Question about Vacuums
Bissell little green machine- won't ****. I
  • Vacuums Master
  • 18,394 Answers
It may be the pump this video will give instructions how to disassemble it
http://www.youtube.com/watch?feature=player_embedded&v=1sSVIu6arbY#!
Posted on Jan 05, 2013
  • 389 Answers
SOURCE: How do you operate the Bissell 1725 LittleGreen Machine Proheat
Go to www.bissell.com then click the Customer Service tab. In the next window click on the User Guides link (in green on left hand side), then enter your model number. You can then download the full instructions.
Posted on Mar 15, 2009
  • 29 Answers
SOURCE: I have a Bissell pro heat water will not disperse from
If the red spray pieces are not clogged but the Bissell still will not dispense water, then I would say the next most likely causes of your issue was either no soap in the tank, or a burnt out water pump. But since you can get water through the tools, I don't see how that's possible. I think it's still the sprayers. When you say you stuck a needle in the eye holes of the two red spray pieces, did you actually take the two red spray pieces off the hoses to do this? And then after pushing through a needle, did you try blowing through the red spray pieces? If you can't blow air through them, they're still clogged and water won't go through, either. Here's how to get the red spray pieces off the Bissell: Unplug the Bissell. Remove the water tank pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your roller brushes when you press the water-and-soap trigger at the top of the Bissell's handle, and tend to clog with mineral deposits. Only work on one sprayer at a time so you can see how it goes back together. As you squeeze the red plastic sides of one red water sprayer, push up on the underside of the sprayer from underneath the bottom unit of the Bissell to release the sprayer from its mount in the base. Clean any lint or debris out of the mount area. Clean any gunk you can off the red water sprayer with an old toothbrush. Now you need to remove one water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip up the hose so it compresses the spring and is no longer on the red plastic water sprayer. (See GOTCHA about the spring, below.) With the clip released, now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care. When you've removed a red water sprayer from the hose, put the end of the red water sprayer that was inside the hose in your mouth and seal your lips around it, and try blowing through it. If you can't blow air through it, it's clogged. Open up a paper clip and push it back-and-forth through the small hole in the hose end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Click the red water sprayer back into position in the base of the Bissell. Now do the same for the other red water sprayer. The GOTCHA: Once when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. It?s best to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, fix this by removing the six screws on top of the Bissell base (this is the surface the water tank mounts on top of), and pry it up. Pull out the hose, reattach the red water sprayers on the hose, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base. You might want to prime the pumps. Sometimes an air pocket inside the machine (even a new one) keeps water from flowing, until you reprime the Bissell's internal pumps. To prime the pumps the easy way, turn it on, then press, hold, and release the water-and-soap trigger a few times, waiting a few seconds each time. Still nothing? Prime it the slightly harder way. Separate the two water tank pieces. Only have the base tank filled and mounted on the Bissell without the piece that sits atop the tank. Turn it on. Kneeling on the floor in front of the Bissell, reach up and press the soap and water trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel just a bit of suction. Lift your hand up and down a few times, a few seconds apart. Release the trigger and repeat a few times. As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Thoroughly rinse out and empty both water tank pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and get all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and needs more pampering than a vacuum cleaner, doesn't it?? Good luck!
Posted on Jun 12, 2009
  • 40 Answers
SOURCE: Bissell Big Green Machine just stopped working in
the motor could have fried or the wires have been shaken off the motor terminals.
Posted on Aug 01, 2009
fixdat22
  • 34 Answers
SOURCE: bissell little green leaks
the tank where the water is has a crack in it mostlikely
Posted on Sep 12, 2009
SOURCE: MY Bissell Little Green Machine doesn't seem to be
Well i see you wrote the question a long time ago but here is what I found. I have new carpet and we got a puppy. You know what that means. Anyway a lot of use and the new carpet gave up a lot of fibers. The fibers lodged in the "s" shaped portion of the suction line. You must remove the bottom (just 6 screws) to see this part. I could not figure out how to detatch the hose so i rigged a way to put air pressure though the head end of the hose and gentrly tapped the "s" shaped part with a plastoc mallet, clumps of fibers started to come out, eventually a real big one popped out and the thing was clear. What a pain it was!
Posted on Oct 10, 2009
Won't spray solution
if its not spraying solution there are two possible problems,
1. the solution carrying line that runs from the unit along inside the hose could be blocked.
2.there mite be a clog somewhere inside the solution tank or leading from the solution tank
Sep 19, 2012 | Bissell THE BISSELL LITTLE GREEN MACHINE...
Have bissell little green model 1400. Having trouble cleaning the holding tank (dirty water) tank. The tank comes out but the stuff doesn't rinse out - its gross. I'd like to take the holding...
Do not take it apart.If you do,it is then broken.Put about1/ cup of powdered dish washer detergent,in the bowl and fill with hot water.Let that soak for a few hours.And as the shampoo folks say,rinse and repeat,if needed.This also will clean tubs,toilets,and all ceramic tile very well.
May 13, 2011 | Bissell Vacuums
Bissell little green machine will not spray
The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
Mar 22, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Bissell little green leaks
Sep 10, 2009 | Bissell 1425 Little Green ProHeat Handheld...
Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
Oct 20, 2008 | Bissell 9200 Upright Vacuum
I need directions for using the Bissell Little Green.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=723971
Generic problem for all Vacuums
Posted by jkcanger on Jun 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. If the instruction did not come with the Bissell Little Green Machine then I would contact the Bissell Factory that I will provide for you listed 2 the bottom of the answer,
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Kenmore Progressive Bagless Upright with...
Need Help
Facing the machine, the tank on the right is the solution tank, the tank on the left is the recovery tank. The solution tank is where you mix the solution and water to do your shampooing. The recovery tank is where the dirty water will vacuum to. Just a note, this model and its most of its parts are oblsolete.
May 13, 2008 | Bissell 1720-5 Little Green Turbobrush...
Vacuums Logo
182 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
