Question about Gateway 450 Rog, Xp Pro, 512ram, Intel Pentium M 1.7ghz,
Power jack fix - Gateway 450 Rog, Xp Pro, 512ram, Intel Pentium M 1.7ghz,
  • Gateway Master
  • 5,660 Answers
Http://support.gateway.com/s/Mobile/Gateway/450ROG/3501353sp66.shtml
http://www.laptopking.com/kingpartdetails.asp?ref=2371&category=dcjack
The above is for an example, not advertising.
Enlarge the photo. Shows the Front and Rear view also.
The Center Pin is the Positive connection. The Center Pin has one prong lead going to it.
The cylindrical metal shell, inside the jack; is the Negative connection. As you can see there are two prong leads going to it.
Lastly there are two prongs that stick up also; but only go to the U-shaped metal bracket, that adds stability to the jack.
All prongs of course go down into the motherboard, and are soldered in place. The jack is shown upside down.
You need to wear an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Your body carries Static Electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
With an ESD wrist strap, the threat of Static shock to the components is removed.
(And having it's alligator clip attached to a good ground source)
Motherboard removed, the motherboard is turned Bottom side up; so you can access the solder joints, to each one of the DC Power Jack's prongs.
I cut a 6 inch piece of Desoldering Braid, (Solder Wick), and lay 1/2 inch of the tip; across one of the solder joints.
Lay your 25 watt (Or so) soldering iron on top of the braid, JUST until the solder melts.
(No.2 chisel tip for the iron)
All you are trying to do at this point, is try to remove as much of the solder as you can.
The solder wick, (Desoldering Braid), will su-ck the solder up.
Usually the first try gets rid of a lot. You will be leaving behind a thin coat of solder.
What you DON'T want to do is burn the motherboard. Go slow. Takes all day, it takes all day.
If you overheat the motherboard in that solder joint hole's area, you risk lifting a circuit trace up off the motherboard.
[Circuit Trace. Also known as Signal Trace. Think very thin flat copper wires, going all over the motherboard ]
You can also burn the circuit trace hole, (Solder joint hole), and then it won't accept tinning.
(To Tin with solder, is to leave a light coat of solder. A soldering iron, or gun's tip; is Tinned before it is ready to use)
Solder wick tip part that you are using get's 'full', then cut it off so you have a new tip to work with.
Go around, and remove the excess solder, from all those DC Power Jack solder joints.
Removed the excess solder from one DC Power Jack prong?
Allow the motherboard to cool a bit, before going on to the next one.
All excess solder removed from each DC Power Jack's prong, there should just be a light, to slightly heavier; coat of solder left behind.
With the motherboard cool enough to touch, use your fingers to put prying pressure on the jack.
The balls of your fingers grip the jack, and your fingernails work as fulcrums. Gives leverage for your fingers.
Solder iron tip cleaned (Wipe across damp sponge), touch each solder skin joint left behind. You will see you can pry on one side; more than the other; and 1 or 2 prongs should start coming up out of the motherboard.
You can only go so far with them, because the other prongs are still holding the jack.
Allow to cool down some if needed, then go to the other prongs, and heat their solder skin joints.
Keep going back, and forth; or around, and around; until finally all prongs are free from the motherboard, and the jack is removed.
If there is a skin coat of solder left over the circuit trace holes -
LEAVE IT ALONE.
If you try to pick it open, or drill it out with an X-Acto knife blade; you RISK ruining the motherboard.
When you go to install the new power jack, the prongs will be resting up against those holes; and you just touch the solder skin joints one at a time, until the prongs poke through.
See how easy that is? lol!
BEFORE installing the new jack you need to THOROUGHLY clean the solder joint areas. The circuit trace holes, and surrounding area.
I use an old toothbrush, and Isopropyl Alcohol. (Rubbing alcohol)
91 percent is best, but 70 percent will do.
50 percent = no IMHO, because it is 50 percent WATER, and 50 percent Alcohol.
CAUTION!!
Isopropyl alcohol is EXTREMELY FLAMMABLE!
Use in a WELL ventilated area with NO sparks or flames present.
After cleaning you may find that solder was lifted off, and the circuit trace hole needs to be re-tinned again.
Do so if needed.
