My hot water keeps going Luke warm the. Cold. Central heating is working, pilot light is firing up when I put the hot water on. I think it could be the diverter valve. Could it be anything else. If so
Check the hot water coming from a faucet, if it stays hot your problem is in the thing getting or using the hot water, maybe the hot water line is sitting somewhere before it is being used.
If the water is luke warm coming out of the tap the problem is the hotwater heater itself. The coldwater inlet pipe going into the heater has been eaten away inside and is now too high in the tank.
Posted on Jan 05, 2013
    Problem Solver:
  • 6 Answers
It could also be the heat exchange
the dr
  • 447 Answers
SOURCE: kenmore 80 series top loader the washer will not fill with cold water only hot water
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
Posted on Dec 02, 2007
SOURCE: HITACHI WASHER SF 6500PX, COLD
hitachi washer sf 6500px lid for washer
Posted on Mar 07, 2008
IFIXALL
  • 868 Answers
SOURCE: maytag neptune
Change the water valve again ,you most likely got a bad one.The odds of there being no cold water after a new valve is almost impossible.You can test the valve to make sure its working before you go to buy another one.
Posted on May 14, 2008
gdmisp
  • 66 Answers
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Posted on Jan 16, 2009
stephanos18
  • 144 Answers
SOURCE: Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Cheers
Posted on Mar 25, 2009
98 grand cherokee little heat.heater hoses hot top rad warm bottom is cold collant barely luke warm
While it doesn't seem likely, if you've changed, or had the thermostat changed.... I'd say you got a faulty thermostat. I am curious as to what your temperature gauge says the temperature of the engine and coolant is.. If your gauge is showing hot, I can think of two more possibilities... the water pump isn't pumping right... and, if the water pump isn't working right, the problem can be a cracked head or block, which can cause an airlock in the coolant system. Check the coolant or radiator cap.
Nov 14, 2013 | 1998 Jeep Grand Cherokee
I have abosch 1600 ps aquastar 4.3 gpm indoor when i turn hot water on it all fires up but no hot water comes out only luke warm water why
Water heater is heating water but only luke warm water arrives at faucet.
Open TP valve and confirm that hot water is available.
If water at TP valve is hot, then problem might be plumbing-related, for example crossover.
http://waterheatertimer.org/Crossover.html
Aug 15, 2011 | Bosch 1600PS NG Aquastar 4.3 GPM Indoor...
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
I am not getting hot water from my water heater
Yes i would agree plastic dip tube .Do you have the hot water entering where the cold inlet is , do you have cold also attached ?
Dec 16, 2008 | Water Heaters
2000 Daewoo Leganza heat gets just luke warm!!!
I have the same problem. we changed the thermastat. the engine coolant was full of muck and looked rusty like something was rusting away.we then back flushed the system including the heater core.It's alot better but we think the water pump propellers are rusting away. this sometimes happens. so we are keeping an eye on the temp to see if it is getting to hot or over heating if so the the water pump needs replacing. I would have the system back flushed to see if that helps you could be having the same problem I' having. Hope this helps.
Nov 02, 2008 | 2000 Daewoo Leganza
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
