Error code c-0413 for konica minolta c 6500
I started my machine after it warm up i am getting the error C-0413, any advice please. Thanks in advance.
  • 1003 Answers
SOURCE: Minolta Konica 7145 error code 26-3
NOT SURE BUT YOU CAN GET SERVICE MANUAL WITH ERROR CODES DEFINITIONS www.precisionroller.com type in your model
Posted on Jan 13, 2008
  • 3 Answers
SOURCE: c451 Bizhub Konica Minolta printer
press utility. press metercount. press metercount details. press stop 0 0 stop 0 1 to access service mode in service mode look for admin initialialation function
Posted on May 22, 2008
SOURCE: error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Posted on Sep 22, 2008
jqsababa967
  • 145 Answers
SOURCE: KONICA MINOLTA
CD231 at power up.
Solution:
CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231.
hope that helps
Posted on Nov 04, 2008
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
Hey I have konica minolta magicolour 2400w printer. When i turn it on, it start warming up but after 3 seconds it turns on the ERROR light & the printer doesn't work. Every time i turn it on same issue...
Hi
Usually these machines give you an error code on the control screen. You do not mention one but the webpage here:
Error Codes Konica Minolta Magicolor 2400W
gives most of the error codes for your model.
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Office Equipment & Supplies
Konica minolta 6501 error code c-c101
had a circuit board replaced recently??? if so check each and ever connection, pull each connection and reseat each connection one at a time while each connector is removed check all pins for a bent pin. Or replace the Print control board, Interface control board, image control board, and the overall control board, $$$$$$$$$$$$$$$$$$$$$$$$$ more then what you paid for the machine!!!! Then you will still have to remove each connection and reseat them and look for bent pins!!!!!
Jul 03, 2014 | Konica Minolta Bizhub C 6501 Color...
What does error code c3102 0n a konica minolta bizhub 6500 mean
problem with Fusing release home sensor and or fuser motor. Fuser is the Hot Part of the machine
Jun 16, 2014 | Konica Minolta Office Equipment & Supplies
Error code 3501
HI
I HAVE KONICA C6500
ERROR CODE 3501 and 3802 but know the error 3501
I know it rech high temperature I change the sensor 1 UP fuser roller
and I reset the error, the machine start and stop again with error 3501
Oct 01, 2013 | Konica Minolta Bizhub C 6500 Copier
Error code c6708
Please send me konica minolta bizhub 600 full service manual and help us this code c6708 still and my next machine bizhub 750 still warming up why problem this machine please help and send me your email address.
i want to talk to you continuous
May 18, 2013 | Konica Minolta Developer 02xk Dv710 for...
Error code c2863
Hi, i have a konica minolta c6500, and i have a problem with error code c-6500. What happen?
Mar 26, 2013 | Konica Minolta bizhub Office Equipment &...
Malfunction code C0040
Minolta copier show error code c0040. Please show me the picture that point of problem. The second problem. What is the way we could what kind of minolta di ...in the machine?thanks in advanced.
Apr 12, 2012 | Konica Minolta DiALTA Di200 Copier
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
I have a 3508 code on my minolta bizhub 6500
Fuser (HOT SECTION) Code requieres technical service to prevent completly destroying machine
Aug 15, 2009 | Konica Minolta Office Equipment & Supplies
ERROR CODE C-4401 On Konica Minolta Bizhub 500
CAUSE: Failed write unit. Laser
Replace write unit (p/n 50GA-6500).
Feb 19, 2009 | Konica Minolta Office Equipment & Supplies
113 people viewed this question
jasbo
jasbo
