Question about Fahrenheat Heating & Cooling
Wiring for a 240 Volt Wall Heater bypass built in Thermostat to a wall two pole Therrmostat
Bypass fan heater 240v. Thermostat to change to two pole Thermostat on the wall
4 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: wwiring baseboard heaters
http://partner.dimplex.com/files/domain4103/7207610100rev00.pdf
Posted on Dec 29, 2009
  • 149 Answers
SOURCE: I just need a wiring diagram---with a thermostat--
grainger has them- home depot. wire is easy wire one side straight to 1 wire on in coming power the other side use your thermostat to break curcit ie wire into stat out of stat to voltage
Posted on Jan 16, 2010
SOURCE: How to install a wall dimplex thermostat to a
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Posted on Sep 21, 2010
Electric Wall heater programmable thermostat
First of all most home thermostats operate on 24volts. If you want to have one that directly turns the 240 volt power on and off you need to get a special 240V line voltage thermostat. How many wires come out of your heater? Most 240v circuits have three wires. A white wire for the common and two black or black red wires that are +120 volts and negative 120 volts. That's why a 240 volt plug has 3 prongs instead of two. If you look at the wiring diagram that comes with the thermostat it should give you an idea of how to hook the wires up. In your particular case though, I think I would try making friends with an electrician.
Nov 09, 2013 | Hardware & Accessories
I need to wire a remote thermostat to my electric wall heater in the bathroom. Not sure if I run the wire from the panel to the heater first or to the remote thermostat then the heater.
Run the wire to the thermostat then to the heater
BASEBOARD WIRING WITH A SINGLE POLE (2 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLY
BASEBOARD WIRING WITH A DOUBLE POLE (4 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLYdennis675_0.gif
Jun 21, 2011 | Heating & Cooling
Can a 240 volt outlet be ran off this breaker and can a 240 volt electric baseboard heater be wired to it or should i use double pole breaker?
You need 240 breaker:
Notice that your 240V breaker is twice as wide as regular 120V breaker.
Notice that both switches are tied together on 240V breaker, making this a double-pole breaker.
For more information about breakers and 120-240V circuits:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/B220C.html
Jan 24, 2011 | Siemens 20 Amp Single Pole Breaker 120/240...
Properly installed electric baseboard heater won't work.
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wire to the neutral will not cut it. If both your red and black wire are on the same phase the heater will not work.
To double check your wiring, measure the voltage across the two screws feeding your subpanel, they should be 240v or 208v depending on your power company. Then do the same at the breaker feeding your thermostat. Again it should read 240v.
If you have no potential across the screws it is possible that you installed an incorrect breaker. Not all breakers with two screws on them are 240v breakers. There is what is called a twin or split breaker that has two screws that are on the same phase. These are for wiring two 110v circuits, when you run out of spaces in the panel.
Double check everything. This is a relatively easy circuit to wire, even for homeowners. If the heater does not work them something is wrong so do not leave the circuit energized.
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Connecting 240 volt singer baseboard heater
Need front grill for singer model WJA-12 wall heater Cat # 9756-A
single phase 60 HZ
240 volts 5.2 Amps
1250 Watts
Where can I find it?
Nov 28, 2007 | Heating & Cooling
Cadet wall mount and thermostat
your wiring is all wrong. for a 240 heater a 20/20 tandem breaker will not work with a 240 heater. you need a 20 amp two pole breaker. the two wires at the heater need to be connected to the line. you probably have two black wires at the heater. one connects to the white romex which should be taped black, and the other romex black connects to the other black wire. at the panel one white goes to one side of the breaker and the black to the other. the bare ground goes to the neutral bar.
Oct 27, 2007 | Cadet Manufacturing 67507 Heater
Wiring my 240 V wall mount heater
Your question is kind of vague, but the 240v goes to the heating element, if the heater has a fan, it may be a 110v, so the white is common and should be wired as such. The heater should have a wiring diagram on it.
Oct 26, 2007 | Fahrenheat (FFH1614) Wall Mounted Panel...
Install and hot wire heater
You can be assured that the element is 240 volt. The fan motor is also rated at 240 volt. the wires you have black - black are the connections you make to the line. Use a 12/2 with ground. Use a double pole 20 breaker in your panelbox. The green wire is the equipment ground - connect this to the bare wire from the 12/2. On the 12/2 cable - there will be two colors, one black and one white. Wrap a couple of turns of black tape on the white wire both at the heater location and on the white in the panelbox. connect the 12/2 to your 2 pole breaker, the black wire and the taped white to the breaker.
Sep 05, 2007 | Fahrenheat FFH1615 Heater
Heating & Cooling Logo
244 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
