Question about Polaris 380: Polaris Booster Pump
Polaris 380 booster pump seal leak
I have a Polaris 380 and the booster pump has developed a lslow leak at the fitting leading into the top of the pump. The pool man who came out to the house today said the pump is also leaking "at the seal". I am being told the pump is at the end of its "useful life: and rather than replace the forward seal and impeller assembly I need to buy a whole new pump. The pump is a little over 7 years old. Any advice?
  • jmondlock Jan 21, 2009
    The main question I have is if the "useful life" observation is accurate. Granted the pump is about 7 1/2 years old but it only runs 2-3 hours per day.
    jm
    Sergeant:
    Champion:
  • 239 Answers
If you are trying to fix it to save some money , my advice is don't do it because it will leak again sooner than later , best bet replace the pump!!
Posted on Jan 19, 2009
Polaris 380 wheels not turning
see if filter at wall fitting ok then see if water coming out of jet on back
Aug 02, 2017 | Polaris 380 In Ground Pool Cleaner
My pool is losing water when a Polaris 380 is running off a booser pump
plug both sides of Polaris hoses one at wall and one at Polaris if stops leak in Polaris line
Jun 08, 2012 | Polaris 380 In Ground Pool Cleaner
My polaris booster pump noise
bad motor due to bad seals leaking on motor better to replace whole pump next time
Jun 03, 2012 | Polaris Pb4 - 60 Booster Pump
Which pressure should i use on uwf polaris assembly 380
It might not be your booster pump. First, check the filter screen and clean if necessary. Often, this is the only problem when these pool cleaners are having problems. Clean the skimmer, pump, and filter also. You will also want to check all connections and hoses to make sure that you don't have a leak.
Mar 14, 2010 | Polaris 380: Polaris Booster Pump
I installed a booster pump. Attached a one ince
1. debris in the water management system (hoses inside the cleaner)
2. black gears in cleaner need replacing (360/380)
3. belt kit (polaris 360/380) or drive shaft need replacing (180/280)
4. teeth on inside of wheels are worn out (polaris 180/280 only)
Jul 16, 2009 | Polaris 380 In Ground Pool Cleaner
Do other brand name pumps work with a polaris 380 or do i need to use the polaris pump?
The Hayward booster pump would work but being in the same price range the Polaris is engineered for its cleaner
Jun 30, 2009 | Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL...
When running it makes a loud continuous loud noise
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
Jun 02, 2009 | Polaris 380: Polaris Booster Pump
Polaris 380: Polaris Booster Pump Logo
78 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
