Question about LG VX8300 Cellular Phone
My phone displays a white main screen
My phone has a blank white main screen and i don't know why the front screen still has everything on it but the main screen is white i have only had my phone for about a month and have not had a problem with it until now what should i do and how can i fix it?
  • 24 more comments
  • elmerk Nov 15, 2007
    The inside screen on my LG 8300 is all white. The only way to make it go away is to use the over-the-air update but it only works for 15min and goes back to white.
  • Anonymous Nov 19, 2007
    I have the same problem. I got off a phone call, closed my phone, and when I opened it the main screen was white. This has happened before and it just started working again a couple of days later. My front screen works and I am still able to make phone calls and receive phone calls, I just cannot see the main screen.
  • Anonymous Dec 07, 2007
    Yes, i am having the same issue. It seems to be sporadic as well. I did notice that you can ever so faintly see the screen (i mean really really faintly), if you look at it from the very top of it, downward. It is nearly unreadable, though.
  • Anonymous Dec 23, 2007
    main screen turned white
  • kram19 Jan 28, 2008
    i have the same problem with my phone i used it the other day and after a phone call i flipped it open again and the main screen was white on the side and eventually the entire screen went white..please help i hate the thought of switching phones and paying way more for a another phone...more than they are worth
    if anyone knows how to fix this please email me.
  • Anonymous Jan 29, 2008
    If your phone is still under warranty, take it back to your service provider. They replaced my phone at no charge.
  • Anonymous Feb 03, 2008
    If you open/close it a couple times does it go back to normal? That's what mine is doing now, but thought maybe it was only beginning to go bad.
  • Anonymous Mar 23, 2008
    SAME
  • Anonymous Jun 30, 2008
    I have the same problem: white main screen, front screen operates normally.
  • Anonymous Jul 25, 2008
    i have the same problem. i can still make phone calls and on the front i can see that i'm still getting text meassages.
  • bsford47 Aug 25, 2008
    My LG Chocolate has a white screen when turned on
  • Anonymous Sep 01, 2008
    white screen
  • Anonymous Sep 06, 2008
    my i phone screen becomes white and blank,its only 15 days old..how can i fix it?
  • Anonymous Nov 28, 2008
    If the screen is white. how do you do *228
  • Anonymous Jan 20, 2009
    I tried putting in *228 but it still doesn't work. Idk what to do :(
  • Anonymous Jan 30, 2009
    I turned on my phone and while the front screen works and i can dial and receive calls, the main screen is just white.  I have tried *228 a couple of times now and nothing is working.
  • Anonymous Feb 05, 2009
    the same thing happened to my madres fone. and now i dont know what to do!!
    H E L P ;]
  • Anonymous Feb 22, 2009
    i have the same problem i need to fix !
  • Anonymous Feb 28, 2009
    i have the same problem i hooked it up to charge it and came back an hour later and the main screen was white i tried *228 and it didnt do a thing. Any help?
  • IloveChris Mar 05, 2009
    I threw my phone and the screen is white. The outside screen is blue then som3times makes a funky color. Can I fix it?
  • Anonymous Mar 13, 2009
    Same problem
  • Anonymous Mar 30, 2009
    i turn on my lg choclate and the screen is white
  • Anonymous Apr 24, 2009
    same here
  • Anonymous May 01, 2009
    i have the same problem, i only had it for eight hours and i turned it on and the screen was white, it was in the bottom of my bag and nobody had touched it, help me find a soloution, please.
  • Anonymous May 20, 2009
    my screen is white
  • mario_malaka Nov 03, 2009
    my phone is fucked and wont turn on =]
My Solution: Heat it up by just sitting on it or holding it in your hands// Take the battery out and back in/ Try keeping the battery out of it for a full day
My Story :) My mom dropped the phone in the dishes because she was drunk haha, I quickly took out the battery, but when the next day came by I looked at the phone and saw the same problem everyone here has. I kept replacing the battery on the hope it would just magically fix itself. Now 2 days from when it dropped in water, I kept flipping it, replaced the battery again (just taking it out and back in) after I sat on it a while, possibly the heat somehow helped it to work again.. I'm amazed it works haha, it was in the water fully submerged for half a min when I had to snatch it out of the dishes But, it is most likely that I took the battery out, the battery is the thing that ruins electronics, just remember to take it out if you drop it in water. Good luck. If worst comes to worst and your going to buy a new phone, maybe try using a blow dryer on it for a little bit **or just do this in the first place**
Posted on May 06, 2009
*228
Posted on Dec 11, 2007
Hey everyone i had the same problem
*228 works and its quick. it programs your phone and restarts it.
good luck
Posted on Oct 10, 2008
  • 1 more comment
  • justinluong2 Mar 04, 2011
    does it erase your contacts and such?
