Symbol on my 32 inch cello television with a built in dvd player and built in freeview the symbol is a video camera with the numbers written like this 1/2 and when you press 2 it changes the scene of the dvd, i cant remove it
techman
  • 3130 Answers
SOURCE: Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Posted on Oct 16, 2006
SOURCE: Cello Lcd Tv Combo TP-1907D Stuck In S/by.
for Cello tv service try www.contrast-uk.net for uk service (may be some help) !!
Posted on Mar 25, 2008
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Posted on Apr 05, 2008
Agent Dort
  • 216 Answers
SOURCE: Dynex 32 inch LCD television - Cant remove subtitles
Greetings jcsfo,
Here is a link to a page with the manual for your television. I hope this helps.
http://www.dynexproducts.com/pc-590-23-dynex-32-flat-panel-lcd-hdtv.aspx
Thank you,
Dorothy
Go Ahead. Use Us.
Posted on May 05, 2008
  • 21 Answers
SOURCE: input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Posted on Jul 26, 2008
Veon tv manual
The eject button on the remote appears as an upward-pointing arrow with an underline - see below image. The eject button on the TV has a similar symbol.
However, I suspect that in your case, you might not be having a Remote.
This link says that your TV doesn't come with a Remote and DVD cannot be ejected without the remote :
VEON 19 LED TV DVD FREEVIEW COMBO A1823511 1
Jun 28, 2014 | Televison & Video
I've lost the manual for my 32
There are plenty of free operation manual downloads. Please search in Google.
Aug 05, 2012 | Televison & Video
Is the integral Freeview on my 32 inch Full HD TV HD or Not
Simple answer. No. But please read on . . .
Full HD Freeview, i.e 1080p does not exist. The four HD channels currently available on Freeview all transmit at 720p resolution. There is insufficient bandwidth in the TV transmission range for the HD channels to transmit at 1080p. It could be done, but it would be at the expense of other channels.
Your TV, however, is Full HD, as indicated by the 1080p in the specifications. This means it can display a full HD picture from a device which outputs at 1080p resolution. Devices which generally output at 1080p resolution include Blu-ray DVD players, games systems and PCs.
When viewing a Freeview HD channel, your TV will display the picture in 1080i (interlace) resolution. This is not true/full HD. The transmitted picture comprises of 720 horizontal lines and the software inside the TV is creating the additional 360 lines and interlacing them between the 720 lines from the original transmission in order to create a 1080 line picture which fills the entire screen.This process is commonly known as 'upscaling' and can cause deterioration in the overall picture quality, most noticably on poor quality, cheap TVs.
Hope that explains it for you sufficiently!
Nov 10, 2011 | Televison & Video
Is freeview available on a bravia 32 inch kdl 32l 40xx television please thankyou
Hello Keith,
Yes, it has a built-in DVB-T* tuner which is what you need to tune Freeview channels. It also has an analogue tuner if required.
* Digital Video Broadcasting - Terrestrial
You can view the full specifications for this model by clicking on the link below and you can download a user manual from there if you need one.
http://www.sony.co.uk/product/t32-l-series/kdl-32l4000/tab/manualpopup?section=ODW+SS+en_GB+Support+New&externalUrl=ftp%3A%2F%2Fftp.vaio-link.com%2Fpub%2Fmanuals%2Fconsumer%2FKDL-32L40xx.pdf
If you already own this TV and are unable to receive or tune Freeview channels, please let me know and I will be able to assist you with this.
Hope this helps
Regards,
BElectric
Feb 20, 2011 | Sony Televison & Video
How do I connect a samsung c555 home cinema system to a LG 42LD450 42 inch tv so that i can get sound out the built in freeview? also cant seem to get sound out my PS3? I have connected the video output...
Use an optical cable from ps3 to surround sound and hdmi from ps3 to tv.... But I can't get my samsung surround sound to come out of the tv with built in freeview either. Just wondering if you figured it out. Cheers
Nov 14, 2010 | Samsung Audio Players & Recorders
Teac 32 inch LCD dvd combo, dvd is coming up with message "no signal" any ideas?
Usually means just that.
The input source you have switched to has no signal.
Does it have built in freeview? just plugging an ariel off the roof no longer works without a digital receiver.
Jul 11, 2010 | Teac (DW-224E) DVD Drive
Bush TV with built in freeview. How to retune without technical manual?
i have a cello c2751f tv dvd combo i need a code to use my sky tv
Sep 30, 2009 | Bush Televison & Video
Recording Problems
Hi.
Yes.
Most tv sets with freeview built in do not allow you to record it.
Check your tv instruction manual to see if it is at all possible.
http://dysonmanuals.llc.nu/
Chris..
Feb 09, 2008 | Televison & Video
Nov 23, 2007 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
