Question about Proform 400 CT Treadmill - Treadmills
Circut board trips electricty board
When i turn on tredmill it turns off electricty
    New Friend:
  • 21 Answers
Treadmills are machines with a considerable pull of electricity. Make sure you are operating on a dedicated circuit.
Most users have the machine plugged into a spare bedroom outlet ehich is either not dedicate (power source spread out to more then one outlet) or is a GFI outlet (Ground Fault Indicator).
These outlets are used so homeowners do not overload an outlet in an area where a resident will sleep and be in danger of a fore or death.
Usually in the first few pages of your owners manual it will give you the requirements for your machine.
You can run an extension cord to another room with a dedicated outlet, but the extension cord does not transmit all the power coming out of the outlet and will eventually lead to other issues, usually electrical issues within the machine.
You can use a multimeter to see what else could be the issue with your outlet, but will want to consider having an electrician put in a dedicated outlet.
Posted on Jan 05, 2013
Just replaced a bulb now have no power at all
Depending on age of home you may have a spark arrestor circut.
if you used incandescent bulb and it failed ( reason you changed ) it could have trip this circut breaker on main panel ( usually will have green toggle ). Turn breaker to full off then turn back on.
Sep 30, 2016 | Hardware & Accessories
When I press start the electricty trips ?
u HAVE A SHORT SOMEWHERE AND NEED TO CHECK UR WIRING FOR BURNED OR FRAYED AREAS.
Dec 16, 2014 | Beko Washing Machines
I have a 520m karcher high pressure cleaner when turning it on it trips the electricty therefore I cannot start
try turning the motor by hand somehow to c if u can free it then try again or possible bad capacitor??
Jan 02, 2014 | Garden
Proform 400c treadmill trips when start button pressed
Step 1:
see the video and lube deck beltg+rollers bearings.
and test again. if there are o.k . Fine
If the problem persist.time to replace the old deck board complete.
However you must sure and test the following:
Step 2:
test the input voltage motor: if there are the motor NEED repair, See my personal TIPS for motor help.
2) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the diagrams attached.
Step 3:
Jan 09, 2013 | Proform Exercise & Fitness
When you turn on the drier it trips the electricty. there is power in to the power switch but when you turn the dial it trips the fuse box. the model is TC7103W
an electrical earth leakage will cause the trip. possibly the the heating element. but the motor or wiring fault can do it. you could try disconnecting the heater if the electric stays on. then change the element.
Jul 22, 2010 | Zanussi Dryers
I have a pro form xp weight loss 620 tredmill and when I turn it on and press start the belt runs for about 1 sec. On the main board in the bottom of the tredmill there is a LED and sometimes it turns off...
Since the motor shroud is off I would like you to manually move the running belt by foot and see if that LED flickers if is does then your speed sensor is working properly. If not then the speed sensor needs to be replaced. The next thing I would be checking is the drive motor, using a fully charge drill battery, lantern battery or even a 9V battery by connecting the two leads coming off the drive motor it should move the motor at approx. 1 mph if it is moving the motor is good. then I suspect the lower board will have to be replaced.
May 17, 2010 | Exercise & Fitness
Hi my tredmill will turn on but moter wont
If elevation will work it's more than likely your motor controller. I would need to know which treadmill you have to help any futher.
Nov 15, 2009 | Exercise & Fitness
Candy cs455 m dishwasher tripping out power
if what you mean is that it trips the circut or fuse in your home then the circut that you have it pluged into is not sufficent to hold for the elctrical load that the dishwasher needs. you can do one of two things. change the circut that the dishwasher is on ( plug it into a circut that has nothing else on it or verfiy that the circut can handle a higher amperage .. if thats the case change the fuse / circut breaker to a higher amperage.
peace ... jk
Mar 19, 2008 | Dishwashers
Trip switch
is the dishwasher on its own circut breaker if so whats the size
Mar 17, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Proform 400 CT Treadmill - Treadmills Logo
152 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
