Question about Williams-Sonoma Kitchen Appliances - Others
Do I add water to bread machine (Cuisinart) first or the bread mix first
    Sergeant:
  • 475 Answers
You at the mix first then the water.
Posted on Jan 05, 2013
SOURCE: how do i remove the
 Grasp pan handle with a potholder, press down on outrer housing,lift handle sharply releasing pan .Now who can tell me how to stop my CBK200 from burning each& every loaf?        Dave from Succasunna,N.J.
Posted on Dec 17, 2008
KMusselmann
  • 247 Answers
SOURCE: I need the dough mixing blade for my bread machine
You can get it at the following site
http://breadmakerguru.com/
Kurt
Pls rate the answer
Posted on Apr 10, 2009
  • 11 Answers
SOURCE: read from Bread Mix fell
This also happened to me. I found out that the yeast in the box was out of date! Now I just use a new packet of equivilent size in any mix I use and have solved that particular problem.
Posted on Apr 21, 2009
SOURCE: My Black & Decker B900SC bread machine doesn't mix properly
Have you tried adding a bit more water to your mix? It sounds as if your dough is too dry. Sometimes, no matter how exact you follow directions, you have to compensate for variables of the machine. I have a similar problem with some of my bread mixes if I do not add an extra tbsp or two of water.
Posted on May 16, 2009
  • 433 Answers
SOURCE: Blackndecker b2300 breadmachine
Hi, Take the pan out of the machine and see if you can turn the paddles by hand. If yes that's good...if no then paddles are sticking. Keep pan out of machine and start a kneading cycle. Look through the lid window and see if the motor shafts are turning. If no...then the belts fell off or are loose. If everything is fine then maybe it's the electronic panel. Hank
Posted on Mar 29, 2010
Cuisinart CBK-100 2-Lb. Bread Maker With Brushed Stainless Housing does not mix or knead ,but it does hum quiet;y
with your machine unplugged turn it on its side so you can get to the panel on the bottom of the machine and remove it. Is your drive belt between the two pulley wheels off, broken, or missing? Let's check that first and then for parts go to the breadmachineshelp.com website.
Dec 13, 2012 | Cuisinart CBK-100 2-lb. Bread Maker with...
Bread maker won't mix, it just clicks. I removed two screws on the bottom to see if the belt had slipped off. it was fine so I called Cuisinart to see if they could help. They said removing even one...
Some bread machines warm up before the kneading process begins especially on whole wheat cycles. If your machine hasn't started kneading after about 1/2 hour then you do have a problem but, give it time before you give up on it....
Aug 24, 2011 | Cuisinart CBK-200 Bread Maker
The dough never mixes right. it sticks to the side of the pan
It should stick to the side of the pan slightly when mixing but not excessively. This is usually caused by too much water in the mix or getting the flour quantity wrong. Try reducing the water volume slightly until the mix is right.
Jul 15, 2010 | Cuisinart CBK-200 Bread Maker
I HAVE A CUISINART DCC-790 SERIES COFFEEMAKER AND IT WON'T PUMP THE WATER THROUGH
I have the same problem. Called Cuisinart and they told me to add a mix of 50 - 50 water vinegar and let it sit for up to 3 hours. (even though it is only 3 months old) If that does not work call them back 1-800-726-0190.
Feb 13, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Mix cycle does not mix add ins evenly or thoroughly. Nuts and seeds are mostly left in bottom of pan or lumped in a few spots in the bread
Check the belt on the motor. It could be lose or has fallen off. Also check the motor to see that it turns in a kneading cycle and check to see if you can spin the paddle freely by hand. Hank
Jan 11, 2010 | Cuisinart CBK-200 Bread Maker
May 13, 2009 | Kitchen Appliances - Others
Black & Decker B2250 - Recipies
Here's a good basic white bread recipe that works great with a BD2550 (and usually doesn't even **** the mixing blade off of the bottom of the machine)
1 cup warm (not hot) water
1/3 cup milk
1 tablespoon sugar
1 teaspoon salt
1 1/4 tablespoons butter/margarine
4 cups flour
1 teaspoon yeast
Heat the water and add the milk to it. Dissolve the sugar and salt into this mix and pour the liquid into the bottom of the bread maker bucket (make sure the mixing blade is already in). Melt and add the butter to this mix. Add the 4 cups of flour directly on top, but do not mix it in. The flour will float on top of the liquid. Make a small dimple in the top of the flour in the middle with your finger and add the yeast into that little crater (at no point while adding ingredients do you let the yeast touch the liquid). Set the bread maker for basic setting 1, light crust, 2lb loaf and let it do it's thing. 3 hours later, you'll have a nice loaf of white bread with good consistency and density, and it usually leaves the mixing blade in the bucket (rather than having to dig it out of the loaf after).
Hope this helps!
Nov 03, 2008 | Black & Decker B2250 Bread Machine
Recipes Are wrong in instruction booklet
I had a similar problem when I switched machines. It seems that most recipes will work in same size machines (1 or 1.5 lb loaf size). My issue was that my old machine had to have liquids in first and then dry ingredients (new machine is the opposite). I ruined several loaves before I figured out the issue. I would have never imagined the order of ingredients would make a big difference.
Oct 16, 2008 | Black & Decker B2250 Bread Machine
Black and Decker Bread Maker B2250
Here's a good basic white bread recipe that works great with a BD2550 (and usually doesn't even **** the mixing blade into the bottom of the machine
1/3 cup milk
1 tablespoon sugar
1 teaspoon salt
4 cups flour
1 teaspoon yeast
Hope this helps!
Aug 12, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
47 people viewed this question
Top Williams-Sonoma Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Williams-Sonoma Kitchen Appliances - Other Expert? Answer questions, earn points and help others
