Question about Bosch Dryers
I think my bosch maxx 7 dryer is child locked
    Sergeant:
  • 475 Answers
Try to unplug it and let it sit for a while then try to plug it back in and see if that resets it.
Posted on Jan 05, 2013
4 Suggested Answers
SOURCE: Bosch Maxx WTL 6100 tumble dryer - door switch
i have wtl 6100 bosch and the mashine is not running. There is power on the machine, it can run but it can not run and heat. I can get light in al the panel, but it is like it needs to be rebouted. I can get it to show 111,222,333 etc in the window but i cant get it to work
Posted on Sep 05, 2010
SOURCE: Bosch maxx 7 sensitive dryer wich stops everytime
Technician just solved that annoying problem. My dryer is few months old and without pump, so condensed water is dripping to tank by gravity. During drying cloth is collected on filter and condenser, but some amount of cloth goes into pipes and canals on the bottom of dryer and clogged non-return valve where tank is inserted. Side panel ha has to be removed, canals and valve cleaned. To prevent problem technician suggested condenser and filter cleaning after every use. Valve can be removed from bottom without removing side panel.
Posted on Feb 22, 2011
kevin_getz
  • 1031 Answers
SOURCE: Bosch maxx 7 condenser dryer not working after power surge
Most likely, the surge blew the internal fuse. I would try replacing that first. If you can't do it personally, have a certified tech do it for you.
Posted on May 08, 2012
Bosch 500 series new dryer has locked up. Key showing on panel, door opens, but you press every button and get the same beep.
Hi dear.
Regarding your information, I would say Child lock has been activated. I do not know what model or serial number of your dryer but you need to refer your machine's user manual or contact Bosch for deactivate child lock. I hope that helps. Thanks.
Jan 22, 2016 | Bosch Vision 500 Series Front-Load Washing...
Hear beeping sound maxx 7 varioperfect bosch
can you see a key sign if so you need to remove the child lock
Feb 04, 2014 | Washing Machines
Child safety lock feature is on. how do you take it off
im not sure if your model of dryer but here is some instructions
Child lock
When activated, the child lock prevents the dryer from being operated by locking the control panel functions.
The dryer can be turned on but not started. The "Child lock" indicator will flash.
The door can be opened.
To activate the child lock
1. Make sure the dryer is turned off and
the door is closed.
2. Press and hold the "Anti-crease" and "DRYNESS" buttons at the same time, hold until step 5.
3. Turn on the dryer with the "On/Off" button.
4. Press the "OPTIONS" button 3 times. 5. Release the "Anti-crease" and
"DRYNESS" buttons.
The "Child lock" indicator will flash and the dryer is now locked.
6. Turn off the dryer using the "On/Off" button.
To deactivate the child lock Repeat steps 1. to 5.
The "Child lock" indicator will go out. The control panel is now unlocked.
Dec 15, 2012 | Bosch Washing Machines
My dryer Bosch maxx 7 doesn't work
That is a bad motor. It is overheating and the overload is shutting it down. Check to see if there is lint buildup on the motor. If not, you will need a new motor.
Nov 04, 2012 | Dryers
Bosch maxx advantage dispaly fault showing lock symbol
use your book to show to undo the child lock
Jan 21, 2012 | Bosch Washing Machines
Washing machine bosch maxx 7 varioperfect
Sounds like have inadvertently activated the child lock. To deselect you need to press and hold the start button for approx 5 secs or until the key light goes out. Hope this helps, please let me know if this works or if you need further assistance.l
Nov 23, 2011 | Bosch Washing Machines
Bosch exxcel maxx washing machine showing key
The key indicates that the child lock has been set, to deactivate it you usually have to hold the start button for approx 5 secs.
Nov 07, 2011 | Bosch Washing Machines
I have a Bosch Maxx dishwasher. It is showing a key symbol and will not do anything. The filter is not blocked
Child Lock feature has been activated - Check your manual for instructions on how to remove it, otherwise look for a small lock picture, usually accompanied with a small childs face, it will have arrows pointing towards 2 or more buttons, these buttons must be pressed and hold in for 3 - 7 seconds.
It could also be a Door Lock error, in this case it could be that the door is not closed properly, or die Door Lock is malfunctioning.
Hope it helps :-)
* If you found this solution helpful, please vote positively.
Feb 16, 2011 | Washing Machines
Cant disable child lock
The child lock on my Bosch Logixx8 washer has come on and i need to disable it
Apr 21, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch maxx dryer
The manual for our Maxx WTL6500 says to press and hold the Start/Stop button for 4 seconds. "The child safety lock can be released permanently using the Menu button." In our case that means press Menu 3 times then press Change to set the lock on or off.
HTH
Jul 02, 2008 | Bosch Axxis WTL 6307 Electric Dryer
Dryers Logo
279 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