DC Power Jack in place, I suggest a LITTLE dab of Rosin paste flux; on each prong to be soldered. (Use a flux paste brush is best)
Helps make that solder stick, and you can make a pretty solder joint. (Should resemble a 'Hershey's Kiss', and be bright, and shiny)
Just examples, not advertising;
1) http://www.radioshack.com/product/index.jsp?productId=2062744
2) http://www.radioshack.com/product/index.jsp?productId=2049774
3) http://www.amazon.com/Oatey-30710-Solder-Flux-Brush/dp/B000M2WO3C/ref=sr_1_3?s=hi&ie=UTF8&qid=1357458865&sr=1-3&keywords=flux+brush
More info that may help;
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Service Manual (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Go to - Gateway 400. (400 in blue) Scroll across, click on -
450ROG
(It's a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (450ROG), it may take up to 30 seconds, before the first page comes up )
For additional questions please post in a Comment.
Regards,
joecoolvette
http://www.skyline-eng.com/index.cfm?fuseaction=product.display&Product_ID=5043
Posted on Jan 06, 2013
My Asus Laptop won't turn back on, there is a chemical smell, and my adaptor green light brinks
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the Acer Aspire 5920 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Jan 04, 2013 | Acer Aspire 5920-6727 Notebook
My laptop won't startup
Possible causes:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Hope you just need to replace the hp power supply to fix this problem.
Dec 11, 2012 | HP Computers & Internet
Laptop is charging but cant turn on
When you say "you fixed the thingy" (ac jack), how did you fix said "thingy", did you open the laptop and replace the damaged/broken "thingy"? Need more info. Perhaps the "thingy" isn't fixed? Try remove any DVD,CD, USBs from the laptop, removing the "thingy" , remove the battery, Hold down the on/off button for 10 seconds, replace the battery, replace the "thingy" push the on/off button. That said, When you fixed the "thingy" was ALL power removed from the laptop AC plug, Battery, If not a short may have occurered.
Nov 06, 2012 | Lenovo G470 Core I5 4gb 500gb Hdd Laptop...
SAMSUNG NP R430 POWER JACK
There is something seriously wrong with the power jack for it to get very hot. I doubt replacing the power jack will fix this problem. The laptop needs to be repaired by a specialist.
Jul 28, 2012 | Samsung R430 Notebook
Laptops
WOW, not such a easy fix. Lots of screws, tricky to open.
HP Laptop Power Jack eBay Make sure you get the HP model number off of the Jack socket - It will be labled. Good luck and have a great day. Jack shown may not be the same to your model of laptop.
Feb 12, 2012 | HP Computers & Internet
A bad connection between the power jack and the
What needs to happen is on the motherboard underneath the power jack, there are solder points that have hairline cracks in them. The best way to fix it is to remove the motherboard from the laptop and to resolder all the solder points for the power jack.
Once you do this then the power should stay on cause wiggling the power cord won't cause the laptop to turn off.
Aug 10, 2009 | Toshiba Satellite A205-S4707 Notebook
I opened my Toshiba satellite laptop to fix the DC Jack. Now it wont power on. Any ideas why
when you fixed the jack did U accidently solder anything else to the connector , sounds like a short, causing a ground fault.
Jul 08, 2009 | Toshiba Satellite A105 Notebook
How do you fix or replace a faulty power jack for inspiron 6000?
I PERSONALLY DONT THINK THAT ANY DRIVER IS GOING TO HELP YOU REPLACE UR POWER JACK,YOU WILL HAVE TO GET TO AN I T SPECIALIST,CAUSE UR JACK WILL HAVE TO BE REPLACED,AND IF YOU TRY AND DO THIS YOU WILL VOID THE WARRANTY ON THE MACHINE
Jul 03, 2009 | Dell Inspiron 6000 Notebook
Problems with Magellan Maestro? 4040 GPS power connection
I also have the same problem - the yellow power jack has broken connections. I fixed it by soldering it back. In my unit, the connection pads under the external power jack were intact and I was able to solder the jack easily. The audio out jack nearby has also come-off the PC board, along with the pads. I am not able to re-solder these back. Since the audio jack is part of the speaker circuit I have lost the text-to-speech function!
Hope you are able to fix yours.
Dec 17, 2008 | Magellan Maestro 4040 GPS Receiver
How can I fix the loose power jack?
The last 2 screws to separate top from bottom are located ynder the 3/8" wide clip on plastic piece above your function buttons. Center screw and right hand side. Be careful of ribbons, plug-ins and wires that attach to both sides. I strongley suggest not doing this if you are not mechanically inclined. You could very easily cause damage to your laptop.
Aug 27, 2007 | Gateway 4530GZ Notebook
Gateway 450 Rog, Xp Pro, 512ram, Intel Pentium M 1.7ghz, Logo
130 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
