Question about Cell Phones
Phone dropped in pool
Hi, I just saw your mess about your phone can you help me fix mine? cheers del
  • 119 Answers
Here's what I did...
Go to the drug store or walmart and get the highest concentration of isopropal alcohol(rubbing) I think it will say 97%. If you could get 100% that would be even better.
Pour the alcohol in tall thin container and take out the sim card if it has one. Take it back out once submerged and shake it well to make sure you get it in every nook and cranny.
Put it back in the alcohol for two hours.. Remove it and shake it again really good this time. Let dry for about a day and verify that it looks dry. It must be pretty dry or you could mess it up. But it should be because alcohol evaporates quickly.
Like I said i dropped mine while boating in the ocean and was able to recover it.
Good Luck
Posted on Jan 19, 2009
Safelink royally messed up my tracfone. how do I get a new sim card?
Hi Debbie, go to any cell phone store for a free (blank) sim card which they should help you activate with your phone number to your service provider.......CHEERS..
Mar 31, 2016 | Cell Phones
Our water level in our pool dropped over a foot overnight
Depending on the size of your pool that's allot of water, check your switching valve it might have a bad gasket OR if your pool has trees near it roots can break the plumbing
You will need to keep a eye on your pump now it may have ran dry and damaged the shaft seal, look for a wet spot under the pump if you see one the shaft seal MUST BE CHANGED ASAP. failure to do so will cause water to leak into the motor and damage the bearing and as a bonus the bad bearing will cause the motor to consume large amounts of electricity, easy fix. I only charge $20 to install a shaft seal,seal included "most pumps" (if u bring in pump) use only quality seal there are seals available on Ebay like these... please PRIME THE PUMP AFTER ANY PUMP REPAIR !
Jay the pool pump motor repair guy longwood fl 32750
Dec 28, 2012 | Pool & Spa
My son dropped his phone in the ocean will not come on
It most likely is dead. Whenever this happens you should immediately remove the battery. If that is not possible turn the phone off. From there, letting the phone dry by putting it in a Ziploc bag with rice for several days sometimes will fix the phone.
I once dropped mine in a pool. I popped the battery off, dried it out with the rice method and tried to get it working again. It did not work until I replaced the battery but the phone was fine after that.
Aug 29, 2011 | LG Dare VX9700 Cell Phone
Env2 flip screen (the keyboard screen) blacked out, but...
walk outside with your phone in hand. with one hand, hold the phone firmly. with the other, grab a baseball bat. step out into your yard, or maybe the yard of a neighbor you don't like. throw the phone straight up in the air, then grab the bat handle firmly. swing away at that bad boy. fetch the phone and repeat the process if you are not fully satisfied with how your phone functions after one whack. hope this helps
Nov 25, 2008 | Verizon Communications enV2 Cellular Phone
A88 CECT
i had the same problem but just charged it and it was better although it does tend to freeze when im low on battery
Oct 31, 2008 | Dual Electronics CECT P168 Cellular Phone
My phone got wet help
I took the phone apart and used an electrical contact cleaner on the phone and sprayed the hell out of it minus the battery which you will have to buy a new one. The put a fan on it for a day then let it sit on the dashboard of my car for a day. Put it all back together and it works Mine was dropped in 18 feet of salt water
Oct 30, 2008 | LG VX-8700 Cellular Phone
2375 poulan chain saw brake is shot,how do I fix it?
You Likely by this time have resolved this. Mine messed up one day and I found a spring inside it. This spring wraps around the counter weights and pulls them together at idle speed, allowing the chain to stop, without stopping the motor. As you throttle it up and the RPM increases the spring allows the weights to push outward , engaging the chain. I have used mine without it, but I'm sure that would not be a recommended procedure, as the chain is always engaged, even when idling.
Oct 06, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Call drop out after 5mins 30 secs
Hi Youradickhead, I have experienced similar problems previously with Telstra and it was not due to the D-link as far as could verify. It seemed to me that Telstra was able to detect that you were using your internet connection for phone conversations and drop your line. Alternatively it may have to do with the filters that they provide. Try it without the filter, i.e. connect your modem cable straight into the socket (cable port).
Cheers.
May 25, 2008 | D-Link AirPlus DI-524 Wireless Router
Nokia 6233 water damaged...
Unfortunately, probaby both, plus the keypad, other selector buttons, camera and speaker.
Most likely would cost more to repair than to replace.
Mar 26, 2008 | Nokia 6233 Cellular Phone
Emergency Download
Same prob with mine when I spilled water on it. Try pressing the 5 key and power on key at the same time, then remove the battery. I had to do this a couple of times, but now it is working fine.
Feb 17, 2008 | LG CU500 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
