Question about iRobot Roomba 530 Robotic Vacuum
Roomba 530 The little dust brushes that rotate horizontally are not working, the other brushes below and the squeegee are working fine
    Problem Solver:
  • 8 Answers
The horizontal spinning side brush is a known failure item in those units. Chances are the side brush motor has gone bad. Check first to make sure that the motor isn't just bound up with hair or something.
Fortunately, it's easy to replace and relatively inexpensive.. See this video link on iRobot's site: http://www.irobot.com/hrd_right_rail/roomba_rr/roomba_fam/RoombaFam_rr_howitworks.html
Click on the bottom link in that video to see how to remove the bottom plate and remove that side brush motor with just 2-3 screws. New motors are available from iRobot for $15 or from places like www.RoboticVacParts.com for ~ $10 links here:
irobot:
http://store.irobot.com/product/index.jsp?productId=2822991&cp=2804606.3358508&ab=CMS_AccSuper_Roomba500_102308&parentPage=family
www.roboticvacparts.com
http://cgi.ebay.com/NEW-Roomba-500-Series-Side-Brush-Motor-510-530-550-560_W0QQitemZ270399677877QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef513a5b5&_trksid=p4634.c0.m14.l1262&_trkparms=|301%3A1|293%3A1|294%3A30
Posted on Jun 20, 2009
Why does robot roomba 530 repeatedly stop and say to clean brushes
I think it's telling you to flip it over, open up the brush compartment, take the brushes out, remove everything wrapped around them, replace them and close it up. I suspect that your brushes are wrapped up with something.
Next open up the filter compartment, dump it into the trash, pop or slide out the filter and bang it into the trash can. Give it a quick rinse in the sink to wash off the fine dust still on the filter. Let it dry and insert it back into the filter compartment.
May 16, 2014 | iRobot Roomba 530 Robotic Vacuum
My Roomba brushes are not rotating!
Is the yellow plastic bearing in and turning freely - or is there hair caught around it stopping it from moving? And is the other end of the brush (with the square peg) mounted properly?
Jan 11, 2014 | iRobot Roomba 530 Robotic Vacuum
Machine just rotates same spot in a circle
I just repaired my 530 roomba last night. I used a sewing machine brush and cotton swabs. On the bottom of the roomba there is a face plate with four screws. Loosen each of these four screws and remove the face plate. DUST EVERY OPENING YOU CAN SEE, but do it gently. Use NO chemicals. Then there is the area that holds in the brush and roller cartridge. Again, loosen those four screws and remove the corner brush's screw and completely remove that little brush. Then you will carefully remove the "case" holding the brush and roller cartridge.DUST EVERY OPENING YOU CAN SEE. Wipe all the silver contact points..plates on the bottom of roomba and one inside the brush and roller cartridge. At this point, I dampened a paper towel ever so slightly with some window cleaner and wiped and dried those contact points. Then using the brush attachment on my vacuum I gently went over all areas of the body of the roomba to dislodge even more dust. Once that is done, reattach all the parts in the reverse order of how you removed them. I charged my roomba overnight and this morning she was charged and worked as if she were brand new! I hope this helps. If my solution works for you,please contact FIXYA and rate my advice.
Nov 18, 2010 | iRobot Roomba 530 Robotic Vacuum
Roomba does not fill upper tray.
brushes are not turning, you can see this if you remove dust bin and start the roomba, remove brushes clean thoroughly removing yellow end pieces as well to remove trapped hair, re inbstall brushes and turn manually about 20 turns and re try cleaning, try this a couple of times
Jul 06, 2010 | iRobot Roomba 530 Robotic Vacuum
On the white roomba 530 - does not fill big dust cup anymore
you may need to clean the ends of the roller brushes.pull both out pull off the funny looking yellow ends and clean out hair ect.
Jul 03, 2010 | iRobot Roomba 530 Robotic Vacuum
Our Roomba 530 stops after few minutes saying clean the brush ,even after brushes are cleaned.
FIrst, remove the dust bin part and the brushes. Then, there are four screws on the bottom gray panel which have to be removed first in order to get to the gears which hold the brushes. I did not remove the little sweeper brush on the front, but I just slide it through the hole in the gray panel.
Then in order to get out the orange section which actually holds the brushes, there are four screws which must be removed. The orange section is attached to a blue section. This entire unit comes out by sliding it toward the area where the dust bin goes, being careful not to tear the light gray rubber gasket which covers the side.
Once that section is removed, there are two screws on each side. These screws hold the orange thing to the blue thing. Once the screws are removed, lift up only the side which has the white squares into which the brushes are inserted. These are actually the back side of little gears. There is a face plate on the outside of the orange part on this end. The other end contains a bunch of wires and I was careful not to disconnect any of them.
The face plate has six screws which must all be removed. Use caution when removing the face plate. Hold it up so that all of the stuff doesn't fall out. It has a bunch of gears, little brass looking fittings and grease. Take care to only remove the gears which have the squares which hold the brushes AND do it one at a time unless you like working jigsaw puzzles. I used tweezers and a pin to clean the "gunk" consisting of hair, fuzz, etc., out of the little gears
Mar 25, 2010 | iRobot Roomba 530 Robotic Vacuum
Red flashing light with 6 beeps
It means you need to clean the sensors. I have had this problem every now and then. There are 4 plastic clear sensors that you can clearly see when you put roomba upside down.
I have found the best and most effective way to clean them is with a dust wipe. You push the dust wipe in with a cotton swab or even a pen, and rub it around the face of the sensors cleaning the dust off, and it will work fine again.
The reason you need to use a dust wipe like a Swiffer brand is that it is very effective and will pick up all the dust. You may not see the dust and you will keep getting that red flashing error though the sensor may look clean to you.
I just had that problem, and after I used the dust cloth, it's working fine again. Good luck.
Jun 11, 2009 | iRobot Roomba 530 Robotic Vacuum
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Good Morning, My Roomba makes a banging sound and the brushes don't turn. It stops after about two minutes. Thank you & regards, Judith Halls
Hi Judith,
after removing and cleaning your Roomba's brushes & bearings (see the manual for instructions), try running the unit without the dust bin. You can watch the main brush while the Roomba runs. If it's not turning, it's time to call support.
Fembot
Feb 27, 2009 | iRobot Roomba 530 Robotic Vacuum
Problems with roomba 530
before taking apart your Roomba read this!!! First to see if it is a defect or really the brushes, take the brusehs out and run roomba with out them. If you still hear the clicking/ thumping then try taking it apart or call roomba. But if the clicking/ thumping goes away when the brushes are out you're in luck! Take the brushes. The brushes have little yellow nubs... those come out. pull them out, and you will see a lot of hair waiting for you. clean all of the hair out ( tweezers are wonderful for this). Once they are cleaned out put the yellow nubs back on. Put your brushes back in and you're Roomba will be back to business in no time!!!
Jun 06, 2008 | Roomba Robotic Floor Bagless Vacuum
iRobot Roomba 530 Robotic Vacuum Logo
577 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
