Question about Honeywell Home Security
Brand new door contacts on my wired alarm system not working properly
When I open the door it does not break the contact and sound the alarm what could be the problem? it's accentia/optima G4 LCD model
  • Maurice O'Shuaghnessy Jan 05, 2013
    btw it's the entry and exit contacts
    New Friend:
1. Make sure you have a (EOL) resitor on the curcuit, it should be at the switch, but you can cheet and have it at the panel, but if your wire would ever get damaged you would not know about it 2. If you had to hammer in the switch it could have damaged the switch to a closed state and wont open when the door opens, the switch should just be pushed in not hammered 3.If the switch is installed to close to a magnet wheather stripe, that will hold the switch close 4. If it is a steel door and steel frame, and the switch is a surface switch with screw terminals, you could have some stray wires shorting to the steel frame 5. make sure your magnet is lined up with the switch
Posted on Jan 06, 2013
2 Suggested Answers
SOURCE: PIR Intruder alarm magnetic contact
Hi Bowdi,
Please find the below the information on the contacts.
You will fine two silver screws - This is your Alarm pair and this will go back to the alarm zone on the panel PCB.
The three other brass screws are just junction screws so you can join the cables to go to other doors.
You will need to join the black and blue together to make the tamper circuit.
Regards will
Posted on Sep 06, 2009
How do i stop the aslarm system from going off each time i open the door
Start by cleaning the door contacts - push em in and out by hand 50 times or if metal type clean with emery paper
Could be any one of the contacts or a bad earth - factory fit alarm or aftermarket? Sounds like an auto electricians job or an alarm installer if the simple stuff doesn't work
Feb 03, 2015 | 2002 Honda Accord
Keyless entry remote doesn't open doors anymore on my 05 ford focus
Sounds like the contacts in the buttons are not making contact.. you may want to try taking the remote apart and cleaning the contacts and seeing what happens. If the remote is truely dead you may need a new remote
Feb 01, 2015 | Ford Cars & Trucks
Door light symbol stays on dash panel what is problem
door is partially open or switch on a door is out of position.
takes 2 people but goes fast. open each door and manually
push the switch open to break contact and stop the circuit from
working.
Feb 12, 2013 | Chevrolet Cars & Trucks
Interior car alarm wont stop
It can be any of the car doors not got properly locked or the door is locked but the switch is not sensing the door locked. Open and close each door again properly.
Or else its problem with any of switch wiring getting in contact with alarm wiring causing it to happen.
And last thing alarm connections need to be inspected. It's getting short somewhere in between.
There is a help link with solutions, to troubleshoot these types of problems. I suggest going through these link.
Click the link below: ------
CAR ALARM ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/factory-alarmsecurity-system-alarmcar.html
These will help.
Thanks.
Dec 09, 2012 | Nissan Cars & Trucks
Stop sign lights up alarm sound when turning on ignition
CAR ALARM ISSUES
These will help.
Thanks.
Dec 09, 2012 | Cars & Trucks
Security system malfunction
CAR ALARM ISSUES
Dec 09, 2012 | 2001 Chevrolet Venture
My security light came on ,on my 2003 Chevy 2500HD truck causing the truck not to start. Does anyone know how to reset the alarm for it to go off?
To troubleshoot these types of problems. I suggest going through these link.
These will help.
Thanks.
Dec 06, 2012 | Cars & Trucks
What is an open zone?
An open zone means that a door or window is not completly shut and properly aligning the contacts or sensors. If you know what zone it is open and shut the door/window check the contact and make sure it is making a complete connection-closing the zone. You can bypass the zone and arm the rest of the system, if you can tell me your brand of alarm, I could tell you how to bypass.
Nov 20, 2010 | Mace 80357 Motion Sensor
its a long time since i worked on these but its quite easy you want the 2 terminals that make a circuit when the magnet is placed by the switch and breaks the circuit when the magnet is removed.hope this helps
les from new zealand (ex uk)
Dec 08, 2008 | Honeywell Home Security
Home Security Logo
211 people viewed this question
Top Honeywell Home Security Experts
Sean
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
