Question about Olympus Vr-340 16mp Camera Digital Optical Zoom With 10x
It froze and wont turn on
The camera makes a sound like it will turn on but dosn't and the leans is stuck out
  • 691 Answers
Common problem when the batteries are not able to deliver enough power. Charge batteries or change it. Also remove memory cards and retry.
Posted on Jan 05, 2013
My sony camera dosn't work and i can't see anything just black screen
of course you need to check first, is it completely black screen. could be that its not even turning on.lucky if lets say beep feature was set to on . check if you press any buttons, is there any beeping sound. try to even press the playback and check if any icons will appear.or press the lcd button repeatedly and check if something will happen . if not , do power reset. take out the battery and hold the power button for 30sec. its like refreshing the memory of camera.. if still same thing. try changing batteries. camera also turns on by pressing playback button. if all ts fails, camera needs service. could be something wrong with its sensor.
Oct 24, 2012 | Sony Cyber-shot DSC-W50 Digital Camera
My stereo is stuck on one station, dosn't light up wont turn off/on \r\nthe volum control not working, cant change station, I don;t know whats going on with it !!! It worked fine yesterday
check all of your fuses, the radio has 2 power feeds, one for the operation and one for the memory, if the memory feed is out the radio will work partially like you explained
Sep 23, 2011 | 2004 Dodge Durango
2007 Hyundai Entourage codes P2187, PP0174,P2189,P2195,P2270,P2272
I've come across these codes before. In almost every case there was an air leak in the intake air hose (hose between the engine air filter & the throttle body). Inspect this hose & tubes attached to it. This is especially true when the lean code includes the comment 'at idle'
P2187 - System too lean at idle Bank 1
P0174 - System too lean Bank 2
P2189 - System too lean at idle Bank 2
P2195 = HO2S Signal Biased/Stuck Lean (Bank 1 Sensor 1)
P2270 = HO2S Signal Stuck Lean (Bank 1 Sensor 2)
P2272 = HO2S Signal Stuck Lean (Bank 2 Sensor 2)
P2187 & P2189 = In order to provide the best possible combination of drivability, fuel economy and emission control, the PCM uses a closed loop air/fuel metering system. The PCM monitors the HO2S signal voltage and adjusts fuel delivery based in closed loop fuel control. Changes in fuel delivery will be indicated by the long-term and the short-term fuel trim values. The ideal fuel trim value is around 0%. The PCM will add fuel when the HO2S signal is indicating a lean condition. Additional fuel is indicated by fuel trim values that are above 0%. The PCM will reduce fuel when the HO2S signal is indicating a rich condition. Reduction in fuel is indicated by fuel trim values that are below 0%. The DTC relevant to fuel trim will be set when the amount reaches excessive levels because of a lean or rich condition
Aug 31, 2011 | 2008 Hyundai Entourage
Just replaced the friction plates, the clutch spring hub does not seat onto the splines. What did i do wrong?
G'day.
You don't stipulate your bikes model or year which makes this a bit harder.
When you fitted the outer hub(the one the springs sit in)- you've probably miss-aligned it.
Remove the springs again
Remove the hub- & re-fit over next set of posts(turn the outer hub so it dosn't go over the same posts as before) & it should slot all the way in.
If it dosn't-try again
It looks like the outer hub can fit over the spring posts in any position- but it can't.
I hope this works for you.
Regards Andrew Porrelli
May 20, 2011 | kawasaki VN 1500 Vulcan Classic...
The leans is dark. Object can not be seen through
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 21, 2011 | Kodak EasyShare C763 Digital Camera
My samsung tl240 lens is stuck wont retract cant take pictures cant zoom. Was neverdropped just froze an stopped working
<div><br /></div> <div>remove the battery and memory card. blow out any dust. put back the battery in and turn it on without the memory card. see if you can take pictures, if so then its your memory card. Check the link below. </div> <div><br /></div> <div>http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&amp;PG_ID=0&amp;AT_ID=264556&amp;PROD_SUB_ID=0&amp;PROD_ID=1008&amp;EMAIL_ID=</div>
Jun 21, 2010 | Samsung TL240 Digital Camera
94 wrangler 4 cylinder makes a whining noise and wont turn over when you try to start it, the serpentine belt does not move, it cranked over a couple of times but it was making a grinding sound and i...
Sounds like something in the engine "froze" or stuck Unhook the battery and try turning the engine with a wrench/rachet both ways. Check the timing belt, if broken the pistons will come up and hit the valves then stop everything from turning. Is one of the pullies stuck? Take off the serpentine belt and check all pullies to see if they turn.
Jan 14, 2010 | 1994 Jeep Wrangler
Help
DOES THE CAMERA TURN ON ?? I HAVE FOUND THAT SOME BATTERIES ARE ACTUALY LONGER THAN OTHER BRANDS--AND SOME BEING SHORTER,DO NOT MAKE CONTACT IN THE CAMERA I ONLY USE DURACELL RECHARGEABLE BATTERIES,ALSO ,DO NOT FORCE THE LENS BACK IN IF STUCK,THIS WILL ONLY DAMAGE THE MECHANISM.IT'S WORTH THE MINOR FEE A CAMERA SHOP WILL CHARGE TO REPAIR CORECTLY.
May 26, 2008 | Kodak EasyShare C613 Digital Camera
Olympus Vr-340 16mp Camera Digital Optical Zoom With 10x Logo
49 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
