Question about Dishwashers
Dish water is not working. Water fills but no noice after that.
My dishwasher is about 9 years old. Use to work good even though it was making loud noise when washing dishes. Since yesterday when we start dish washer, hot water fills in but no sound and no wash. When I cancel the wash it is draining water also nicely. What could be the problem? Does the motor/pump need to be replaced? Is it a good idea to pay for replacing motor and service or just buy a new dishwasher? You input is appreciated.
    New Friend:
  • 6 Answers
It's obviously sounds like your pump has gone, but considering the age of the machine, it would probably be best to get a new machine, that way you would have a 5 year warranty with it aswell so it's win/win really!
Posted on Jan 05, 2013
3 Suggested Answers
  • 128 Answers
SOURCE: dish washer won't kick into wash mode . heating
First check you float valve.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Not working?
Check for a clog internal or external.
Scoop as much water our as you can. Open the cover on the floor of the machine. Usually just turns and lifts out or snaps out some are screwed in. Take your time and try not to force anything. Look for a clog there.
Check for clog in the drain. The dishwasher will connect to the drain under your sink and run either directly to the drain or into your disposal unit. Remove open the connections and look for a clog. Clear if necessary.
Not the clog?
Water is pumped out by the machine via an internal pump located under the base. If it fails the water will collect until it trips the float valve. First scoop out all the water from the machine and run it again. If water comes in and it runs to the point it fills again and trips the float then either the pump or timer is faulty.
Pump check.
Remove the machine. It will be held in place by screws directly into the counter top. You may have to lower it to get it out. The front feet turn with a wrench to lower.
Turn off the water supply. Run the unit again until you get to the drain cycle.
Connect a test light or voltage tester to the terminals at the pump. Check for voltage at the pump. If you have voltage replace the pump. If no voltage the timer is faulty.
Timer problem?
Some can be replaced as a unit others are integral to the control panel. Turn style can be replaced. Touch control can not.
For more help go to my more detailed tip "Dishwasher will not run. DW101 how to fix". Or click on my profile and you will find the link there.
Hope this helped you. Please take the time to rate this tip.
Thanks,
Adrian
Posted on Mar 22, 2010
  • 2501 Answers
SOURCE: Dishwasher fills and makes some
It could be that the jet holes in the rotor arms are blocked.
The arms are easy to remove so take them out and check out the jets.
Also take out the filter in the bottom of the machine and check that it is clear.
Posted on Sep 26, 2010
Even though the dish washer is off the tub slowly fills up with water. I have to turn it on to flush it out.
Sounds like a jammed inlet valve. Sometimes you can take it apart and clean it, or just replace it....Get a good screen and put in the inlet of the valve, if it does not have one.
Feb 13, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
The dishwasher is not cleaning properly, glasses look like they have a film on them, plates also do not look clean & the dishwasher has a foul smell.. like rotting food in it.. we use the top quality...
Check the main drain system connected to the dish washer hose pipe. Clean the junction if clogged. This smell might orginate from the pipe.
Check incoming water quality. If hard water is noticed, use softener attachments to the inlet.
Fill dish washer salt in the dispenser. Refer user guide. The salt will help softening the water to certain extent. Finally check whether rinse aid dispenser filled with the rinse aid liquid.
Jun 01, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
My dishwasher doesn't clean my dishes anymore and sometimes it doesnt dry them. it is a quiet partner 1 and it is about 2 years old.
It sounds like the water pump on the dish washer has gone out. A dish washer works (much like a clothes washer) by filling up the washer with a set amount of water, then through circulation, pumps the water up through the various spray nozzels. If the water pump is worn and not making enough pressure, the spray won't get the job done. Depending upon make/model, it may be cheaper to replace the water pump.
Run an empty dishwasher load with a bowl of white vinegar on the bottom shelf. As the dishwasher runs the cycle, the vinegar is slowly disbursed and cleans the dishwasher.
Mar 02, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Leaks front and back, makes loud noice
It sounds like broken glass shards have become lodged in the pump. You are looking at the possible need to replace the pump, and locating and repairing those leaks.
The cost of parts alone could exceed 200 dollars.
With a 12 year old unit, you may want to consider just replacing it, especially if you would need to pay a repairman to make the repairs. Your cost of repairs may actually exceed the cost of replacement.
At this point, the unit is already broken, so it couldn't hurt to remove the unit, disassemble the pump and look for the damage yourself. You may get lucky and just have a few seals to replace and a hose or two.
Here is a picture of a water pump, your should be similar and located underneath the bottom of the unit.
Oct 03, 2009 | Dishwashers
Dish washer fills and then drians without washing
If you're sure it is heating the water, then it sounds like the wash motor/pump has failed. If you've worked on washing machines and/or dish washers before, this is potentialy a DIY job - the Haynes Dishwasher manual is very good, and parts can be found on the internet.
The reason for cheking it is actually heating the water is that the symptoms sound very similar to those of a failed heater = fill, pause, empty, stop usually accompanied wth an error code. Error code will be presented by a number of flashes of a lamp, or a number on a display panle depending whch machine you've got.
Sep 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
The dishwasher works very loudly.It cleans the dishes very well, just the noise is extremely loud.
Though Noise depends on the model and make of the machine, still you can use the below methods to minimize the noise :-
  1. Ensure the dishwasher is level. An unleveled machine can cause unwanted vibration noise in addition to dish rattling. Most appliances have leveling feet that adjust to ensure that the appliance is level. Ensure the machine is level. If you can't access the feet, call a professional.
  2. Install insulation around the dishwasher. A sound-absorbing foam can diminish dishwasher noise level. Unless you are familiar with how to remove or install dishwashers, have a professional perform this task.
  3. Load dishes securely. One sure fire way to cut down on dishwasher noise is to load the dishes properly. Cups, saucers and other items that aren't properly placed in the dishwasher can toss about by the jet streams of water. Put small items in a dishwasher approved, screened container to prevent them from getting caught in the dishwasher's cleaning mechanisms.
  4. Purchase a quiet dishwasher. Some manufacturers make dishwashers with built-in noise reduction features. Research and read reviews for each to determine which one works best in your situation. Magazines like "Consumer Reports" provide unbiased reviews that can be helpful.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 03, 2009 | Whirlpool Dishwashers
GE Dishwasher fills with water but does not "spray water" on dish
Here are a few things that might help you out, first is you could have a bad heating element in your dish washer, when it fills with water it has to reach a certain temperature before continuing to the next cycle, next thing is you could have a bad thermostat, or your timer is defective.
Mar 16, 2009 | Kenmore 16522 Built-in Dishwasher
Loud noise
My Dishwasher had the same loud Grinding Noise.
It was a piece of a plastic fork lodged behind the macerator blade.
This is at the suction to the pump just under the strainer. check this out first before you pull everything apart. You should be able to get to it by taking the lower arm off and pulling the strainer out. Hope this helps.
Jun 20, 2008 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
87 people viewed this question
Top Dishwashers Experts
