Question about Dyson DC39 Animal Canister Vacuum
My Power head on my Dyson Animal DC39 will not stay spinning. Suction Issue?
When pushing the button to turn on the brushes on my power head, the brushes will not get spinning, but if I hold the button in a 'sweet' spot I can get them to rev up. Then it seems to rev to high, then all of a sudden stop. Is there an issue with the power head? Please Help... My Dyson only a month old and I want to love it
There should be a red insert on the right-hand side on the cylindrical bulge behind the brush cylinder. Check that this is moving when you push the button. The red insert should stay pushed in for the brush to rotate. The insert moves in an out as well as rotates in order to lock in the 'in' position. Mine is a little sticky on the rotation and I need to shake the brush head a little in order to get it to rotate and lock.
Posted on Apr 13, 2013
    New Friend:
I had the same problem and fixed it by dismantling the brush and removing the small piece of transparent tubing. It works fine now and the only downside is I now have to keep my thumb pressed on the button if I need it to stop spinning (which I can live with rather than splashing out £60 for a new brush.)
Posted on Mar 03, 2016
Brush bar doesn't spin on dyson on dc39
Hi there, it's Jack at Dyson.
DC39's Trigger head floor tool is powered by a turbine, driven by your vacuum's suction. Following these simple checks should help you resolve any issues which could be preventing the brush bar from rotating as normal: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/trigger-head-not-working/dc39-check-the-brushbar/dc39-check-triggerhead-tool
If you'd like further help from our experts after giving this a try, please get in touch with us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a replacement part is needed, we can also confirm if this is covered under your Dyson parts and labour guarantee.
Feb 24, 2015 | Dyson DC39 Animal Canister Vacuum
Get the brush bar to spin again on my dc39 vac
The rotating brush bar inside DC39's Triggerhead floor tool should rotate when the vacuum is running, unless you turn it off using the button on the wand handle. If it's not rotating, our Support guide will walk you through the checks needed to resolve this: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/trigger-head-not-working/dc39-check-the-brushbar
In the unusual event that these checks don't resolve the issue, please contact our experts directly so we can help you further. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 13, 2015 | Dyson Vacuums
The turbine head of my DC39 stopped working. The suction is super, took the brush out and disconnected the hose and looked into it, no blockage is visible looking. ideas?
hi russ, it's jack at dyson.
i'm sorry to hear you're having difficulty with your dc39's triggerhead floor tool. i appreciate you've already checked for a blockage, but you may want to follow the steps shown in our online support guide just to make sure there's nothing you've missed: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/dc39-check-extension-tube
if you find there's no improvement after running through these checks we're happy to help further - and if a replacement is needed, we can confirm if this is covered under your dyson warranty. you can reach our experts directly by calling on 0800 298 0298 (uk), 1-866-693-9766 (us), 1-877-397-6622 (ca) or 1800 239 766 (au).
Jan 20, 2015 | Dyson DC39 Animal Canister Vacuum
Why does my Dyson Dc-39 vacuum have good suction, but the beater bar barley turns?
The beater bar may be clogged with pet hair and other debris. You may have to do some disassembly to get everything working again.
Dec 18, 2014 | Dyson DC39 Animal Canister Vacuum
Dc 39 canister carpet brush will not turn
on the head there is a round filter type part if that is pushed in the the brushes won't turn. try pulling it out slightly.
Apr 07, 2014 | Dyson DC39 Animal canister vacuum cleaner
WHEN EVER I PLACE THE SPINNER ON THE VACUUM IT STOPS SPINNING
Hi Linda,
I am sorry to hear you are having difficulty with your DC39 brush bar. The brush bar on your machine is air driven. Generally, if the brush bar stops rotating it is due to an obstruction that is preventing air flow. Please visit the appropriate link below for step by step instructions on locating and removing a blockage from your machine.
US:
http://www.dyson.com/support/dc39/dc39-animal/diagnosis-root-menu/performance-flo-extension-tube-suction-check-dc39
UK:
http://www.dyson.co.uk/support/dc39/dc39-multi-floor/machine-is-not-working/dc39-check-extension-tube
We also recommend inspecting the brush bar to ensure it is free of any debris and washing your filters. If for any reason the recommended trouble shooting does not fully resolve the problem please contact our Helpline to speak with an expert.
US - 1-866-693-9766 or UK - 0800 298 0298
Best wishes,
Jessica
Dec 15, 2013 | Dyson DC39 Animal Vacuum
Brush keeps shutting off . DC39 Animal Canister.
The belt that turns the rotating brush is loose. Make sure it is on correctly or replace with a (new) tighter belt. This will require you to unscrew a few screws on the bottom & remove the cover. Then remove the roller.
Nov 06, 2013 | Dyson DC39 Animal Ball Canister Vacuum New...
Turbo head on DC39 animal will not spin. I have removed any hair etc caught around the brush but still no spinning..
I have the same problem with my DC39 Animal's brush bar. Im on my 3rd one in 9 months of ownership. The DC39 brush bar is driven pneumatically (there is no electric motor in the brush head) and switched on and off via a suction activated pneumatic ratchet within the brush head. The moving components are actuated by bellows. Ive found that the glue holding the bellows fails stopping the ratchet working intermittently at first and then completely as the bellows comes away completely. At first you can help the ratchet by tapping the brush head - the red ratchet ring can be seen to click round. This, in my opinion, is an inherent weakness of the DC39 design and cannot be easily repaired. The only solution is a new brush head. Luckily Ive got a 5 year warranty and at the current rate I will have got through about 20 brush heads !
Mar 31, 2013 | Dyson DC39 Animal Canister Vacuum
Dyson DC39 Animal Canister Vacuum Logo
9,804 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
