Question about True GDM-45 Refrigerator
My true gdm 45 is getting to cold
The compressor turns of but not before it drops below freezing and the temp control is turned to 1. I suspect the thermostat but I don't want to throw parts at this thing Help please
  • 400 Answers
SOURCE: I have a true GDM-12FC floral cooler that the
You have not said if the cooler is cooling to the correct temperature or achieving the setpoint. Make sure that the correct thermostat has been supplied. Also that the sensor has been installed in the correct location. If all of the above is correct, then I would have the refrigerant level checked.
Posted on Mar 09, 2009
  • 88 Answers
SOURCE: Tru GDM-47 cooler evaporator icing up.
possible bad defrost timer,or control on an off is bad,were you adjust temperature...thermostat from 30 to 65.00 dollars....possible there is leak or unit is under or overcharged..more than likely under charged...possible defrost heater is not working...good luck..michael doctor airr appl.repair..service tech..843-384-8474...call if need additional help ..its free..
Posted on Mar 27, 2010
duane_wong
  • 6826 Answers
SOURCE: My true cooler gdm-45 is
The thermostat seems to be bad. Or, the defrost timer is staying on too long.
Posted on Jul 12, 2010
  • 274 Answers
SOURCE: True GDM-12 - Unit runs, but won't cool below 60 degrees,
Is it very hot out side the unit.recharging may not hurt is it cleaned the lint could be trapping the radiator were the coolan goes through to cool down try cleanning underneath before recharging
Posted on Jul 26, 2010
  • 906 Answers
SOURCE: GDM-41 Refrigerator: True GDM-41 Refrigerator getting too cold...
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
The GDM-41 true cooler is freezing my food what do you guys think I am thinking of replacing the thermostat
Simply turn the temperatue up a couple of points..If it is freezing stuff it is set too cold !
Dec 04, 2013 | True GDM-41 Refrigerator
My GDM-45 made a loud vibrating noise and quit about 1 hour later
Sounds like your may have a comp issue. The comp has a lot of power and when there is a huge vibration then no cooling i always suspect the comp first.
Aug 14, 2013 | True GDM-45 Refrigerator
My gdm 26 is too cold. have the control on 1 and it is 33 degrees. I have replaced the temp control and it has a new compressor
Make sure the knob is on correctly, very easy to install wrong. Sounds silly but I find them wrong a lot. Look at the shaft, next that is a tab, the tab goes in the shortest channel under the knob. If it is in the longer channel it slips and is not accurate.
Nov 29, 2012 | True GDM-26 Refrigerator
Cooler gets to cold
Try cleaning the condenser coil.
Jul 07, 2010 | True GDM-69 Refrigerator
Got a true cooler with a new compressor... noticed ice on evap when checking temp contrl. replaced temp contrl and still not getting as cold as it should be... ???
probably an wrong freon level. Check that out. could be a freon leak from when the compressor was replaced. Bad weld joint could be the issue.
Let me know if I can be of any further help,.
Jun 16, 2010 | True GDM-47 Refrigerator
good day,
ref
May 18, 2010 | True GDM-41 Refrigerator
Mar 27, 2010 | True GDM-47-RL Refrigerator
We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Jun 08, 2009 | True GDM-12 Refrigerator Commercial
True freezer gdm 35f to cold
you just have to change the temperature control. I recommend using a white rodgers part no. 1609-105 set the cut out to about 33 cut in at 38 or 39 you might have to set defrost time to less minutes about 5 or 6 if coils dosent frezze with the setting i gave you. the bulb of the temperature control can be placed on the border dof the difusser.
Apr 14, 2008 | True 49 cu. ft. / 1388 liter Commercial...
Help?
turn thermostat all the way to the left to turn it off. restore power and see if it stays on and inside fan is running. Then turn thermostat to rite to turn on compressor. If the power trips when turning thermostat back on, the compressor may be bad. :(
Dec 27, 2007 | True GDM-41 Refrigerator
True GDM-45 Refrigerator Logo
59 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
