Question about Insignia Televison & Video
What is the typical startup time for a 55" LCD TV?
I just bought an Insignia 55" LCD TV Model NS-55L260A13. It takes approximately 35 seconds to turn on by either the remote or at the TV. Seems excessive for a new product. Opinion?
  • 933 Answers
35 seconds is a bit long. You may want to contact Insignia's tech support and bring this to their attention. I would say there is a problem,
Posted on Jan 05, 2013
  • 814 Answers
SOURCE: My Insignia NS-LCD32 TV won't power on. The remote has good batteries, the outlet has power etc. Insignia says to unplug it it for a few seconds and then plug it back in. I tried that multiple times w
The power surges have probably blown the fuse in the power supply board. This may not be the only problem.If you are still under warranty, you will need to have it serviced at a service center. If not You will need to find a repair person or center to open the unit and test it for you. This television and all your electronic equipment should be protected with surge protectors. The reason is your power company has problem with power outages and this will damage your equipment. There is no built in self defense for this equipment due to the huge variants involved with power companies. You should call Insignia and ask them where you can find a authorized service center. You can call the Insignia customer support at this telephone number 1-877-467-4289. Tell them the model number of your television and the problem you have had with its failure to turn on.They will be able to help you find a service center to test and repair your television. I hope this information helps you with your problem.
Posted on Jun 03, 2009
SOURCE: tv is locked
hi guys got same tv same prob......finally after hours of frustration found a solution.
steps:
  • Turn on tv
  • Press and hold the menu button (you will hold this through the next few steps till the menu comes up)
  • turn the tv off using the silver button on the back of the tv
  • push the button back in on the back of the tv
  • tv should come on and bring up the menu
  • using the channel and volume get to the menu with the v-chip controls there should be a reset menu button change it to on.
  • turn off tv using power button on front of tv.
  • turn it back on and problem should be solved
Posted on Dec 04, 2007
SOURCE: Insignia NS LCD32 standby light blinking off and on. No Power
I had this problem as well. Actually best buy just left my hosue to fix it. This is the second time they were here to fix it. The first time they said a part was loose. This time they had to replace a part.
Posted on Apr 01, 2008
  • 5 Answers
SOURCE: how to get code for insignia ns pdp42. remote is incorrect setup
This TV is the same as the LG 42PC3D. Find a remote code for that TV and you'll be in good shape.
Posted on Sep 03, 2009
SOURCE: TV will not turn on.
I am having same challenge!
Posted on Dec 07, 2009
Insignia ns-55l260a13 does not power on. Power led blinks 5 shorts, pause, 2 shorts and stays on. Screen blinks and nothing else happens afterwards.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 23, 2016 | Ideal Sales New Insigniatm - 55 Class -...
Need manual for my tv,XVA133DLM-080507-01196
Product Support ' Insignia
www.insigniaproducts.com/support.html
Manual, Firmware, Drivers & Product Information. Most of ... For OPEN SOURCE SOFTWARE information refer to the on-screen display on your product. If you ...
[PDF]English - Insignia
www.insigniaproducts.com/.../manuals/NS-55E560A11_11-0573_MAN...
manual, or otherwise listed by an independent laboratory as suitable for your TV. •. Follow all instructions .... NS-55E560A11 Insignia 55" LED-LCD TV, 1080p.
Oct 07, 2015 | Insignia Televison & Video
I have a 55 Insignia tv it turned it self off and want come back on.i check the power and it want work either.
Won't not want.
Hi James,
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a
component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 13, 2015 | Insignia Televison & Video
Setup insignia NS-LCD19. I get a "signal not
Your computer video output resolution is not compatible with the TV. Try adjusting your video card output settings to 800x600 at 60 hz to begin. Once the desktop displays on your TV, you may continue to adjust the settings to meet your needs.
Oct 12, 2011 | Insignia NS-LCD19 19 in. LCD TV
Televison & Video Logo
57 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
