How do I install a new frexer door fisher paykel e522b. Do I need to pull off the top door, or go from the bottem
SOURCE: THE TOP PART (FRIDGE) IS NOT COOLING
We had the same problem. The duct between the freezer unit and fridge is probably iced over - a design problem apparently. Allowing to completely defrost will solve.
SOURCE: I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Testimonial: "which temerature censor ( there are three )"
SOURCE: I have a fisher and paykel E522B refridgerator and
In most case the screws are hidden, some of the handles have a cover that slides up or down, and the others have a little hole cover that have to be popped out and then you can access the screw
Testimonial: "I actually found little hex screws at the bottom of each of the handles. Once both are loosened a fair way the handle comes off allowing tightening."
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
SOURCE: Fridge compartment not cooling. Freezer
Hi, Refrigerator or Freezer not Cooling or Getting Cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
