My Phillips TV will turn on with sound, but has no picture
  • 691 Answers
Sounds like a problem with either the power board or more likely the one of the other boards controlling the LCD. If you have some electronic skills you might be able to find replacement boards on ebay, failing that weigh up the cost of a repair guy vs a new TV
Posted on Jan 05, 2013
2 Suggested Answers
  • 541 Answers
SOURCE: Phillips LCD TV - sound but no picture
You probably have a bad inverter board or possibly power supply. Both can cause this problem.
Posted on Oct 13, 2009
Toshiba theaterwide hd
replace the lamp on your TV, but only replace it with PHILLIPS brand. Anything other than that, will not last. We just replaced ours with Phillips and the picture is much brighter. It really shows the HD quality of the tv.
Mar 24, 2014 | Televison & Video
Phillips Magnovox
Its a power supply issue the only solution is to get it repaired.Possible power outage.Repair charges would be around $400.
Goodluck,
Please don't forget to rate the solution
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
Power light but no picture or sound
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ? Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Nov 17, 2013 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 47" flatscreen sounds still
If the TV menu displays your problem is most likely not the Tv , but is caused by the signal source:
Cable box or connections. Reboot everything test using other sources like a DVD player to isolate the problem.
Aug 20, 2011 | Televison & Video
Oct 12, 2009 | Televison & Video
Phillips 47PFL3603d-f7 blinks when turned on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
May 29, 2009 | Philips 47PFL3603D LCD TV
Power light for tv turns on but no picture and no sound comes on tv i have a 50 inch phillips plasma
Check your cables and TV input settings.  Can you get to the on screen menu?  Does anything appear on the screen when the tv is on?
Dec 06, 2008 | Televison & Video
Sound but no picture 60in phillips television
I beleive you can get a chip to fix this problem from www.magnavoxhelp.com.
Aug 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
