Question about HP Mini 1000 Netbook
HP MINI 1000 KEYBORAD BACKLIGHT
IS IT BACK LIGHT LAPTOP OR NOT?
  • HP Master
  • 7,627 Answers
4 Suggested Answers
1234s282
  • 144 Answers
SOURCE: SD vs SDHC on the HP mini 1000
Yes , SDHC is the name given to SD cards that can hold more than 2gb of data like 4gb or 8gb. they use the same slot as SD cards
Posted on Jan 05, 2009
SOURCE: How to Reset HP Mini 1000 Laptop BIOS?
hi,
this is sujeet, solution for this problem you just restart you laptop and press F8 and start your pc in safe mode and than remove your password and restart again.
Posted on Jul 16, 2009
jomabug76
  • 1148 Answers
SOURCE: key pad is locked in
Go to hp website ,,they have what u need,,solution s,, and driver downloads,,goodluck
Posted on Nov 20, 2010
HELP my computer is locked up i need the BIOS PASSWORD to the hp mini 1000
Best solution is to visit http://www.unlockbiosrecovery.com/Unlock_HP_Bios.php
and order your HP Mini Bios Master Password for only $20 which will clear any currently set bios password. They do most laptops and have a phone number where nice tech support help you unlock your laptop.
Jul 13, 2012 | HP Mini 1000 Notebook
Changed the lcd screen but all i have is a white screen
1) Loose connection of the Video Cable TO the motherboard, and/or TO the back of the LCD screen.
Can easily happen when reassembling.
(If you can't reuse the sticky tape on the back of the LCD screen, that holds the Video Cable to it, use more tape )
2) Incompatible LCD screen.
MATCH up the manufacturer's numbers on the back of the old LCD screen, to the new one.
They MUST crossover, and match up, if they are two different LCD screen manufacturers.
The screen Inverter is MATCHED to the LCD screen, also.
Matching up the Model Number, (Product Number for HP), may not be all the info you need.
Matching the numbers off of the old screen, for the new one, is.
http://www.sparepartswarehouse.com/HP,Mini,1000,Laptop,LCDs-Displays.aspx
Under the red heading - Find Your Spare Parts - click on the blue Down Arrow to the right of the - Choose Model - box.
What Model is yours?
Write down the manufacturer and product ID number.
Now go to the far upper left of the page. In the box under - Part Number Search, type the letter/numbers for your old LCD screen.
On the page that comes up. Do they match?
Putting the letter/numbers in for the LCD screen you just purchased.
Do they match?
IF the old LCD screen works at all, reconnect it, and see if it works.
If so the LCD screen you purchased does not.
3) Make SURE the screen Inverter cables (Wires) are connected tightly.
[ Check the connection of the Video Cable to motherboard first.
Then the Inverters wires, then the Video Cable connection at the back of the LCD screen ]
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL or a series of LED lights
The HP Mini 1000 series of Netbook PC's uses a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
OR a series of LED lights. Depends on the model. (8.9 inch LCD screen models usually use CCFL. 10.1 models usually use LED lights)
A screen Inverter (FL Inverter) is used to convert power from the laptop, for the Backlight, and LCD screen.
Make sure there is 6 Volts DC power going through the Inverter.
[ NOTE*
90 PERCENT OF THE TIME the fault is the Inverter ]
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3832471&
HP Mini 1000 and Compaq Mini 700 - Maintenance and Service Guide
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 28, 2012 | HP Mini 1000 Netbook
My HP mini screen will not turn on but my computer will turn on , the power light turns on but the wifi light is orange? But mainly the screen will not turn on. How can i make it turn on?
Hi craryrayann...
Plug your mini into an external monitor and see if the screen is the way it is suppose to be...if so then you lcd screen needs replacement.
If it does not look normal...then replace the backlight/inverter
Please take time to rate me
Sep 11, 2011 | HP Mini 1000 Netbook
I have hp laptop but i cant use coz the keyborad...keyborad loose enter, backspace, letter z and h, and the arrow on the right side...my laptop is mini hp...can u help me plss....
Hey, If a few keys do not work on your keyboard you can get them replaced , i recently got my new replacement keys from www.laptopkey.com Now my laptop keyboard is as good as new. Love them for they service and reasonable cost.
Sep 06, 2011 | Compaq Keyboard
HP 210 mini. No back light on screen. If I aim a light at the screen I can see an image. Connected to an external monitor works fine. I changed to a new mother board same problem. Is it the cable?
It is possible that it is the cable, but it is far more likely that the backlight in the screen is out. Obviously, with how new the laptop is, this is likely a manufacturing defect. If the laptop is under a year old or covered by an extended plan through a vendor, I'd recommend taking it to them or calling HP. If not, replacing the backlight on a laptop is typically expensive enough that it makes more sense just to replace the Netbook.
Aug 27, 2011 | HEWLETT-PACKARD HP Mini-Notebook...
My HP mini 1000 is locked and I can't even get
Remove the cmos battery for 5 - 10 minutes. That will reset all data in the bios.
Jul 25, 2011 | HP Computers & Internet
Hp mini 1000 does not seem to recognize my wireless network and the wireless network light will not come on. What do I need to do?
The front of the HP Mini 1000 Netbook has two switches and two small lights. The two switches are for power and wireless. The two lights are for hard drive activity and power. Both the power and Wi-Fi switch are designed exactly the same. They are flat with a little bump where a light is.
Check if the switch is on before trying to reinstall the driver.
Hope this helps!
Apr 13, 2011 | HP Mini 1000 Netbook
Im using the hp mini 210-1000 laptop and ive accidentally lock the touchpad. Now i dont know how to unlock it back. Pleaseeee help me
just double tap the left top corner of the touchpad on your mini. the red light will go away and the touchpad is active now. repeat the same to lock and unlock the touchpad.
May 18, 2010 | Computers & Internet
Hp mini 1000 - no startup display
you got error this windows/OS system so u need to re-install the OS/Windows..good luck and have nice day
Jun 18, 2009 | HP Mini 1000 Netbook
HP Mini 1000 Netbook Logo
48 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
