Question about Vacuums
How to unclog the Bissell little green machine
The machine will not suck or pick up the water.
I have removed the dirty tank container and check the hoses far as I could. I also used wire hanger and stuck it in there and try to pull out anything in was in there and nothing came out.
Do I have to disassemble it or take off the bottom or what
  • Vacuums Master
  • 18,394 Answers
SOURCE: my little green machine won't spray the solution but it will pick
We had the same problem. After dissassembling the whole machine we could not find a clog or any other obvious problem. The manual suggests priming the pump by putting the solution reservoir in and out a few times. This did not help much. What did work was to raise the unit up a few feet above the trigger while depressing the holding the spray trigger. (That is, use gravity to fill the tube.) After solution was flowing freely, we turned the machine on and it seems to spray fine again.
Hope this helps
Posted on Jul 22, 2009
reddevil6
  • 1673 Answers
SOURCE: Bissell 1720-1 Little Green
If it isn't spraying, the pump is most likely bad, leaking from tank, depending where it is leaking, may need a new tank. But Bissell has obsoleted this unit and its parts. So unless you can find the parts somewhere, it may be time for a new one.
Posted on Feb 29, 2008
  • 29 Answers
SOURCE: I have a Bissell pro heat water will not disperse from
If the red spray pieces are not clogged but the Bissell still will not dispense water, then I would say the next most likely causes of your issue was either no soap in the tank, or a burnt out water pump. But since you can get water through the tools, I don't see how that's possible. I think it's still the sprayers. When you say you stuck a needle in the eye holes of the two red spray pieces, did you actually take the two red spray pieces off the hoses to do this? And then after pushing through a needle, did you try blowing through the red spray pieces? If you can't blow air through them, they're still clogged and water won't go through, either. Here's how to get the red spray pieces off the Bissell: Unplug the Bissell. Remove the water tank pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your roller brushes when you press the water-and-soap trigger at the top of the Bissell's handle, and tend to clog with mineral deposits. Only work on one sprayer at a time so you can see how it goes back together. As you squeeze the red plastic sides of one red water sprayer, push up on the underside of the sprayer from underneath the bottom unit of the Bissell to release the sprayer from its mount in the base. Clean any lint or debris out of the mount area. Clean any gunk you can off the red water sprayer with an old toothbrush. Now you need to remove one water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip up the hose so it compresses the spring and is no longer on the red plastic water sprayer. (See GOTCHA about the spring, below.) With the clip released, now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care. When you've removed a red water sprayer from the hose, put the end of the red water sprayer that was inside the hose in your mouth and seal your lips around it, and try blowing through it. If you can't blow air through it, it's clogged. Open up a paper clip and push it back-and-forth through the small hole in the hose end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Click the red water sprayer back into position in the base of the Bissell. Now do the same for the other red water sprayer. The GOTCHA: Once when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. It?s best to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, fix this by removing the six screws on top of the Bissell base (this is the surface the water tank mounts on top of), and pry it up. Pull out the hose, reattach the red water sprayers on the hose, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base. You might want to prime the pumps. Sometimes an air pocket inside the machine (even a new one) keeps water from flowing, until you reprime the Bissell's internal pumps. To prime the pumps the easy way, turn it on, then press, hold, and release the water-and-soap trigger a few times, waiting a few seconds each time. Still nothing? Prime it the slightly harder way. Separate the two water tank pieces. Only have the base tank filled and mounted on the Bissell without the piece that sits atop the tank. Turn it on. Kneeling on the floor in front of the Bissell, reach up and press the soap and water trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel just a bit of suction. Lift your hand up and down a few times, a few seconds apart. Release the trigger and repeat a few times. As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Thoroughly rinse out and empty both water tank pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and get all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and needs more pampering than a vacuum cleaner, doesn't it?? Good luck!
Posted on Jun 12, 2009
SOURCE: not picking up water on a bissel proheat turbo 2x
If unit is not picking up solution it is most likely the small red plastic filter that is just above the small float door in the top piece just left of the tool switch.. pop it out clean muck out of it and it will work like new again.. have fun!!
Posted on Jan 31, 2010
  • 17 Answers
SOURCE: i have a bissell proheatX2. it has quit spraying
Here is how
Posted on Feb 08, 2010
We have a bissell lift-off deep cleaner 66e1 and it won't suck up the dirty water what can I do to fix it
Loss of suction power -
1. Tanks may not be seated properly - Pick up both tanks and reseat them so they fit properly on the unit.
2. Nozzles may not be assembled properly - Unplug the unit. Check to make sure the "lip" of the nozzle cover is securely hooked into the groove on the top of nozzle.
3. The portable spot cleaner is not attached completely - Push down firmly to check connection
4. Dirty tank has picked up maximum amount of dirty water and has reached full line - Empty dirty tank
5. Formula & water tank is empty - Check fluid levels in formula & water tank Suction Gate is open Check to make sure the suction gate is closed. Follow "Cleaning Suction Gate" instructions in the manual.
I hope this helps!
Jim
May 27, 2016 | Bissell Vacuums
Bissell little green machine- won't ****. I
it may be the pump this video will give instructions how to disassemble it
http://www.youtube.com/watch?feature=player_embedded&v=1sSVIu6arbY#!
Jan 05, 2013 | Vacuums
Bissell little green leaks
the tank where the water is has a crack in it mostlikely
Sep 10, 2009 | Bissell 1425 Little Green ProHeat Handheld...
The water is staying in carpets and is not being sucked back to the machine
The pick up slot across the front of the unit may be blocked or internal path for the water into the tank. Disconnect from electric and strip down the head and check for fibres/fluff balls - as these are the normal culprits. I am assuming that the suction motor is running?
Good luck
May 12, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Cleaning the bissell little green
take the jugs off the sides and wash the base. out with bleach water,also fill the solution tank with bleach water and shake well to remove the mildew and dirt from the tanks
Apr 27, 2009 | Bissell 1400 Little Green Pro Canister...
Not sucking up dirty water
Sounds like the suction motor is not working correctly. Either clogged with dirt or objects or it is failing.
Check this first:
Not suctioning properly, first check the motor duct gasket. To check this, first remove the tank and place your hand over the rubber square opening.
If your machine does have suction at the duct, continue to check the following:
Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE
ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced.
Check the Tank Lid and Tank for damage.
If there is no suction there, please take your machine to a BISSELL Authorized Service Center for inspection.
Jul 31, 2008 | Bissell 1699 ProHeat Clear View Upright...
I need directions for using the Bissell Little Green.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=723971
Generic problem for all Vacuums
Posted by jkcanger on Jun 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. If the instruction did not come with the Bissell Little Green Machine then I would contact the Bissell Factory that I will provide for you listed 2 the bottom of the answer,
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Kenmore Progressive Bagless Upright with...
Vacuums Logo
721 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
