Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Frig and freezer not cooling
I have a kenmore elite model 596.7350201 refrigerator and I've been hearing a clicking noise coming from it. It has quit cooling and the freezer section is thawed out. What what I've read, this could be a capacitor problem an overload relay problem or both. I hope it is not the compressor itself. What do you think?
  • 2 more comments
  • rhkhawk63 Jan 19, 2009
    that would be a kenmore elite model 596.73503201 refrigerator. thanks
  • mclaugh Feb 21, 2009
    I Have the same problem on my 76503. The Fan is running but it seem like the compressor is not working and the fridge is not cooling.
    Michelle
  • Anonymous Apr 11, 2009
    My compressor died on this relatively modern machine. I am very unhappy, and strongly suggest avoiding this model.
    To invest this kind of money and wind up with a doorstop on a long-term appliance is insulting.
  • cliffqueen May 24, 2009
    It's running but stops cooling almost every other day. Have cleaned everything - just stops cooling. I unplug for a few minutes and it usually starts cooling soon. Help!!!
  • 410 Answers
It is possible that a start relay has gone bad but more likely is that the compressor has seized up. if the unit is under 5 years old most likely the comp will be under warranty from sears. peyton
Posted on Jan 20, 2009
Frigidaire gallery freezer fully thawed and red light never came on.
So lets start with this do you hear any clicking noises coming from behind the frig? Can you hear the fan running in the freezer? Does the frig cool at all?
Sep 25, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a kenmore elite frig that just stopped working not cooling at all it is only 13 months old
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Kenmore Refrigerators
Our frig compressor won't come on and cool the frig
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 29, 2011 | Kenmore Refrigerators
FREEZER AND REFRIGERATOR NOT COOLING HEARING CLICKING NOISE
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore elite side by side bottom freeze frig.There is a huming noise coming from the frig.sounds like the compressor. The freezer is starting to frost over. I can make the noise stop by opening...
Hi and welcome to FixYa. I am Kelly.
The humming noise your hearing is the evaporator fan blades striking the ice build up on the evaporator. The fact that you have ice build up is a sure sign your refrigerator is not defrosting.
The door switch controls power to the evaporator fan.
I am going to use this model number 106.57071791 as a parts reference that MAY be different from your actual model but it is close. This model is a mechanical control refrigerator. You may have the electronic control version.
Take a look at item 6 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657071791/0582/0165000/P8100197/00012?blt=06&prst=&shdMod=
It will be located in the top left of center & front of your fresh food compartment. It will be circular and will have 2 tabs on it with an incline so that if you were to rotate the tabs with something flat it would only turn ONE direction.
Either use your finger nail or something flat to SLOWLY rotate that until you hear an audible click. (Everyting stops but the lights) This is initiating an automatic defrost cycle. After about an hour come back and check to see if your refrigerator has re-started. If it has not restarted there is definately a problem with the automtic defrost circuit. That can be the timer (listed above), The defrost element under the evaporator, the Bi-metal thermostat on the evaporator or wiring.
All parts can be found via this link / section
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657071791/0582/0165000?pathTaken=
If none of the links work go to http://www.searspartsdirect.com and enter your model number where it says find it fast and choose model search.
I guessed at the model number so if this does not resemble your refrigerator or you have the electonic control board type refrigerator please respond with your model number.
Thanks for choosing FixYa,
Kelly
Oct 09, 2010 | Kenmore 53642 / 53644 Side by Side...
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The Freezer and Refrigerator has stopped working completely
first check to see if the compressor and fan on the lower back of frig is working,if it is then check the freezer to see if the freezer fan is working,if it is then find the defrost timer(most of the time behind the front grill or inside frig. or on lower back)turn it til it clicks,wait 30 minutes and see if it comes out of defrost(you k=will know this if the freezer fan comes back on,let me know what you find-mike
Apr 16, 2009 | Refrigerators
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite trio bottom freezer refridgerater 795 7555
there are 3 ways it can be held on,screws,snaps,clips or slides one way up or down or side to side,to make sure what you have get the model number from inside the frig. ,go to sears .com click on parts put in your model number and your whole frig diagram will come up and you will see exactly how it comes apart,let me know how you do-mike
Oct 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer works but frig is not cooling
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Aug 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
488 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