  • buddy_dinga
    buddy_dinga Sep 18, 2012
    do you call that number or just dial it?
  • jessicaheck3
    jessicaheck3 Oct 16, 2012
    this didnt help D:
Same problem! white main screen. someone stepped on it and now it doesnt work. can still get calls and texts, just cant see anything! someone figure this out!
Posted on Dec 25, 2009
Same problem, my front lcd went black first about a week before, then my front screen went white, rebooted the phone worked for 15 minutes, then went back to white
Posted on Jan 28, 2008
HELP me please i got it yesterday from tesco for 40 quid and the screens just white?! all ov sudden PLEASE HELP ME IM TRYIN TO ADD MY FRIENDS BUT LIKE ITS HARD BECAUSE I CANT HARDLEY SEE IT x<!-- from fixya rte -->
Posted on Aug 11, 2010
OMFG. same question as above. DOES ANYONE KNOW HOW TO ACTUALY FIX THIS?
ANYONE?
its rly urgent.
Posted on Sep 19, 2008
HERE IS A TEMPORARY FIX? SORT OF? SO I have an LG vx5500 and I had the white screen on the main screen but the outside display was still normal. I read all of these posts and tried taking the battery out with the power on and then replacing it after a couple minutes. That didn't seem to work so while the power was on I typed the *228 and hit send. Then I told the verizon robot lady to program my phone. She did and after the call was over the phone was the same. I held the 1 button down which does the automatic voice mail call to see if I could still access my voice mail. I could and was listening to and saving/deleting voice mail messages when all of a sudden the screen was visible and working again. I ended the voice mail call and the screen still worked. I don't know which step in this sequence was the working one but this worked momentarily. Then when I closed the phone and opened it again- the white screen was back. I tried the sequence again and it worked again but it is a temporary fix because the white screen comes back after the phone is closed and reopened.
Posted on Jun 10, 2012
I threw my phone too. the frunt scree doesnt work and the main if white
Posted on Sep 23, 2008
I threw my phone, then it was just pure white. Is there a way to fix my phone?
Posted on Sep 03, 2008
2 Suggested Answers
bdouglas
  • 290 Answers
SOURCE: my phone displays a white main screen
If it was run over probably the LCD is damaged even if not visible take it to a repair center for that manufacturer
Posted on Jan 07, 2009
My LG phone screen will not react to touch
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Good luck.
Jan 12, 2012 | LG GT540 Cell Phone
My problem is my inside screen went blank white. About a week ago the inside screen started to do weird stuff like one day it had multi colored snow. The next it went blank. The next it looked like liquid...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Oct 05, 2010 | Motorola Mobility E815
Take care.
Blank screen
Good luck.
Jun 24, 2010 | Motorola Mobility RAZR V3
Sony erricson f305 mic problem and G502 blank display problem and k810i blank display problem show me the details with circuit pcb diagram and solve my problem.
first mobile was ok. problem was display white light. i changed the strip .now no white light and front keypad light .i changed the display,main strip also but of no use .pls suggest something
May 15, 2010 | Sony Ericsson F305 White +512MB Unlocked...
Display problem
try reformatting it.
May 05, 2009 | Sony Ericsson K750
Samsung G600 mobile phone blank screen
sgh d880 screen is totally blank & everything is ok widout screen. everything is ok when connected to tv output, the screen is displayed on tv bt it is white on phone plz solve my problem.
Apr 10, 2009 | Samsung SGH-G600 Cellular Phone
Jan 06, 2009 | Cell Phones
Blank or White screen on new Motorola Krzr k1 cell phone
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
It turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Jul 16, 2008 | Nokia 6133 Cellular Phone
LG VX8300 Cellular Phone Logo
12,655 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
George Etukudo
George Etukudo
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
