Question about Viking DVGBQ532-3RTL (LP) All-in-One Grill / Smoker
Viking grill will not light but the burners are working
  • 59 Answers
Do the igniters spark?
Have you replaced the batteries in the spark modules, they arer located behind the drip tray at either side of the unit?
Posted on Mar 05, 2009
3 Suggested Answers
  • 10865 Answers
SOURCE: viking grill burner is clogged and fire is
Hello. Use ammonia. If you can remove the burner, wrap it in ammonia soaked newspaper layers and slide it into a large plastic bag overnight. Joe
Posted on Mar 21, 2010
SOURCE: Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Posted on Apr 30, 2010
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
We have intermittent low gas flow to our Viking grill. We have replaced the burners and the regulator. It worked fine on Sunday but now today only the first burner lights (and it's low even though I...
Lynn, the problem lies with the gas regulator and the way you turn the tank ON. But it's readily solvable.
1. Turn the tank valve OFF & disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first and set it on HIGH.
Does the flame height look correct? If so, light the remaining burners the exact same way.
Do all the flame heights look correct? If so, your solved the problem. Always remember to
open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. They run about $30.00 at any hardware store or home center that sells grills and accessories. Simply take you old one with you for comparison purposes.
Hope this helped you troubleshoot & solve the problem. Please let me know. Thanks.
Jul 06, 2011 | Viking VGBQ410-3RT Grill
Viking gas grill - when I turn the knobs to lite up one of the burners, it rushes out the gas with a loud hessing sound. also there are flame coming out from where the gas comes out and goes into the...
What you have described sounds like a clogged burner as well as the venturi valve on the burner. Your will need to remove the burner to clean it and the venturi valve on the open end of the burner, that goes over the burner orifice. Spiders like to build nest in them and clog them up. The venturi valve will look like two slots, cut in to each side of the burner, at the open end. It's function is to mix air with the gas, for proper combustion.
Hope this helped you to troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 16, 2011 | Viking Grilling
I have a Viking Grill model VGBQ530 with cast iron burners that need replacement. I cannot find the exact model no. with these replacement burners however it appears that Viking now have a replacement made...
That is correct. Viking no longer supports the Cast Iron Burners. There is an aftermarket Burner VIKU1 that comes with mounting brackets to convert older Viking Grills that used a Cast Iron Burner to be able to switch to the stainless steel burner. The large bracket attaches to the center tube and has two screw holes and screws for mounting to the rear of the housing. The two smaller brackets mount to the two holes at the rear wall of the housing and create a ledge for the end of the two tubes to rest on.
Jun 11, 2017 | Viking Grilling
Viking grill burner is clogged and fire is shooting out of knob. How do I clean my grill from excessive grease.
Is it still under warranty? I'd call Viking or a qualified repairman to fix it. If your burners are clogged, the flames should be coming out the venturi tube and flaming towards the gas valve knob. If the flames are coming out of the gas valve itself, then it will need to be regreased. If the burners can be removed without too much trouble, soak them in the sink with hot water and dishwashing detergent. Be sure to remove the knobs, so no one turns the gas on without the burners connected. If it's difficult, call a repairman.
May 12, 2010 | Grilling
Viking stove right burners won't light
can u see the burner spark if not then ht lead at fault of electrode
Aug 21, 2009 | Viking 31 in. VGSU101 Gas Cooktop
We bought a new 41 inch viking grill. Hooked up LP regulator and tank. When we light the burners there is a loud humming noise that is coming from the regulator and/or hose (we have reassembled twice to...
First make sure everything is tight on the valves if you still smell it get some windex spray where you hoses, the tank where it connects places where the propane gone if it bubbles you have a leak for the noise turn the tank upside down and shake it for about 10 second
Jul 12, 2009 | Viking VGBQ532-3RT All-in-One Grill /...
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Apr 30, 2009 | Viking VGIC485-6G Gas Kitchen Range
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Viking DVGBQ532-3RTL (LP) All-in-One Grill / Smoker Logo
494 people viewed this question
Top Viking Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Mike Hollander
Mike Hollander
Level 1 Expert
Are you a Viking Grilling Expert? Answer questions, earn points and help others
