Edimax hp-2003av not working with humax
I am trying to get my Humax Free Sat + working with BBC iPlayer and ITV player using the Edimax HP-2003AV home plug mini but it keeps saying that its disconnected. It works occasionally but most of the time says its disconnected.
Shuttle83
  • 1139 Answers
SOURCE: problem for humax 5400
This is telling you of a defect in the circuitry since this unit cannot be repaired I would contact my satellite company and have the unit replaced since it is defective.
Posted on Sep 16, 2007
WebTeligent
  • 42 Answers
SOURCE: Humax Tivo will not record to DVD
After the update to 1.15 I had to delete EVERY recording on the unit. After that, any new recordings would burn just fine. However, some have found that same failure even after a hard reboot (repower). Called Humax level-1 support and they suggested a replacement unit so I swapped it out. But I've since learned that TiVo "pushes" a DVD firmware patch (possible supplied by Humax) from 1.08 to 1.15 and that patch is the culprit. That patch is suppose to make the DVD burn at a higher spin rate. After talking with level-2 Humax support they heard of the problem and said "the unit is working as designed", meaning, the DVD drive manufacturer specs say the drive is capable of a faster burn rate. So now I have Humax DTR800 #2 and so-far-so-good, but TiVo hasn't pushed the patch onto the box yet!
Posted on Nov 10, 2007
  • 7 Answers
SOURCE: how to download recordings from humax pvr9200t to pc
Hello liardet,
you could of course use the manufacturers supplied utility !
However, a lot of independent work has been done to produce a whole range of highly effective tools described on http://humaxdisk.wikispaces.com/
See also http://www.hummy.org.uk/forums/showthread.php?t=2009
JamesT
Posted on Dec 18, 2008
SOURCE: Humax Tivo Stuck on the welcome screen
I just had the same problem with mine and found another post that at least fixed mine.
I had a DVD in the unit as it was restarting. I took a flathead screwdriver and opened up the DVD slot by inserting at the top right corner and opening the door. On the inside, at the bottom right, is a button that ejects the DVD player (the eject button on the outside won't work while it's booting up). I ejected the DVD that was in it, unplugged the unit for 30 seconds, and then it rebooted just fine.
Hope it works out for you too...
Posted on Aug 20, 2009
SOURCE: Humax Foxsat HDR sudden Remote Control failure..
Make sure you have pressed the "PVR" button at the top. If you have accidentally pressed on on the others TV, DVD or AUDIO then they will light up when you press another button signifying that the remote is trying to send a signal to them rather than the PVR...which is where you want it to go.
Posted on Nov 21, 2009
Tip
How to watch uk TV Online FREE!!
  • Most U.K channels also provide an on-line streaming service to allow users from within the U.K to watch programmes after they have aired on the channel on digital t.v.
  • All websites are free and require no logins or registrations just select what you want to watch and click play..
on Jul 09, 2010 | Computers & Internet
My humax won't;t record bbc channels. I have tried retuning the tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range. The signals for BBC and ITV are among the strongest ones broadcast. If they are now at a point on the aerial's range where they are too strong for the TV then the tuner will over-saturate. The result is the same as no signal.
Have a look online for a Variable Signal Attenuator. It's a device that can be added to a aerial signal cable just before it goes in to the tuner. The adjuster allows the signal level to be reduced. Watch the TV's signal quality and signal level displays if it has them. As signal level (power) reduces you'll actually see signal quality increase. If you go too far then quality will start to go down again. The optimum point is where quality is highest.
Oct 08, 2014 | Humax Televison & Video
The bbc red button service on humax listing not working
You should scan for channels again, as some were changed recently.
Sep 14, 2014 | Humax FOXAT HDR DTV Receiver
Why is BBC iPlayer not working via Expat Shield
I dont have a proper solution ,, sorry ,,i have the same problem since May 19th. From one day to the next ,, suddenly the bbc iplayer does not recognise my expat shield UK address ,, it keeps telling me "programmmes are not available in your area. But when i check on other sites where i am , my IP address is UK, and i can connect to itv player no problem. I have tried numerous times since then, and still no connection, i think Hotspotshield has done this deliberately,to force people to pay for the Elite service.I wrote to them (anchorfree) about this problem, but the answer is always about Hotspotshield ,,, they fail to recognise my question is about Expat shield,, useless support service.
Anyway my small solution at the moment is Hola unblocker(mozilla FF add on),, on some days it sticks a bit but most days it works fine
May 20, 2014 | AnchorFree Expat Shield
Not receiving BBC or ITV iplayer
I don't know this device but it maybe set to WiFi when you are on Ethrenet cable. Go into it's settings and make sure it's set to Ethernet not WiFi and DHCP for it's IP address.
May 06, 2014 | Humax Televison & Video
T get itvplayer on my humax free view i can get bbcplayer what could be the problem?
ITV Player is somewhat flaky compared to the well-implemented iPlayer. Sometimes, just starting it again will make it work.
Dec 06, 2013 | Humax Televison & Video
I cant't get bbc iplayer to play programmes: it comes up with: task queue failed at step 0: config empty. ITV player works perfectly but I prefer programmes from BBC. What can I do to solve this...
I am having the same problem,same error message. I only get the message when trying to view live TV using the iPlayer. The BBC News channel plays live OK through the BBC News website. Live sport broadcasts play OK though the BBC Sport website. I uninstalled Flash Player and then reinstalled. It made no difference. Please help.
Sep 11, 2011 | AnchorFree Expat Shield
How do i install free bbciplayer i can play itv player but not bbc player as it comes up with install latest flash player but this is already installed as the itv player uses this
the best thing to do is to manually install flash player. go to filehippo.com and search for flash player. install it from there. then try to install iplayer
Feb 25, 2010 | Microsoft Windows Vista Home Premium...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
