Question about Air Tools & Compressors
Bostich bt200k brad nailer: how difficult to replace driver?
My week for broken tools :(
  • juju Jan 07, 2013
    still unanswered. the driver is broken in 2. i see the expanded, doesn't look difficult to do, any thoughts?
    Problem Solver:
  • 3 Answers
If it is a real expensive brand of driver I would try and fix it. However, I have learned as a contractor that sometimes you can save money
in the long run by simply buying a replacement. The price has dropped quite a bit.
Posted on Jan 08, 2013
  • juju Jan 08, 2013
    yeah, ain't that the truth. but the part is cheap enough, the nailer is a great tool and work is a bit hard to come by, so i think i will try to fix it. based on what i see, i am going to give it a try, since no one has warned me not too, lol
5 Suggested Answers
  • 1388 Answers
SOURCE: Bostich framing nailer leaks air out driver hole
Generally, air leaking from the nose of the gun is caused by the vinyl headvalve/cylinder seal. It is installed on the headvalve and snugs against the cylinder. I would also check the cylinder ring supporting the cylinder that is visable when the head is removed. The cylinder ring is made of white plastic and has an oring on outside edge and seals against the cylinder with another oring. The ring tends to crack allowing air out nose. Some cylinder rings were made of metal, which is better and do not fail. Metal or plastic, check the orings there. Not to worry, these parts are not expensive and available at www.bostitch.com. enjoy
Posted on Nov 30, 2008
  • 4234 Answers
SOURCE: Bostich N80 Framing nailer
Sorry about the delayed response. This unit needs to have the O-rings replaced. The return of the firing pin is not happening correctly. This means that the pressure release holes are still engaged. When the pin pushes out the nail, the return should cause the holes to get covered. If there is an air leak, the return will not complete resulting in an even larger air leak which is what you are now seeing. This is a relatively simple repair for any shop that handles these and would be considered a standard maintenance effort. These are decent tools and with proper maintenance will last for years. Mine is over 22years old and going string.
Dan
Posted on Feb 11, 2009
  • 7 Answers
SOURCE: constant air leak
Sounds like you need a repair kit or take to a tool company that installs the kit.
Posted on Jun 10, 2009
comax
  • 154 Answers
SOURCE: Firing Pin doesn't return
The piston is returned to its firing position by air from the trigger valve after the piston has fired. It relys on the piston sealing against the bumper at the bottom of its stroke, if the bumper was damaged when the driver shattered or it was put in upside down the piston will not return. Also the piston uses air fed into the return chamber from the little holes in the cylinder, if the seal over these holes is damaged the piston may not return. Basically change the bumper and the check seal on the cylinder.
Posted on Aug 05, 2009
Nailer is shooting air out of trigger, is not releasing brad
Sounds like the head valve. Remove the head cap take out the head valve, clean, re-fit and give it a few drops of air line oil. Then give it a try. Good luck.
Oct 19, 2014 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Bostich framing nailer won't reset. If I release air pressure it resets.
The new Stanley guns are a pain in the ***! I you don't oil them twice a day the rings get sticky,also if you don't use the regulator on the compressor for different nails it will over fire.If your pin isn't sticking then you need to return/contact Stanley cause their product along with the brad guns seem to be having problems!
Oct 22, 2010 | Stanley Bostitch BT200K
Hello My PC 18ga brad nailer its piston wont retr...
Check the regulator gauge on your air compressor to make sure you have enough air pressure going to your nailer. After replacing my nailer because the driver wouldn't retract, I discovered, when the replacement nailer had the same problem, that I had somehow turned the regulator and decreased the pressure. Now I have two fully operational nailers.
May 20, 2010 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
BN200A porter cable brad nailer. have tried
check for a broken driver blade, also make sure of the proper nail guage for the tool. Let me know if this is not the case and I will find you a breakdown for the tool for further inspection.
Nov 06, 2009 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Bostich angle trim nailer sometimes the ram or nailer will not go back up and I have to open it and manually put it back up with screw driver
sounds dirty to me...open the nose and spray WD40 in and around the nose, as well as the track....also, check if that model needs oil, because that can also cause the problem. All in all, it is a lubrication issue
Jul 15, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
May 20, 2009 | Stanley Bostitch BT200K
My gun fires 2 2in brads at the same time. Is there a fix for this?
most likly using wrong gauge brads check on gun for gauge size example 16mm 18mm ect.
May 10, 2009 | Stanley Bostitch BT200K
Bostich gun problem
If the piston/driver is broken, the gun will fire however nailing will not take place because the piston will jam in the cylinder. Sometimes the cylinder will also crack when the driver goes. If the piston is not broken but stays down, then check the cylinder check valve, worn lower bumper, bent driver or cracked cylinder. 18 guage nailer has a very thin driver which will easily bend or break. Parts however are not expensive.
Nov 18, 2008 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Nails won't shoot
18 guage nailer has a very thin driver and plastic cylinder which bends or breaks easily. Remove the head noting all the parts in the head and remove the piston which should be at the top of the cylinder. Check for broken or bent shaft. Most likely broken and jammed in cylinder. Parts are not expensive. Check WWW.toolpartsdirect.com for diagram and parts
Nov 17, 2008 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Stanley Bostitch n59fn
Very nice tool indeed. I have had mine since they first released it to the public but I have never had any problems with either size brads. Have you ever dropped the fastener? Check your rail for bends as it may cause the longer brads to be binding. If there are no bends, detach the rail and look to see if there is debris within the rail preventing a 2" length from advancing that would not otherwise affect the 1.5". If none of this seems to be the problem, return the brads to the store for replacement as the defect may be within the brads themself. Hope this is helpful.
Sep 28, 2008 | Stanley Bostitch BT200K
Air Tools & Compressors Logo
24 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
