Question about Western Digital Elements Computers & Internet
How to run chkdsk on network drive - Elements Western Digital Computers & Internet
  • Western Digital Master
  • 27,725 Answers
Cannot CHKDSK a network drive. Explanation: You cannot use the Chkdsk command with a local drive letter that has been redirected over the network. User Action: If you must run Chkdsk on the drive that is on the network, you will have to use the computer that is local to that drive. You might try this Log into the computer sharing the drive. Open your "Start" menu and select "All Programs." Click "Accessories" then "System Tools." Select the network drive and Right click select properties tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers operating system and Hard Drive. If no luck chkdsk utility for network drives Found a great utility called "TreeSize Professional". It runs on Win9x and NT and has command line options for running in batch files. You can download a full functioning 30 day eval @ http://www.jam-software.com/tree.html Background b> A network drive is a disk or tape drive connected to a server in the network that is shared by multiple users, according to PCMag.com. A network drive can also be called a remote drive. b> Benefits b> A network drive is typically on a server. Servers normally are always on, so the information on the drive is always available. Information stored on the drive is accessible on any computer on the network. Significance b> The implications of network drive technology on computer mobility are significant. Network drive software that allows a person to connect to a network drive via the Internet is available. You may access files from home or work from any computer with an Internet connection, even if you're thousands of miles away.
Run Network Repair From CMD b> The command-line interface for Microsoft Windows is accessible through the "Command Prompt" utility in the "Accessories" folder. The command prompt is particularly useful for network diagnostics and repair. For example, you can issue the "ping" command from the command prompt to test for and verify network connectivity. You can issue commands to repair the Windows networking from the command prompt instead of using the built-in diagnostic wizards that sometime provide less information than the command line.
Click the "Start" button in the lower-left corner of the screen. Type "cmd" without quotes. Press "Ctrl," "Shift" and "Enter" simultaneously on the keyboard. Click "Yes." Type "ipconfig /release" and press "Enter." Type "ipconfig /renew" and press "Enter."
Fix Network Device Driver Errors
b> A network device driver is a small program that enables a network device to communicate with the computer's operating system, as well as with other computers connected to a network. Errors may occur if the network device driver becomes corrupted because of viruses and other causes. You can fix errors by following the steps laid out below.
Check the information that came with your network device for compatibility issues; you need to know whether it is compatible with your computer, as well as the version of Windows you are using. Check if the network device is properly attached to the computer. Click on the "Start" button then choose "All programs." Right-click on "My Computer" and select "Properties" from the list of options. Select "Device Manager" from the "Properties window." In the "Device Manager" window, click the plus sign (+) beside the "Network adapters." This will list all the network devices installed. The network device that has an error should also have a yellow exclamation point right beside the network device icon. Double-click on the network device icon that causes the error. On the "General" tab, click on the "Troubleshoot" button and answer the "Troubleshoot Wizard's" questions. Follow the resolution steps provided by the "Troubleshoot wizard." If Step 3 does not work, check if your hardware or network device came with a software disc. Use the disc to install the network device on your computer. Follow the specific instructions provided by the manufacturer. You can also go to the manufacturer's website to check for updates available for the device driver. If no updates are available, try manually updating the driver. Getting an updated network device driver will prevent any conflicts from arising in the future. Go back to the "Device manager" window. Double click on the device that you need to update. This should bring up a small window that has the device's properties. Click on the "Driver" tab and choose "Update Driver." Reboot your computer, if necessary. If the network device still shows an error, Go back to the device manager, right-click on the device that shows an error and select "Uninstall." Restart your computer and open the "Device Manager" again as soon as the machine is back up. Right-click on the device and then choose "Scan for hardware changes." If the device continues to malfunction, the hardware or device may already be corrupted. Consider getting professional assistance from from a computer technician. Hope this helps.
b>
Posted on Jan 05, 2013
Chkdsk checking drive on network workstation every boot, how to stop?
Ensure the network discs are closed down correctly when powering off and ensure there are no bad sectors.
May 08, 2018 | Computers & Internet
Tip
Coping with and avoiding Hard Drive Volume Bit-map Errors
If your computer "locks up" or reboots itself, the problem is frequently lost or corrupted files on your hard drive. Most of the time the problem can be corrected by running chkdsk. However, one of the exceptions is when chkdsk reports that the hard drive has volume bitmap errors.<br /> To run chkdsk, click on Start, All Programs, Accessories and Command Prompt. This will open a "DOS Box" where you can enter DOS commands without the results scrolling off the screen before you can read them. Then key in chkdsk C: (assuming that drive C is the letter of the hard drive where your operating system files and applications programs are stored).<br /> Chkdsk will run in the read-only mode and report (but not repair) problems found on your hard drive. Chkdsk will then ask you to run chkdsk with the F switch to fix the file system. Make a mental note whether or not chkdsk reported any problems with the volume bitmap, then key-in chkdsk C: /F <br /> You will get a message that the drive will be checked (and repaired) on the next system restart.<br /> Enter exit to close the DOS box and the restart your system. Chkdsk will run automatically when your system restarts. If no volume bitmap errors were noted earlier, chkdsk should have repaired the problems with the hard drive. You can verify this by opening another DOS Box and running chkdsk without the /F. However, if bit-map errors were reported initially, chances are they will still be there as chkdsk cannot repair them.<br /> If you still have volume bitmap errors, you can either take your PC to a professional who may be able to repair the volume bitmap with specialized software, or you can back-up all of your data, format the hard drive, and reload the operating system and all applications.<br /> A frequent cause of volume bitmap errors is cloning (copying) a hard drive with more than one partition to another (usually larger) hard drive. The partitions should be sized proportionately on the target drive but sometimes the partition sizes are not reported correctly in the partition table and sometimes in the master boot record. <br /> Avoid cloning drives with multiple partitions, or if you do, immediately run chkdsk on the target drive to check for bit-map errors.
on Oct 25, 2010 | Computers & Internet
Studio XPS 9100 - I cannot access the internet from this computer consistently and shutting down takes 25 minutes
Always include the version of Windows in your posts.
