Whirlpool Washer does not drain and tub does not seem to be turni
When it goes into spin cycle it has a clanging sound. Replaced timer some two or three years ago..
  • nightowl264 Jan 22, 2009
    I was going to get a cartridge for the printer so my husband could read it as he worked on the washer. However I went on a local classified we have KSL .com and found a 2 year old Whirlpool Washer for $75.00 in mint condition.Wife wanted the new front loaders .We decided to buy the washer and fix the broken one in the next couple of weeks. I will let you know if this was the answer.
  • 61 Answers
Sounds like a broke drive coupling. lean the machine back look under the front you will see the motor in the center with a pump mounted on the front behind the motor is the gear case between the motor and gearcase is the drive coupling. To replace it disconect the power, remove the two clamps holding the pump on,remove the pump disconect the wiring harness to the motor now on the front of the motor there are two screws one on top and one one the bottom one the front of the motor with a 1/4 scocket romove the two screws. with a flat head screwdriver release the top clamp on the motor now the motor should tilt down and you can lift it off the coupling is on the short shaft of the motor and on the shaft of the gear case remove both may need to use a flathead screwdriver to get the one off the gearcase replace using a 1/2 deep well scocket and short extention and hammer tap them both on lightly but be sure the go all the way on put the rubber part of the coupling on the gearcase side and turn one of the fingers to 12:00 position turn one on the motor to 6:00 put motor back on the gear case bracket and put the top clamp on frist put the bottom clap back on insert screws put pump back on put pump clamps back on note you will have to turn the ootor to line the shaft up to go into the pump reconect the motor wiring harness plug machine in and test
Posted on Jan 20, 2009
Whirlpool washer does not spin
Try taking some of the wet clothes out maybe to heavy
Jan 15, 2016 | Whirlpool Washing Machines
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer will not cycle.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine makes a clanging sound during agitation/spin
Without being there to physically see what it's doing or hear the sound, I would say there's 3 possibilities. 1) drive block is slipping on basket drive / brake assembly. 2) basket drive assembly is worn where drive block seats onto it. 3) clutch slipping.
Sep 26, 2017 | Whirlpool Washing Machines
Will not spin or drain.
Sounds like the cycle timer has a defect and needs to be replaced,sometimes you can get a used one at a used appliance store. there not that hard to replace.
Feb 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer stops after agitation cycle, tub full of water. Won't drain. Will drain if advance to spin cycle. Top losder
if washer will wash drain and spin when timer is turned manually suspect timer although have known an intermittant problem with lid switch
Sep 22, 2008 | Whirlpool Washing Machines
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
