Question about Reptile
Can i get replacement parts for hexbug nano hive habitat?
One of the black plastic piece that attaches the lower level to the upper level, hinging them together so they open and close properly broke off. Is it possible to get a replacement?
  • Rusty Skates
    Rusty Skates Dec 26, 2013
    We broke 4 of these pieces in one session, so are also looking
  • 100 Answers
SOURCE: 2001 Olds Aurora center console lid hinge broke
Best bet is the junk yard
Posted on Jan 06, 2009
  • 9 Answers
SOURCE: The plastic part on the back hinge broke and i
This just happened to ours, it's a design flaw in my opinion.
Anyway, I drilled through the plastic covers and used 4 6-32 countersink screws, 2 inches long, with corresponding nuts and ground off the excess screws with a dremel tool.
Won't come apart again and matches the brushed stainless theme.
Posted on Jul 02, 2009
  • 24 Answers
SOURCE: DCS 30 inch oven door fell off
First thing is be careful them sprins are strong and will hurt your fingers bad if not careful. That said place both hinges in 1/3 open position they should stop there. if not put both all the way open then slide door back on and close. supposed to only lift off in 1/3 open position but whatever works.
Posted on Jul 25, 2009
SOURCE: Fisher & Paykal Refrigerator.
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Posted on Apr 11, 2011
  • 68 Answers
SOURCE: HP M3035 ADF has two
Unfortunately for this model the ADF section isn't broken down into it's individual components,
the part numbers available for the ADF are as follows: (direct from the Service Manual)
Control Panel
CB414-60101
Cover, ADF
CB414-67902
ADF feed roller kit
CB414-67904
Input tray, ADF
CB414-67903
ADF assembly
CB414-67916
Scanner assembly (ADF assembly is not included)
CB414-67905
However your best bet would be to call around to all of your local printer repair shops in your area and asking them if they have any of these M3035's sitting around for spare parts.
Otherwise I could try to find a good picture of the ADF Feed roller kit and see if it contains the parts you're looking for.
Hope this helps! If so please don't forget to leave a positive review for me. :)
Posted on Jun 07, 2011
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
The mullion is broken in my Lg refrigerator
I have a related question. My lower spring broke and I have the replacement spring. How do I put it into both plastic fittings at the same time. One arm on the spring goes on mullion while the other arm goes into a fitting on the door. Please help!
Aug 15, 2012 | LG 4-door French Door Refrigerator...
HP Officejet J6400 hinge Broken
Or you can take it apart like I did, see the attached photos and use JB weld but be very careful. I put paper between the moving parts to not put JB weld over every thing. I also practice placing the hinge with a pair of needle nose pliers. To try and get a good feel about this. You will want to scrap off the excess with a small flat head screw driver, on the inside and outsides of the plastic tabs. Let it dry for 24 hours. You will need to cut a piece of the while plastic out to be able to slide the metal hinge pin back into place, I would do this first but I did not think far enough in advanced that way you can slid the pin in to let is dry and the two ends will be in perfect alignment. Ideally you would want to replace the hing but I could not figure how to get the front right white lower cover off to get to the one screw that is holding on the black top piece to be able to figure out how to remove the hing assembly completely and go to a local printer repair shop and get the new hinge if HP still sells the part and it is not $100.
I took the photos with my 4S so I am not going to re-size them to 200K because you wont be able to see anything.
Hope this helps.
Apr 24, 2012 | Office Equipment & Supplies
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
Coolant leaking in and around the intake manifold as well as the under carriage of that same part I think. Outake? I know that the part that attaches to the manifold appears to be metal but the manifold...
The plastic piece is the upper intake manifold. The metal part is the lower intake manifold. Sometimes the gaskets go bad between the upper and lower intake manifolds. But usually the upper intake manifold is cracked and needs replaced.
Nov 11, 2010 | 1993 Buick Park Avenue
Door on new Kenmore freezer hard to open ... could this be a leveling problem? I wouldn't think it is an ice build-up problem since the freezer was only installed last Friday (9/24) and the ice maker is...
Check thoroughly for any obstructions, shipping tape, remaining pieces of plastic, in and around the doors, door frame, cabinet frame that the door contacts when closed, and around the upper and lower hinges. Do you hear any noises when opening or closing the door? Do you see the door rubbing on the inside liner as you open or close the door? Were the doors removed and replaced in moving? This last one, if it is the case, check the alignment at the upper hinges, loosen but dont remove the screws, and adjust the door away from center.
Sep 30, 2010 | Freezers
Strange thing over night my refrigerator has lost the suction in the doors. I have to close the door and hold the door close, to keep it close
there is a plastic part that attaches to the lower hinge that helps keep the door closed. it is like a rocker that when the door is open the door rides up on the plastic rocker then as you close the door the door rides down on the hinge rocker and helps to force it closed. mine stopped closing on it's own then all of a sudden the black plastic piece broke and fell to the floor. I am ordering a new piece if I can find the part number.
Mar 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
How to replace the cabin air filter in a 2000 toyota avalon xls
lower the glove box and its forward of that, should be a plastic panel to remove.
Sep 23, 2009 | 2004 Toyota Avalon
Door on fridge side has droped 10mm the plastic washer has worn away i think .Can i get a spare please its situated at the bottom of door
Take the model number ( you didn't list it here ) to a parts house and tell them you need the door closer for the frig door . To install , remove the 3 screws holding the top door hinge located under tho top hinge cover , and lift door off bottom hinge . Remove all food items from door first . The closer should come with a lower hinge and the piece which attaches to the door . If not , tell them you need the door piece also. Or the kit may come without the hinge , but , with both the hinge piece and the door piece in the package .
Aug 09, 2009 | Refrigerators
2005 Mustang Automatic Shifter
The solution is that you must purchase the complete shift housing because it is all one piece and you can't just replace part of it.The dealer told me this is about $250.00 U.S. and it can be replaced by an intermediate skilled tinkerer. For right now I just live with the inconvenience as I can pretty much guess what gear Im in.
Sep 17, 2008 | 2005 Ford Mustang
Open Questions:
Reptile Logo
346 people viewed this question
Top Reptile Experts
windryder
Level 1 Expert
john h
Are you a Reptile Expert? Answer questions, earn points and help others