Could have been a RAM problem if you got 4 beeps and you seem to have resolved that by reseating the modules. But the RAM error may have caused some corruption to a file on the hard drive.
Assuming the diagnostics pass, you can reboot and press F8 before Windows starts to load. Select Last Known Good. If that gets you to the desktop without errors, shut down normally and reboot normally, and you should be good to go.
You may also want to run chkdsk on the hard drive:
Click: Start>run
Type in: chkdsk C:
Click OK
Accept the offer to run chkdsk at next boot and then reboot. chkdsk will run before Windows loads. It may take a long time, depending on size of your hard drive, so be patient.
Apr 25, 2014 | Dell Studio Computers & Internet
BIOHD-s no drives detected
Error Code Biohd-2 No Drives Detected errors are caused by missing system files or broken system registry structures. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
If you are unable to get a connection with your hatd drive
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
You might have to use safe mode with Networking to download
Select safe mode with Networking to download
Oct 07, 2013 | HP Computers & Internet
I have done a monthly backup on my laptop for more than a year, but this time I'm getting an error message "corrupted file system 0x81000008
Run a check disk on the Drive and select Fix bad sectors.
    Running CHKDSK through the Windows Command Prompt:
  1. Go to the Windows Command Prompt. You can do this by clicking first the Start button and then clicking the Run button. After this, type "cmd" in the Open text box and press Enter.
  2. View the displayed Command Prompt screen.
    If you want CHKDSK to run in read-only mode, type:
    CHKDSK c:
    If you want CHKDSK to fix errors and not to check bad sectors, type:
    CHKDSK c:/f
    and press Enter in the Command Prompt.
    If you want CHKDSK to run thoroughly; that is, fix errors, find bad sectors in your hard drive and recuperate still readable data, type:
    CHKDSK c:/r or
    CHKDSK c:/p and press Enter in the Command Prompt.
  3. Running CHKDSK through My Computer (Windows XP)
  4. 1
    Initialize the properties of the hard drive you want CHKDSK to run. Open My Computer. Right click your mouse on the drive in which you want CHKDSK to run. Click the Properties button and click the Tools tab. In the Error-checking box, click the Check Now button.
  5. 2
    Set up the Check Disk options by checking one or both check boxes displayed. These are labeled "automatically fix file system errors" and "scan for and attempt recovery of bad sectors". If you want CHKDSK to run in read-only mode, do not check either box. After this, click the Start button.
Jan 01, 2011 | Western Digital My Book Essential Edition...
My PC every time i power on chkdsk always appear it says i need to scan my local disc d. What should i do? Do i need to format local disc d alone or the entire system. Thanks and more power
One of Windows annoying so called “feature” is CHKDSK being automatically being run whenever you don’t shut down your computer properly. You get the blue colored screen that says “Checking file system on C: The type of the file system is NTFS. One of your disks needs to be checked for consistency. You may cancel the disk check, but it is strongly recommended that you continue. To skip disk checking, press any key within 10 seconds(s).
Simply pressing any key would stop CHKDSK from running but when you restart your computer, you’ll get this prompt again. Sometimes even after letting CHKDSK scan the drive that it wants to, CHKDSK would still automatically run at next boot! Here’s how to disable or stop CHKDSK at Windows bootup
There are some people suggested to edit the registry but the proper way to disable CHKDSK from starting up is using the /x switch on chkntfs command in command prompt. The /x switch will exclude a drive from the default boot-time check. If you have drive C: as your hard drive, then the command to disable chkdsk from scanning C: drive would be:
chkntfs /x c:
If you have 2 drive, C and D, you can disable chkdsk with the command below
chkntfs /x c: d:
Aug 02, 2010 | Computers & Internet
Please run Chkdsk utility
open run type cmd type chkdsk c:
Oct 08, 2009 | Google Chrome
Chkdsk will not run
You need to run chkdsk /F /X and then the drive letter c: for example.
May 03, 2009 | Seagate USB 2.0 External Enclosure + 400GB...
Pen drive write protected problem
Click > Start > Run > type "CMD" Then
Type "CHKDSK" and type the letter of your Pendrive and "/F".
chkdsk Q: /F > press Enter
another example:
chkdsk D: /f
chkdsk E: /f
D or E is the letter or your pendrive.
Dec 06, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Disconnected network drive
you should run chkdsk because this only means that there was a unstability either on your OS, software or files. chkdsk will check your systems integrity and if it finds an unstable file, it will repair it.
Apr 03, 2008 | Computers & Internet
Computers & Internet Logo
6,955 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
