Switch hard to use - Computers & Internet
  • 27,725 Answers
Now what switch are we referring to post a reply with the switch details so someone can try to help you
Posted on Jan 05, 2013
  • 2 more comments
  • Tim Quinn
    Tim Quinn Jan 05, 2013
    Don't know why this ended up ini Hard drives, because I put in that it's for a Dustbuster! The switch to turn it on and off.
  • Brian Sullivan
    Brian Sullivan Jan 05, 2013
    Which brand and model of dustbuster do you have
  • Tim Quinn
    Looks like we got it working better--for now anyway. Thanks. I may be back later!
  • Brian Sullivan
    Brian Sullivan Jan 06, 2013
    thanks for replying sometimes just removing items then resore them to there original positions makes them work again strange its murphy's law
Erase hard drive hp1055
In service test menu scroll to "3.Hard disc drive", & press enter, if test drive passed don't replace the hard disc or modification or changes. If test failed then check as shown below:
1 Switch the printer OFF. Remove the EIO Card (if installed) and re-install the Hard Disk Drive making sure it installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails again then replace the Hard Disk Drive.
2 If the Hard Disk Drive Test passed after removing the EIO Card,then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened.
Switch the Printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails, then the EIO Card could be faulty.Replace the EIO Card.
3 If the Hard Disk Drive Test continues to fail after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module..
I am having little knowledge, if I am wrong Pl don't comment, pl forgive me.
May 20, 2013 | HP DesignJet 1055cm InkJet Printer
When I switch on the device I now hear a clicking sound coming from inside
A clicking noise from a hard drive indicates a faulty hard drive, it is known as the Click of Death.
If you need data off this faulty hard drive, there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Jan 31, 2013 | Maxtor Personal Storage 3200 (U01E200) 200...
How do I replace power switch on fantom gforce 1tb external hard drive?
I have the same problem. These guys are clueless. I removed the warrenty sticker, undid the screws, and slid the hard drive bracket out easily with a little push. Unpleg the wire connecting the power switch to the board. Push the switch out from the inside, applying presure to the top and bottom. You've removed the faulty switch. Replacing it is my new problem.
Aug 19, 2010 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
When the breaker goes the on/off switch as a hard clicking sound that disappears once the breaker is re-set. The breaker is re-set but the compressor still won't start and the on/off switch still has the...
1. Disconnect the power or put the circuit breaker to
off position.
2. Disconnect the motor connection from the on/off
switch.
3. Put the circuit breaker to on position and put
the switch to on position. If there's a hard clicking
sound even without the motor. Then, it needs to be
replaced.
4. If there's no hard clicking sound, then, your motor
must be grounded or partially burned winding.
This must be corrected to get your compressor
running.
Oct 24, 2009 | Black & Decker Dewalt #D55155 2HP 4GAL...
Getting error code 04C300 00310000
Hi;
if you HP 1050C Plus display System Error 04CXX Try the following Steps to resolved an error:
1.)Press ENTER and switch the printer OFF. Remove the Hard Disk Drive (if installed) and make sure that the EIO card is installed
ON again. If this error code continues to appear then replace the EIO card.
2.)If this Error Code disappeared after removing the Hard Disk Drive, then switch the Printer OFF and reinstall the Hard Disk Drive, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If this Error Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
3.)If this system error continues to appear after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module...
May 26, 2009 | HP DesignJet 1050c InkJet Printer
640 GB WD element hard drive has no power
Try it on a different USB port or on a different computer - is this hard drive powered via a mains cable ? If so is that plugged in and switched on as well ?
Also does the hard drive have an on off switch at the back or on it anywhere that needs turning on ?
Does this hard drive have a firewire port or another way of connecting to it ?
Apr 10, 2009 | Western Digital Elements powered by WD 320...
System Error 04C300 00260000
System Error 04CXX Try the following Steps to resolved an eror:
Aug 21, 2008 | HP DesignJet 1050c plus InkJet Printer
Installation
unplug you hard disk, then switch on without your hard disk let your xpcd in your cd rom to run after reading your cd ''saying, no hard drive found'' switch off then plug it in your installation will proceed
Nov 27, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
LaCie Hard Drive
The hard drive has it's own power supply. If you look on the back of the external hard drive, there is a power button there to turn it off. It doesn't shut off just cause you disconnect it from the PC or turn the PC off.
Feb 01, 2007 | LaCie (300951U) 500 GB Hard Drive
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
