Question about Kenmore Elite 45986 Front Load Washer
I have a kenmore Elite HE5
I keep getting a F21 message
  • 640 Answers
Unit is taking to long to drain,,its time to clean ,,pump filter..onthejob
Posted on Jan 20, 2009
Heat turns off while clothes still wet
change the gas coils on the gas valve by removing the 2 screws holding the bracket for the coils,remove the wire harnesses to each coil,dont worry one coil has 2 wires the other has 3 so quite hard to reverse
Jun 16, 2012 | Kenmore HE5
I keep getting error code F21 on my kenmore elite which is a drain error the drain is not clogged and the drain hose is not clogged any ideas on what I could do?
The error code F21 is similar to F02 which both pertains to a draining problem. The usual cause is a blocked drain filter or a clogged/kinked. But since those areas are found to be not the source of the problem, the problem must be somewhere else. It is either the drain pump is broken particularly the impeller if the pump just hums/whirs or the pressure switch contacts are stuck/welded together and is, therefore, not tripping. The link below provides the detailed troubleshooting instructions the problem of this kind after the drain filter has been cleaned out.
Error Code F02/F21 on Whirlpool Duet and Kenmore Elite Front Load Washers (Filter Cleaned)
Aug 21, 2011 | Kenmore Washing Machines
No heat-Kenmore (Whirlpool) Elite He5 Steam 110.8775
Check that there is 240 volt at the plug as sometimes a breaker will be weak on one side and only produce 120 volts which will let the drum spin but produce no heat
Mar 20, 2010 | Kenmore Elite 45986 Front Load Washer
Ok to Use in Australia USA Sear's Kenmore Elite He5 W/D
should not be a problem as long as the converter is for that country. but i would suggest you get the appliances changed over to the proper wiring as the adapter is just for temporary situations
Sep 30, 2009 | Washing Machines
I have a Kenmore Elite HE5 front loader and seem
when i clean my screen i use a cheap vacuum to **** up particles as i pull it out and vacuum screen. works so nice.. but use a cheapy that you doesnt need a bag and it will filter better as it gets clogged with lint lol.
Apr 16, 2009 | Dryers
Kenmore He5 Dryer
try replacing the door strikes and catches part # 279570...possible door hinge issue but less likely
Aug 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
107 people viewed this question
Sal De
fordexpert
Robert Rankin
