Question about Smeg 24 in. DWF612SS Free-standing Dishwasher
I HAVE A DWF612SS SMEG DISHWASHER I HAVE A FAULT E2 IS SHOWING WHAT DO I DO
2 Suggested Answers
  • 1462 Answers
SOURCE: E2 error in smeg dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
Posted on Nov 20, 2008
Kettle does not heat. What does the E2 message mean
SMEG DISHWASHER ERROR CODE E2? - How To Mend It
howtomendit.com > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
Oct 15, 2015 | Oster 1.7 L Variable Temperature Electric...
Smeg dishwasher DWA 147X showing fault ER 01
Is your dishwasher overfilling? Check the water inlet valve.
Oct 21, 2014 | Dishwashers
Smeg DW167.1 error code
I HAVE A SMEG DW167.1 AND IT COMES UP WITH A E9 FAULT, DOES ANYONE KNOW WHAT I CAN DO TO SOLVE THE PROBLEM ,THANKS
Jun 22, 2012 | Smeg Dishwashers
HOW DO YOU TURN IT ON TO WASH THE DISHES
look for the manual of your new DWF612SS Free-standing Dishwasher.... and find the tutorial how to turn it on...
Apr 27, 2011 | Smeg 24 in. DWF612SS Free-standing...
My smeg dishwasher stopped during a cycle and warning lights E2 come on. suggesting that it has drawn too much water and to contact customer technical services, any idea what i need to do
E2 shows that the water level switch has been tripped or its faulty,interupt the programm and switch off the dishwasher then switch it on ,programm it again and start the washing cycle again,if the problem persist then test the water level switch for possible replacement
Jan 10, 2010 | Smeg Dishwashers
Lost manual book dishwasher smeg df612se
The program will not move when you press the button.
May 23, 2009 | Smeg 24 in. DWF612SS Free-standing...
Hi our dw 1612 integral dishwasher has thrown a fault code E2 which according to the book is a tripping of the water level switch. unfortunately the book dosent tell you where the switch is located or how...
I don't mean to make you sound stupid but it isnt a switch that you can use.
It is used in a dishwaher to make sure that the water doesnt over fill and spill over out of the dishwasher and electricute someone. it cuts off the water (when working corectly) and washes as normal or if it over fills it tells you and in your case it is error E2
you need to speak to a appliance repare shop to see what needs to be fixed or replaced.
Hopefully this has givin you some help
if you have any questions plese dont hesitate to ask
Dec 02, 2008 | Smeg 24 in. DWD612SS Built-in Dishwasher
Nov 20, 2008 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Open Questions:
Smeg DWF612SS leaking & not functioning The dishwasher seems to attempt to run program's as normal but after a few minutes when the water is supposed to start spraying around inside, there is only a humming noise and no water seems to be coming in to the machine. Also, a small leak of water is coming out of the bottom of the machine. I have removed the covers and laid the unit on its side and it would appear that water is coming out of the salt reservoir/ water softener unit. I can see no other visible problems and no evidence that the water inlet pipe is not functioning and I have ensured that the drain is working normally. What I can see is that there is a darker, coppery coloured content inside the water softener reservoir, alongside the fresh new salt I put in this week. But right at the bottom of the white salt appears some grime or grit. Up on the Side, in the water softener tank ( the complex routed flat shaped tank), there appears to be a white calcified surface on some of the channels and there is water high in the tank which appears to be blocked by the calc deposits. So I can imagine if water pressure is being pushed into this whole system and water is unable to flow, then the whole reservoir will begin to leak. Do all of these components need replacing or can I remove them and maybe wash out with some mild acid to remove the offending calc? Or am I barking up the wrong tree altogether? One concern is that if I remove these parts then I may damage other seals. Help/ advice would be very welcome, thanks.
Feb 28, 2017 | Smeg 24 in. DWF612SS Free-standing...
See all Smeg 24 in. DWF612SS Free-standing Dishwasher Questions
Smeg 24 in. DWF612SS Free-standing Dishwasher Logo
Top Smeg Dishwashers Experts
Cleverer2
paul
paul
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
