Question about Grohe Freehander Adjustable Shower Head System Chrome
Grohe Freehander Won't Stay Up
My contractor installed the Grohe Freehander showerhead for us. About a year and a half later I was using the showerhead one day and decided to put it down for second to clean the bottom part of the shower and then realized the showerhead won't stay up on its own now. I think a screwed is loose somewhere and needs tightened but when I take apart either of the round, external nuts on the outside I can't make heads or tails of how to tighten anything. Anyone have any suggestions?
3 Suggested Answers
  • 21 Answers
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Posted on Dec 03, 2009
  • 32 Answers
SOURCE: how to clean a grohe freehander shower head?
soak in white vinager
Posted on Dec 11, 2010
I can't get shower head pressure from the outer head of my new grohe freehander.
Everything you installed new. Please chack if not one of the gaskets came in a pipe or a line. I once had a rubber ring almost complete blocking the water flow.
Nov 01, 2014 | Grohe Shower Freehander 27 007 Chrome...
Can you locate the 27.007(27.006) in satin nickel
Why not refer this issue to Grohe? You can do some research to determine whether a competitor offers something equivalent.
Nov 17, 2013 | Grohe Shower Freehander 27 007 AVO Satin...
Ladylux handal can not be removed afert taking screw off
Could not find information for your exact model; however these specifcation which include diagrams of your faucet and installation and maintenance instructions should be useful. See here:
http://www.groheamerica.com/lib/1/tpi/1311703.pdf
Go to Page 5 and look under Maintenance for intruction on how to remove the handle and replace the cartridge.
Feb 14, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
My contractor installed a 4 port diverter. The hot and cold are ok, but when I turn the shower on, the flow starts in the hand held shower head and not the main shower head. According to Grohe, whichever...
I haven't had a lot of experience with Grohe brand but have had twenty eight years as plumber, 22 years as master plumber and the bottom port of every tub or tub/shower valve that I installed used the bottom as main supply port. As far as the instructions from manufacture like I said I have not used that particular brand much,so I really couldn't say. Hope this helps some. Thanks
Nov 10, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
I have a Grohe Freehander. One of the shower heads has hardly any water coming out. The other shower head has good water pressure. I have sprayed CLR on the shower head but it doesn't appear to have...
Try soaking it in vinegar...this will help break some things that CLR will not. Soak it for five minutes, then rinse, and try again. It will help a lot...rate if it helps!
Oct 05, 2010 | Home
Freehander leaks at shower heads
Hi
Thank you for your query
If you just grab the showerhead with one hand and then unscrew anticlockwise the pipe underneath it should just screw off, once this has been done simply replace the O ring and rescrew
I hope this has been useful
Mar 14, 2010 | Grohe 27.007 FreeHander Shower Head Shower...
Hi there, I have a 27007 Freehander that was just installed by a plumber. When I turned it on to test, the right hand side of the swing arm, pulled away from the mounting assembley, and water shot up...
Without being ther and seeing I ofcourse can't be sure but based on what you have told me I would lean towards defect. There is no such thing as perfection in any assembly line. It's not ever easy to block water under pressure from coming from a place it was not designed to come from
Feb 08, 2010 | Grohe 27007000 Chrome Freehander...
Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Jan 20, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe Freehander Adjustable Shower Head System Chrome Logo
168 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
