Question about Diehard Gold Portable Power 950 with Jump-Starter - DC & USB Power
Need manual for Diehard Gold - Diehard Gold Portable Power 950 with Jump-Starter - DC & USB Power
What could be the problem?
I had a Wal-Mart version that did the same thing. Turned out to be a bad battery after all. You should be able to replace the battery.
May 03, 2014 | Diehard Gold Portable Power 950 with...
Do I have a negative battery system or positive battery system?
If you have a 12volt standard electrical system in your vehicle.
It is both positive and negative. The travel inverter converts this 12 volt DC current into 110v 60hz AC current so you can plug in your electronics that require standard household current to charge/operate.
There is a built in USB port if you device will accept this for 12 volt power. It also has the power oultet with ground for 110v 6hz power.
Link below has a good picture and description. Hope this helps!
http://www.sears.com/diehard-120-watt-ultra-slim-travel-inverter-with/p-02871520000P
Dec 30, 2013 | Sears DieHard 120Watt Ultraslim Travel...
Want to buy a new battery for 2000volvoS80, what size should i buy?
Research your factory battery cold cranking amps usually listed on the top of your battery or compare owners manual battery spec. Wise to meet/exceed these amps with your replacement battery. ie Autozone Gold is a 1000 CCA battery in many appications. 3 year free replacement etc...compare prices at Costco, AutoZone, Interstate, sometimes the Sears Diehard, but can be limited in applications. I use the Autozone Duralast Gold, about $108. w/exchange. Don't be surprised to be able to increase the CCA by a couple hundred over the factory battery...this is a good thing:) Hope this helps.
Jan 21, 2013 | 2000 Volvo S80
My 2003 Honda Pilot has been having starting problems the past several months. When I put the ingition key in and try to start the vehicle, the meters go wild and start vibrating. I jump start the vehicle...
to get this out of the way you can get the code from the manufacturer. Contacting Honda at there website is the quickest way. Business hours are Monday through Friday, 6:00 a.m. to 5:00 p.m., Pacific Time, or try this page here https://radio-navicode.honda.com/
Their Twitter: @HondaCustSvc
By Phone toll-free number: 1-800-999-1009
outside the US:
Honda Canada Customer Service
(888) 946-6329 Honda Motor Europe LTD. TOLL-FREE
01753 590590 Honda de Mexico Servicio a Clientes
01 800 368 8500
Good luck, Zim1308
Jul 05, 2011 | 2003 Honda Pilot
I have a 2004 PT Cruiser Platinum series with a 2.4 liter engine, wjhat is a suitable replacement battery for this car; Sears die hard or interstate ?
Sears Diehard or Interstate would make a battery for your vehicle. Look for something with over 600 cca and you should be ok for the winter.
Diehard makes a Platinum battery, but it costs over $189.99.
Diehard Gold batteries are like $109 or so.
Walmart sells batteries that are comparable to the Diehard Gold for under $100.
However, I just bought a Platinum battery for my 1997 Cadillac Deville Limo and it seems to work alright so far and has a 4 year free replacement warranty.
In general, the more you pay, the better the battery up to the 'best' which is the Diehard Platinum.
Walmart and Interstate do not offer a battery that has as long of a warranty or as good of a design as the Platinum from Diehard which uses proprietary technology to get a better warranty than normal.
The Platinum name in the PT Cruiser has nothing to do with the Platinum name for Diehard, by the way.
Good luck on finding a suitable replacement battery for your 2004 PT Cruiser Platinum.
Nov 18, 2010 | 2004 Chrysler PT Cruiser
What's the best battery for a caddillac deville
I put a Diehard Platinum battery in mine for about $189.99 plus tax at Sears Holdings or Sears for short.
It has a 4 year free replacement warranty, the best in the business, and has higher cca's than the Gold version of the Diehard which is equivalent to the best that Walmart sells.
Good luck on buying the 'best' battery for your Cadillac.
Nov 02, 2010 | 2002 Cadillac Deville
1999 Quest Runs fine but seems to have trouble starting, longer time from the time I turn the key until it fires than it used to, and it had a little trouble turning over this evening. Had extensive...
i would go to the auto parts store and have them check your battery as it sounds like the cranking voltage is not there or not what it should be
Sep 28, 2010 | 1999 Nissan Quest
Diehard Gold Portable Power 950 with Jump-Starter - DC & USB Power Logo
Top Diehard Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Diehard Electrical Supply Expert? Answer questions, earn points and help others
