Question about Sharp Aquos LC-32D40U Television
LC-32D44E Image overscan and shifted to left when HDMI input
Sharp Aquos LC-32D44E Television
I connected the LCD to HDMI output of the Blackmagic Intensity card, sending a 720p signal to the tv. The image displays ok but it is slightly zoomed in (overscanned) and shifted to left.
I used the menu controls to adjust position but it seems it is not enough for proper centering.
Is there any setting in service menu for disabling overscan for HDMI, and also for adjusting horizontal position?
SOURCE: My LG HDTV is in overscan, can't resolve
Have you tried to reduce the ratio on the remote..when zoom comes on lower the zoom ratio.
Posted on Jan 16, 2008
  • 476 Answers
SOURCE: magnavox 37MF337B/37 overscan only sometimes problem
This TV has a pixel resolution of 1366x768p
It will accept a 1920x1080i input from a high def source , but running a PC at 1920x1080i/p will cause the problems you describe, depending on what the PC is sending to the TV, because PC signals are not the same as high def.
Your PC should be set to a resolution as near to 1366x768 as possible. My PC allows 1280x768 and 1360x768. Try one of these for best results.
There are no settings on the TV to solve this problem.
Posted on Feb 12, 2008
DRebel
  • 19 Answers
SOURCE: Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Posted on Apr 03, 2009
gymhasafit
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
  • 3 Answers
SOURCE: Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Posted on Jun 26, 2009
Television isnt working correctly
Are you changing the Video Input selector to the proper HDMI port? AKA the SOURCE button.
Couldn't decipher if you said that you've used another console with HDMI video on the Sharp Aquos already.
Jun 08, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
No audio, no video but program guide displays
1. You should check you cabling connections at the satellite receiver to the TV.
2. Check the mode you are in on the HDMI cable
3. Your HDMI should have 3 modes in the set up screen (HDMI 1,2,3)
Apr 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
When plugging in a new PS3 to hdmi input 4 or 5 on the Sharp Aquos LC-42D62U, it is not picking up the connection and I can't select it on the input menu
Does the HDMI output on the PS3 have to be turned on first in its settings? Make sure the settings on the PS3 are at a minimum of 720p as if it is set to 480i the TV probably wont notice anything connected to HDMI.
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to use a sharp aquos as a monitor with my laptop
Hi. You haven't said how you have connected your laptop to your TV so I'll give you a couple of options:
1. VGA to VGA (This cable is a 15-pin cable like the one you would use to connect a computer monitor to the back of the computer box itself). The Sharp has a VGA connection at the back.
2. DVI to HDMI. If your computer has a DVI output, this would be the best connection.
On your remote, press menu.
Use the left/right arrows to select option
Then use the arrow up and down to select input source.
Depending on the TV you have, you will either see the actual name of the connection (ie. HDMI, DVI, VGA) or you may need to select Input 1, Input 2, etc... depending on which connection you used. The input number may be labelled on the back of your TV.
If none of this works, please let me know your model numbers and I can provide you with instructions specific to your models.
Jan 19, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Jan 13, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
SETTING
The Aquos is capable of 1080p which is the best current HDTV resolution - awesome!  The exact resolution is 1920x1080 with a 60Hz refresh rate.
Its also very capable at upscaling 720p inputs.  I've done various tests and visually there is practically no difference when watching a regular DVD and having the DVD player do the upscale, or letting the television do the upscale.
If you are connecting a computer then its a little more complicated...
If you are attaching a computer to the television then if the video card in your computer is capable of 1920x1080 at 60Hz then this would be perfect.  Personally I would rather use 720p rather than drop to 1080i as the drop in resolution isn't noticeable from 4 feet whereas interlacing causes me to get a headache after a while.  (LCD / Plasma interlacing isn't as bad as old CRT monitors that used to use interlacing - so not everyone will get eye strain / headaches from it)
The television is also good at showing other computer resolutions too although you'll need to make sure "overscan" is turned on which can cause some bits of the computer desktop to disappear off the edge of the screen...
I spent quite a while getting the DVI->HDMI working - to be honest I'm not entirely sure it was worth it and the results from a regular older style monitor connector is pretty similar...  If your graphics card can't handle the required resolutions - then it may well be worth a new card as HDTV output cards are available pretty cheap...
Nov 17, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sound, but no picture
The hdmi inputs on this unit go directly thru the main digital pcb. and the component inputs feed thru the av pcb then to the main pcb. If the composit hook up do not work and hdmi inputs do work the unit has a bad AV pcb.
Nov 08, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
743 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
