Question about Sub-Zero 561 / F
NEED ORIGINAL DOORS ON MY 561 SUB ZERO LOOKS LIKE DOORS ON FRONT
NEED ORIGINAL DOORS ON MY 561 SUB ZERO FRIDGE. LOOKS AS THOUGH ORIGINAL OWNER HAD PANELS PLACED ON TOP OF DOORS TO MATCH PANeL DOORS ON CABINETS IN KITCHEN . NICE LOOK 20 YEARS ago BUT NOW WE WANT IT BACK TO ORIGINAL STATE. ANY SUGGESTIONS?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Given the model serial number I could get your decorative panels. The door itself is a framed door and designed to take a 1/4" insert. You can have new panels made if you have changed the cabinets, order stainless steel panels or put another material of your choosing. If you would like the more about the panels reply with mod and ser number which is in the freezer door jamb at eye level. Open the door past 90 degrees and look in.
Posted on Jan 23, 2009
  • Lauren
    Lauren Dec 06, 2013
    Are you still available to help with replacing wood panel fronts to stainless steel on a Sub Zero 561 model number P889755?
SOURCE: Sub Zero Model 680 - Light in Fridge and Control Panel out
replace door switch
Posted on Sep 03, 2008
  • 479 Answers
SOURCE: We have a 5 year old side by side sub zero fridge/freezer (largest size)
check whether the temprature is set properly in the freezer on proper level.
Posted on Sep 27, 2008
SOURCE: sub zero freezer too warm
I believe the freezer has to get down to 7 degrees or lower for icemaker to harvest. Clean your condenser and blow it out. If that doe not fix it you will need service for sealed system
Posted on Oct 08, 2008
SOURCE: my sub zero model 561 dosent't cool when the weather outside is h
I had the same problem with my sub zero. I took off the grill on the top and vacuumed the coil that has the fan in front of it. The problem has not happened since. I'ts worth a try.
Posted on May 01, 2009
SOURCE: sub zero fridge model 561 not making ice
Thanks to everyone for the help.We did get it moving and working finally. My husband took the ice drawer out. Reached up to where the ice drops out and poked around a bit. He said he didn't move anything but I heard a piece of ice move. We then shut the power off at the breaker switch, waited 10 seconds or so then turned back on. An hour or so later, we heard ice drop and it's still making ice. What a relief. I
could tell there had been a power failure as the clocks all needed resetting. So as someone suggested, we just had to reboot the thing.
We tried everything after reading 50 plus pages of questions and answers and finally got it. Thanks so much!
Posted on Jan 08, 2010
My sub zero model 561 refrigerator side is not working
The fridge side or the freezer side? not cooling, or just no lights? Nothing is cooling or lighting?
Sep 18, 2013 | Sub-Zero 561 / F
Our sub-zero refrigerator has not been cooling properly and mold builds up near the bottom
My Sub Zero 561 would lose cooling in the main fridge area over time and I would usually turn the thermostat down. This helped but I'd get an ice buildup on the back wall of the fridge, especially if it was packed full of stuff and didn't allow for air movement. I finally removed everything, removed the back panel to the fridge, and discovered that the entire rear area was a solid block of ice. A defrost fixed it but I had to turn up the thermostat to keep it from coming back. Now it works great after driving me crazy for years.
Jun 02, 2012 | Sub-Zero 561 / F
I have a sub zero 561. The freezer works properly but the refrigerator is not cold enough. I turned temperature from 5 to 7 but no change
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Sub-Zero 561 / F
Ice maker not working in sub zero 561 model
you need to make sure that the unit has the water supply turned on. if you have a water dispensor on the front door and you are getting water then the water supply is on.
This ice maker is located in tight spot and has to be removed to cycle it manualy. so im going to give you a different way of doing a test.
first i want you to try to put your finger in the ice maker to see if you have any water or ice in it.
If it is empty then follow this step : try to get water in it without removing the ice maker. Do not fill it to the rim, just about halfway. This wont be easy, but if you do that you can check it the next day and see if it droped ice. if it did then your water valve is bad.
If it has ice in it then the ice maker in mostlikey bad.
or the switch for on and off is bad. (not common)
The freezer has to be under 14 F for most ice makers to operate.
Jan 07, 2010 | Sub-Zero 561 / F
I have a 20 yr old Sub Zero 561 side by side. The
If it were not a Sub Zero i would say its time for new. It sounds like it needs a service call and shot of gas and all will be well for many more years.
Sep 01, 2009 | Refrigerators
My 561 refridgerator door gasket is torn and needs replacing. How do I remove the old one?
I sure look carefully for solutions - some clown just replaced mine for a mear - get this $750 dollars. I assume I've been ripped off, my bride handled the call - don't use REO appliance -
Jul 14, 2009 | Sub-Zero 561 / F
My sub zero model 561 dosent't cool when the weather outside is h
Apr 26, 2009 | Sub-Zero 561 / F
Sub-Zero 695s - plastic/rubber fridge door edge is warm
This is normal and is to keep door from getting moisture or sticking around door seal. You also can contact them at 1-800-222-7820
Sea Breeze
Mar 27, 2009 | Sub-Zero 695/O Side by Side Refrigerator
Fridge not cooling
two comperssor ... check the thermostate ..or make sure there is power to the compressor...
Dec 22, 2008 | Sub-Zero 561 / F
Refrigerators Logo
463 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
