Question about Music
Crate bv120h weakness.
I have a Crate bv120h and I have a slight problem. It doesnt sound like it has enough power when I play it. I took off the back plate and two lights were not kicking on, so i switched some of the tubes around and the lights were still not kicking on. Any ideas what this could be?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
Bad wires or fuse or connections
Posted on Jan 06, 2013
2 Suggested Answers
  • 11 Answers
SOURCE: guitar amp no sound or lighting
Ah yes: complete catastrophe. Usually when everything is not working, it is a single reason and when that single reason is fixed, so is the amp.
Based on what you tell me, I am going to say you have a bad power tube. And I will even go as far to say that you buy a set of tubes and play on them as long as you can. If so, then you not only burned up the tube, but weakened the power section and may have a slooow tube frier. I always tell customers: modern tubes have an effective life of less that 1200 or so hours and that varies. Replace the tubes once per year if you gig with the amp: period. Otherwise, guys like me (doing repairs) stay busy and the tube companies get rich selling tubes to amps with weakened power sections.
It sounds like you burned a power tube and blew a fuse. First, you need a new set of power tubes and some extra fuses (go to Radio Shack and set the value you need in SLOW BLOW fuses).
Then, replace all the power tubes. Don't worry about biasing yet, we are just seeing if there is a problem. Next, replace the fuse.
Turn on the amp and play on it at various volumes and settings. If all is well, take the amp to a tech and get it rebiased. If you can afford it, pay to have the grid/plate and other resistors changed so the power section will be like new (clean slate with new tubes). Your amp will love you for it.
Almost all of the amps I have worked on for performance problems (cant keep tubes to stay alive for very long) are directly related to end user use. When you use a tube until it blows it ALWAYS TAKES SOMETHING WITH THE TUBE WHEN IT GOES (like the power section components). The compents will be weakened and the tubes will 'wear' at different rates that can even move them out of the 20% tolerence they must be within to sound good. 99% of the time a board repair with a retube after a catastrophe fixes the amp until the next time it is 'run into the ground'. Tube amps are NOT invinceble: they are weak compared to solid state and expensive to own. But we love tubes because they sound great. I have solid state to knock around on, when when it counts, I play only with tubes. I have spent hundreds on good tubes because you do get what you pay for.
Hope this helps!
-mike
Posted on Mar 30, 2009
Frying sound from amp intermittantly
then the problen is in the power amp section after the preamp stage. Contact Crate for your nearest service center.
http://www.crateamps.com/support/index.php
Mar 03, 2014 | Crate Ca6110dg Gunnison 60 Watt Acoustic...
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Where is the serial number on a crate amplifier
Real basic owners manual is here:
http://www.crateamps.com/pdf/manuals/CA6110DG_OM.pdf
Look at the chassis, or pull a part number off the original speaker to match speaker and back cross reference to the amp versions that used it. The OM is at least good enough with the block diagram to allow it to be serviced easily enough.
Feb 21, 2012 | Crate CA6110DG Gunnison Acoustic Guitar...
I have a crate fxt 120. I 'll be playing in the #2 overdrive channel and it will automatically fail and go to a clean sound. Although it is not entirely clean. It sounds like 2 sounds combined. A loud...
A possible problem MIGHT be marginal switch contacts on the external foot controller cable. If you are not using the foot pedal, these contacts must maintain contact to keep the same channel selected.
Sep 15, 2010 | Crate Music
I have a Crate PA-8 4 ohm 150 watt PA head that I run to four Peavy 10" PA speakers (two per side in series). It was very good, clean sound, but the speakers were cheap and may have been pushed too hard -...
150 watts should be easily handled by four Peavey speakers in the connection you described.. If the Peavey's are 8 ohms, then your total load was 8 ohms for the series/parallel arrangement which is well within the 2 ohm drive capability of the Crate according to specs.
I question if you really mean the speakers were in series? This requires a special cable to do this. Now if you mean they were "daisy chained" like the amp went to one speaker and another cable connected that speaker to another, then you REALLY had ALL speakers in parallel electrically which would be at the 2 ohm low limit of the amp... In either case, with only 1/4 of the 150 Watts to each, the speakers should NOT have been damaged. The amp MAY have been damaged. Try each speaker individually at a REASONABLE level to test.
If you plug into the effects loop out jack,OFTEN the connection to the internal power amp is broken so you might have to arrange a special cable as a wye to go back into the power amp as well as your external amp. In any case pwere ALL interconnected amps, etc from the same power source/receptacle for system safety.
Jul 15, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a small crate rx15 solid state amp. The power light comes on, but no sound comes out of either the amp or headphone jack. No buzz etc....
Power light means very little. If unit has a preamp output, plug a set of headphones into it and see if you can hear anythin going through. (it will be weak). If you can, the power amp section is bad. Take in for service.
Mar 29, 2010 | Crate Music
Crate flexwave 120 head sound cuts out
You have a broken solder joint. You'll have to disassemble the amp enough to get at the soldered side of the circuit board that the controls are mounted to and touch up any suspect solder joints. Just be sure to resolder only the joints that were originally soldered or need to be soldered. Hope this helps.
Jun 07, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Guitar amp no sound or lighting
Hope this helps!
-mike
Mar 14, 2009 | Music
Crate bv120.no power or sound..no lights..f6 fuse has 160 ohms...
did you change out the fuse? could be a tranny going south. if you change the fuse and you still get no power, then you have a fried power transformer. they are relatively easy to replace. look on ebay . get the numbers off of the existing one and start web searching. something will come up. if not email me on my contacts tab in my website yostamplifier.com we can troubleshoot. you should see the custom blue voodoo i built and gave to my little brother.
Mar 14, 2009 | Crate Blackheart BH15H Handsome Devil...
Loss of power while playing
If you can solder, try resoldering any connections on the board that appear grainy or have rings. It is likely that after the unit has been working for a while, the heat is causing a marginal connection to open up.
Keep us posted.
Dan
Feb 16, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Music Logo
78 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
