Question about Sony Dvp Sr210p Dvd Player Black
Sony dvd remote won't work for dvd player
I do not want it to work on the TV just the actual DVD player and it will not work. It is brand new and so are the batteries. It works from the controls on the player but not by remote.
SOURCE: Sony Rm-v202 remote the tv/video doesn't work
I need the code for operating an emerson television
Posted on Dec 25, 2007
SOURCE: Problem Getting Codes to Control Apex TV
APEX TV CODES
Posted on Jan 15, 2008
bestdarngood
  • 3037 Answers
SOURCE: sony rm-y181
use this website to get the manual with the codes
http://www.remotecodelist.com/remotes/old-index.html
The manual file that will work for you is under Sony and is named RM-Y165
Let me know if you have any questions or need any more help and I would be glad to assist you
Posted on May 20, 2008
SOURCE: Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Posted on Dec 26, 2008
ricomun
  • 24 Answers
SOURCE: SONY Remote Control - some buttons do not work.
Usually this means the conductive contact on the back of the rubber pad has worn down and cannot connect the circuits on the remote controls main board. There are several ways to fix this.
#1 Find some conductive adhesive or paint and carefully paint the back of the button tab ( let dry completely)
#2 Rear window defogger kits are available at most reputable auto parts shops and contain a paintable adhesive which you can apply to the back of the remote control button.
#3 try super gluing a small piece of aluminum foil to the back of the button tab.
I have used all 3 and they all work good.
Posted on Jul 02, 2009
HELP! Dog stepped on remote and now volume on Sony KP53S65 won't work.
test this steps and fix it. God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 22, 2013 | Televison & Video
Check disc
The DVD player's laser pickup assembly is intermittent and since it is brand new and under warranty take it back for replacement. There should be no issue with your TV set.
Mar 18, 2012 | Televison & Video
Codes to program a dvd remote to an emerson tv
Access the Emerson Remote Support site online.Locate the television's manufacturer brand within the table list. Obtain the television manufacturer codes to begin programming the television with the remote control.Power on the television you are trying to program the Emerson TV remote control to operate with.
Press and hold the "TV" button at the top of the Emerson TV remote control keypad to prepare the remote for programming and association with the television.
Enter the television's manufacturer code when the Emerson remote's TV button begins to flash. The television will automatically power off to process the new settings.
Jan 06, 2012 | Sony Televison & Video
Sony RDR-GX360 won't respond to any buttons on unit or remote. Only function that works is power button. Disk tray won't even open.
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Aug 11, 2011 | Sony DVP-S360D DVD Player
Universal remote + Quasar TV = no luck. pls help!!
Do Research on the remote with the tv brand name in google. you will find something such as an manual.
Jan 05, 2010 | Televison & Video
Sony dvd players codes on rca universal remote
unemployed and cant affoed to go to your site sorry will figure out another way.
Dec 03, 2009 | Sony DVP-NS50P DVD Player
Will a Sony Dvd player,work on a Zenith Healthview TV?
Yes, Sony DVD Player will work on any brand TV that has Composite Video <yellow> or Component Video <red-green-blue> Inputs.
Feb 23, 2009 | Zenith ZN110 Remote Control
Sony Dvp Sr210p Dvd Player Black Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
