Question about Toshiba 46HM95 46" HDTV
Lamps burned every 6-9 months.
Service center said I may not replace the lamp correctly? I bought 3 lamps since bought TV in Nov. 2005. Your help is greatly appreciated. C. Wan
  • 1 more comment
  • Anonymous Feb 01, 2009
    You most likely didn't put them in wrong, there is a defect in the manufacturing which causes the lamps to burn prematurely and this is a common problem. I am on my 3rd lamp as well. There is a class action lawsuit against Toshiba where you may get reimbursed for the lamps, because apparently they knew about the defect. There's a link on the toshiba website or you can do a search for dlp lamp settlement. Good luck.
  • changgui_wan Feb 06, 2009
    I left the TV on for about 6-7 hours/per day.
  • thayerslair May 11, 2010
    How many hours per day on average is your television set left on ?
This is indeed a very common problem with the Toshiba products. The reason I asked about the time is that the television bulbs are estimated to last on average 4,000 viewed hours, which you are only coming up short of 50%.
Toshiba is offering an extended warranty free on the product that does cover the bulb replacement.
http://www.tacp.toshiba.com/tacpassets-images/notices/dlplamp.asp
is the link for this extended warranty.
After researching your particular make and model, I have found that the average span for a bulb is indeed 9-12 months. Beyond this extended warrant, Toshiba is offering no further assistance, and will only replace it once. They have also been having issues with the color wheel going out at an average cost of $750.00 which under warranty they will replace one time only.
There is nothing you can do beyond replacing the lamps, however my suggestion would be to replace the television itself, and stay away from Toshiba.
Posted on Feb 06, 2009
Kdf-e50a11e diagnostic codes
3 blinks is indicating the lamp has burned out. Aftermarket lamps tend to fail quickly. Only use oem replacement lamps for your sony. You can get replacement lamps from www.tvrepairworld.com
Feb 07, 2012 | Sony KDF-E50A11E TV
I have bought the biggest lemon in this tv than ive ever seen before..shortly after buying it, i had green swirly lines throughout the whole picture...had 2 repair guys out here,1 replaced the "mother...
Lamps have a limited life. They useually last 1000 hours or so. If the TV is on from 07:00 until say 23:00 every day, that equates to 60 days.
There is no such lamp as a "One time replacement lamp" as they do not last for ever.
The average life of a lamp is just about 6 months.
If the picture is cloudy is probably needs the optice cleaning. It is very fiddly and damage can occur easily so get an authorised Hitachi repair service department to clean it for you. It should be carried out in your home and will take less than an hour. If anything gets broken, it is not your problem if they are heavy handed.
Hope that helps.
Feb 03, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
When you turn it on, the green LAMP light goes on, then it clicks and the STANDBY/TEMP red light goes on, then clicks and back to the green LAMP light. It does this a few times, then The TIMER green light...
Usually if all 3 indicator lights come on this could be the color wheel is not functioning or the DINe chip needs to be re-soldered. Be sure the lamp door is closed all the way, but the color wheel needs to be looked at first.
http://tvtechwork.webs.com/
Nov 17, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
My tv turns on, but there is no picture. The two green lights and one red light are flashing on the button in front. What do I do?
That means that the lamp may be defective and the TV needs service. You can replace the lamp yourself. The code is on the right side of the TV and on the lamp case. Get a replacement using this code from the store where you bought the TV or a Samsung Service Center.
Once you have the correct lamp (the wrong one may damage your TV), make sure your TV has been off for at least 30 minutes (cool down). The cool down will not happen properly if the TV is plugged into anything other than a wall outlet.
Open the lamp case and take out the old lamp and replace with the new one. Do not touch the glass with your hands and do not insert any objects into the case. Do not leave the old lamp near flammable objects or where children can access it.
I hope this helps.
Apr 13, 2010 | Samsung HLS4266 TV
KDF-55WF655 WHEN I TURN IT ON IT CLICKS .THE SCREEN STAYS BLACK, THE POWER/STANDBY LITE BLINKS 6 TIMES. IF I TURN IT ON 3 OR 4 TIMES IT BLINKS 10 TIMES. CAN ANYONE TELL WHATS GOING ON. A SERVICE MAN...
If I remember correctly, 6 flashes is a lamp issue.
A blown lamp is usually caused by dirt in the vents (and a blown thermal fuse). If the tech replaced the fuse but did not vacuum out the TV, find a new shop.
The lamp could be overheated and need replacing. The lamp driver could also be failed.
Fans in the set could be not turning and overheating the set.
Check with Sony for a reputable center. Best to transport the TV in to save service call charges. Expect to pay $275 for a lamp + labour.
Mar 31, 2010 | Televison & Video
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
Panasonic PT50LC14 Power issue
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
May 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
New Lamp will not come on
I suspect thermo fuse near lamp or ballast or light engine. In that order , first double check lamp is in tight and covers are on correct there are switches on cover for lamp.
1 thermo 150.00
2 ballast 250;00
3 light engine 600.00
Get a tv service center to come over and check. it would be worth the service call ask him what he charges for road call , at least know you have price and part information.
thanks doctor video
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung DLP HL-R-5667W lamp LED comes on solid, no picture, then turns off
DO you have the owners mannel if so read it and see what they would do ,have you removed the lamp and if so how did it look? some lamps only last for 5,000 hrs and others 8,000 hrs If lamp is bad TV will not come on.
Feb 20, 2008 | Samsung DLP HL-P5663W 56" TV
Toshiba 46HM95 46" HDTV Logo
152 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
