Samsung tv is saying no signal when component for DVD player is connected
Firstly using TV remote go into menu, Then find factory reset option and reset tv,also why so many leads can you use a hdmi cable
Posted on Jan 05, 2013
SOURCE: samsung dvd home theater HT d5610
I am looking for and to purchase an antenna for my HT D5610. Thank you for any help you can provide me with.
Posted on Feb 01, 2009
chipsandnuts
  • 70 Answers
SOURCE: Samsung DVD (1500) Remote problem.
Try to reset the blu ray player's remote control.
Remove the batteries and hold down the POWER button on it for 30 seconds.
Then replace the batteries with fresh ones
Posted on Jul 04, 2009
SOURCE: I get a "no signal" message when using HTMI or Component cables
on the remote, press "progessive" until you get a signal through hdmi to your tv
Posted on Jul 06, 2009
  • 1043 Answers
SOURCE: Just got a samsung H1080 DVD player playing black and white only
The component connection should have one red, one green, and one blue connector that will connect to the back of your player and the back of your television. Then there should also be another red and a white connector that should run from the AUDIO L & R OUT of your player to the AUDIO L & R IN beside the Component IN connections on your TV. The yellow cord would normally be running from the VIDEO OUT on the back of your player to one of the VIDEO IN connections of your TV.
Posted on Aug 12, 2009
  • 380 Answers
SOURCE: the VHS tapes will not playback on the Samsung TV
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Posted on Dec 30, 2009
Connect sony dvd to samsung tv
There are five ways to get the video and audio signals from the DVD player: HDMI, Coaxial, Audio/Video, S-video and Component video, which way did you use?
Jun 07, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
No Signal form Samsung DVD R 155 to Vizio TV
tried to hooked up to other tv or other component input with in the tv and replacing cable wire just to ensure where the main cause of the problem.
Sep 02, 2012 | Samsung Televison & Video
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
Connected samsung ht x720 (home cinema system 2.1) to v+ box.Cant get picture when playing a DVD.Can hear the sound tough.Thanks
You probably need to change the incoming input signal on your tv.
In other words, your audio is coming directly out from your dvd player, and going directly to the audio power amp.
Your video does the same thing, except it goes to your tv. Your tv has multiple places for "incoming" signals to hook in to it. Take a look at where you're hooking your video in - the input should be marked ... something like "Component 1" "Component 2" "HDMI 1" "HDMI 2" ... something like that.
On your remove, there will be a button that says, "Input." When you push this, you will see that your TV brings up an input selection window. Pressing the "input" button on your remote should scroll through the ports on the tv. Briefly pause on each input selection to see if it begins receiving a video signal from your DVD player.
Nov 19, 2010 | Samsung Audio Players & Recorders
DVD player and HDTV incompatiblity?
Which ports on the TV are you using to feed the video signal to the TV: Composite (yellow RCA), Components (red, blue, green RCA), HDMI?
Dec 23, 2009 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
No Signal on DVD to Samsung 2333HD Monitor/TV
I had the same problem connecting the monitor to my Philips DVD player. After a couple days trying to determine if the monitor or cable was bad, I went to the Philips user manual and found that the Video Output setting had to be specifically changed to YPbPr/Component (which I needed). Apparently the player sends the signal in only one format at a time. Hope this helps.
Jun 10, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Novice installing HDTV(Samsung),DVD(Sony) no pic on TV
Purchased a newer HDMI DVD player,(Sony)as well as found that I do need the video cables.Also found that I need to change the input to component on the DVD player by using a regular coxial to at least get a display from the DVD player had I kept the older one.
Oct 08, 2008 | Televison & Video
Mintek 2110 no component video
You need to change the Video out in the menu.
Press set up on the remote
move down to video out and select YUV output
it should now work
Aug 08, 2008 | Mintek DVD-2580 DVD Player
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
