Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
No ink coming through
I have a epson sx200 and I have changed the cartridges and it is not printing only very faint yellow. I have done a nozzle check and cleaned the printheads but nothing helps!!!!
    Sergeant:
    Champion:
  • 357 Answers
Make sure the tape is removed from the cartridges.
The cartridges could be defective.
Align the printhead.
Try new cartridges from a diffrent supplyer.
Good Luck.
Posted on Feb 16, 2009
BLACK INK NOT WORKING
Black ink head clogged/cartridge empty. Go to Printer Utility and do a Nozzle Check, Print a Pattern. If Black pattern lines are missing/broken then do another cleaning. Don't forget to try a new cartridge if the cleanings do not work. Refurbished Epson printers are great and can be purchased at www.epson.com/clearance. I have used them for 15 years.
Feb 15, 2013 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Epson stylus d45 prints purple images the yellow ink wnt come out
You have done most of the required DIY but I feel that two more things can be tried out. First of all you can reinstall after removing the sofware from your PC. there after connect the C45 and try to see if the fault changes. If not we have to suspect the head and since you had tried the maintenance and head cleaning which is inbuild in this model . You will have to think of the cost of an head assembly to the cost of a new model of epson. If not try to use it printiing all your documents till the ink runs out and decide. Hope my advice helps. Good day
Jul 26, 2010 | Epson Stylus C46 InkJet Printer
Faint printing after cartridge change & head cleaning
How about nozzle check output? Is it perfect? No missing lines? Do head cleaning, wait for 30 minutes. Check nozzle again. If there are no difference betwen two output, you may need cleaning head manually.
Sep 11, 2009 | Epson Printer
Won't Print Yellow Ink
your yellow colour is used mostly please refil your colour cartridge or change your colour cartridge.
Jul 30, 2009 | Epson Stylus C44UX InkJet Printer
My Epson Stylus Color 760 printer tells me there's still ink
If your ink was installed Feb. 2007, then most probably it got expired as you said you have done test prints but with faint samples.
It is advisable to install new and genuine epson ink cartridge.
Jul 24, 2009 | Office Equipment & Supplies
Only black and blue will print on test page; yellow and magenta does not. Ink was just replaced.
Did yellow and magenta print OK before the previous cartridges ran out? If so, it looks like your new cartridges are not working properly. Try another yellow and magenta cartridge - you can re-use the previous cartridges if they turn out not to be faulty. If new cartridges don't solve the problem, you can try soaking the print head, in case you have nozzles blocked with dried ink for some reason.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta/yellow ink on the nozzle check, then there is hope! Repeat the head clean/nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
May 04, 2009 | Epson Stylus C86 InkJet Printer
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
222 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
