Question about Sanyo Televison & Video
I have a sanyo tv which is toggling between blue, red green repeatedly. Can you point me in the right direction.
Model number: CE32LDD3-B Main board number: 17MB12-3.
Benimur
  • 6966 Answers
SOURCE: Sanyo 42
Hi again,
Sorry bout the Live Session.
May I suggest something?
Pls try another signal source other than the indoor antenna such as a DVD or even an old VCR.
It is possible that what you are experiencing is video muting due to dirty antenna signal. If even with a stable known to be good video source (DVD) the problem persist, then it is a matter of checking the voltages as indicated in your service manual.
Hope this be of some help/idea even if the chat did not work out. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 02, 2008
SOURCE: Replacing the Y-MAIN or Y-SUSTAIN Board in Philips 42PF9630A/#&
I called PTS 1-800-844-7871 they told me it was an easy fix. The part is $162.75. Im gonna try it.
Posted on Aug 16, 2008
  • 6 Answers
SOURCE: Tatung wont turn on
I have v30dmtt 29 inch tatung and had the same problem. I took the power supply out and took it to repair man. He told me it couldnt be fixed. I contacted the manufacturer and had a new one sent. The phone # is 915-771-7554 but you need to call 1-888-482-8864 to get a case #. It costs 70.00 for a new power supply unit.The part # I needed was 6693006610. I hope this helps.
Posted on Oct 21, 2008
  • 157 Answers
SOURCE: TV green lite comes on for 2 seconds--goes back to
you posted the model number in reverse-----32pf double check-only thing i found so far -------replace c601 470/25v
someone else found a bad FET did u check them
do u have a pdf of this one
Posted on Sep 16, 2009
SOURCE: ysus board number for a sanyo 50'' plasma model dp50747
I just bought a Sanyo DP50747 50 inch plasma. When I pause the tv, then push play (even 1 minute or less) the sound does not start as soon as the picture starts back. I have picture first and no sound for 4 or 5 seconds then the sound continues from that point.
Posted on Mar 21, 2011
My Sony KP-53V85 I have a really light "redish burn-in" image that looks like widescreen format. Perhaps a 16:9 DVD that burn-in at one point in his life. I want to bring this TV set back to its glory days...
sanyo still make the parts but you need the old numbers to find them from sanyo. they should be the same as sony made as at the time they used the same parts just changed the part numbers over, sanyo use them in billboard displays so you would need the right size.
Jul 27, 2017 | Sony Televison & Video
Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
  1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  2. Enter the menu on your TV. Use the remote control and bring up the menu.
  3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  5. Press "Enter." A crosshair pattern will appear on your screen.
  6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  9. Repeat these steps for all colors.
Take care
Jul 06, 2010 | Televison & Video
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
RED Convergence Alignment issue
Replace both STK392-110 Convergence IC's with Toshiba or Sanyo quality................No cheap IC's !!!......................T.
Aug 16, 2008 | Toshiba 43H71 43" Rear Projection...
CONVERGENCE PROBLEM IN TOSHIBA 43H70
Replace both STK392-110 convergence IC's with Toshiba or Sanyo brand........no cheap junk IC's !!!.................T.
HD tv with the mitsu
Well if your refering to the right tv (check your model number) then this tv only supports 480i, 480p and 1080i. Ive never seen anywhere that it supports 720i.
The component wires should include three lines for each corresponding color, red green and blue, and finally white and red for left and right audio. I think that is what your refering to.
If everything is right, it should work, the fact your seeing green could be a number of issues... maybe its a direct tv box issue?
Apr 03, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
Televison & Video Logo
52 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
