Question about Cuisinart GG2PR
Knob for a gg-2pr thermostat or new control
Need control knob or new control
3 Suggested Answers
SOURCE: Where can I buy a
http://www.cuisinart.com/discontinued/grills/gg-2.html
Posted on Oct 17, 2010
SOURCE: where can I purchase the
I don't know where you live but I have had to replace two of these now and I go to Servicetek in Mississauga, Ontario 905-602-5191. I understand that this grill has been discontinued which is no surprise to me because the probe in particular is garbage. We originally paid about $135.00 Cdn. for this item and I have had to replace the probe twice at $35.00 plus tax per time. Once this one goes, I will replace it with a better quality item. Hope this helps.
Posted on Aug 29, 2011
Pumpishotnotcuttingoff
The thermostat is probably shot. If the fridge is getting too cold and runs all the time. If its an electronic controller, you will need a new board. If its the old rotary knob type, they are a lot cheaper. On the rotary knob type, you can confirm a thermostat fault by disconnecting 1 or the wires to the thermostat and testing with a multimeter. If the circuit stays closed regardless of where the knob is set, that will tell you the thermostat has failed.
Oct 19, 2013 | Avanti CF100 Chest Freezer
How to replace thermostat
This all depends on the type of fridge. I had a problem with my fridge/freezer and it need a new thermostat.FIRST UNPLUG THE APPLAINCE FROM THE WALL SOCKET. Basically you need to get access to the thermostat and many models the control knob is on the inside and on some its outside on the top. You need to first undo the end where the capillary tube ends then remove the control knob. There is usually a nut holding the thermostat, remove that and also remove the electrical connector and simply pull until the whole of the capillary tube is out. Refit the new one in reverse order.
Feb 19, 2013 | Refrigerators
Trying to find an electric probe for cuisinart griddlenGG-2pr 120VAC
Unfortunately Cuisinart has discontinued the probe GG-2PR for this machine. Finding an old machine through Ebay or something along those lines is probably the easiest way to get the probe.
Oct 27, 2010 | Cuisinart GG2PR
Where can I purchase the Cuisinart GG-2PR Probe with Control Knob - i ordered it from Cuisinart - they said they had it - but it came backordered cancelled! Thanks...Dennis
Oct 18, 2010 | Cuisinart GG2 Indoor Grill
Replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
Dec 12, 2009 | Viking VGIC485-6G Gas Kitchen Range
XL 44 Gas Range Oven temperature problem
hi If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about
25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
Step 3: If necessary, replace the thermostat with a new one of the same type.
If you need to replace the thermostat, follow these guidlines:
Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
Step 3: Install the new thermostat using a reverse procedure.
Nov 06, 2008 | Ovens
Control panel erase from the windows
hi The thermostat control is usually mounted inside the refrigerator. Its visible control knob is turned to regulate the refrigerator/freezer temperature. The workability of this control can be tested in various ways, depending on the problem. To test the thermostat control:
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Nov 06, 2008 | Samsung RS2630WW Side by Side Refrigerator
Kenmore Elite bottom freezer suddenly stops making ice.
Step 1:
Step 2:
Step 3:
Step 4:
Sep 14, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Mabe oven thermostat and stove flame adjustments
Step 3: To check an operating thermostat, first make absolutely certain that the power to the dryer has been turned off and the dryer is cool. Then disconnect the leads to one side of the thermostat. Test an operating thermostat with a VOM set to the RX1 scale; clip one probe to each terminal of the thermostat. Disconnect the leads to one side of the thermostat so that the meter won't give a false reading. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Sep 13, 2008 | Kitchen Ranges
Cuisinart GG2PR Logo
53 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
