Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
I cant remove the spin tube on maytag centennial washer
Videos show the spin tube easily sliding out to replace it. mine will not come out. Model#MVWC3OOVW1
beltronic205
  • 1467 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: Maytag Neptune bearing noise
John,
What are the first two numbers of your serial number i.e.10 through 17. I’m an owner like you not a repair person….. but I have a very good feel for machine issues and the repair of the machine. See my ratings under this nick name FAV6800AWDIY and my old original nick name dh1200s.
The biggest problem with FIXYA is they don’t ask the user for Model or S/N of the machine. I can’t believe how many professional repair folks jump in with comments and they have no clue as to what machine is being discussed.
You may end up going with a replacement if it’s the Outer Tub Bearings. I would remove the tub and try to replace before I would junk a $1000 but that’s me you would need to decide. This a weak repair area for me I have not replaced the outer tub bearings on any of the three FAV66800A’s I own but I feel confident I could do it. I buy these cheap and repair for resale.
Have you had the Clutch Pulley removed/replaced in the past for dC or uC error code failure in Spin Cycle?
I would drop the Clutch Pulley out and clean up/re-lube the One-Way Roller Clutches and check for signs of a tub seal leak. Then with the Clutch Pulley out spin up the Wash Basket CCW as fast as you can by hand and listen for bearing noise of the Outer Tub Bearings. Let’s make sure the One-Way Roller clutch bearing is not the bearing noise source. See this post for removing the clutch and doing maintenance and replacement. Clutch Fix Post
I have to post rest of this comment as a comment. This forum is not geared up for DIY responses.
Posted on Jan 25, 2010
Daniel S
  • 4323 Answers
SOURCE: Maytag Centennial will not spin
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 22, 2010
richroth
  • 9472 Answers
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Posted on Dec 26, 2010
richroth
  • 9472 Answers
SOURCE: Washer immediately goes into wash cycle when
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on Jan 26, 2011
Maytag top load washing machine repair
It sounds like your Maytag (now owned by Whirlpool) Actuator needs to be replaced. Last year our Maytag Centennial top loading washer Model MVWC300XW0 would not drain all the water and cloths would be soaking still. Doing some online research, I came across some very helpful video regarding replacing your Actuator.
The only thing I would recommend to future installers is get your Technician Manual located just inside the case (front panel) first of your Washer. The Technician Manual is taped inside your washer in a plastic bag. Once you replace this Actuator part, I recommend that you run the Calibration cycle on your washer. It is needed anytime you replace a motor, motherboard or pump.
Here are two videos describing how to change/replace the Actuator but these videos are basically for the MVWC300XW0 model. I'm sure if you search for your model, there will be other videos as well.
Two videos on how to replace your Actuator:
1: https://www.youtube.com/watch?v=YVjTY-Hj4jw
2: https://www.youtube.com/watch?v=yTHryoT78pA (This is video that I viewed the most)
Best of Luck!
Jun 05, 2016 | Maytag Washing Machines
Not operating correctly Sometimes doesnt fill all the way Sometimes doesnt go through the cycles correctly Somtimes it doesnt spin out correctly clothes still wet What needs to be replaced
Model number would be helpful just so I know what type of Centennial washer we are talking about...
If it's what I think it is, Here is a diagnostic guide to get error codes that may help to figure out the problem:
Maytag Centennial Washer Diagnostic Guide
My guess is the tub sensor...
Apr 23, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Specs for model#MVWC400XW0 Maytag Centennial Washer
It definitely could be a clogged or bad pump. However, it's always a good idea to check for error codes before replacing a part...Especially expensive ones...
http://applianceassistant.com/Washer-Repair/Maytag-Centennial/Maytag-Centennial-Washer-Error-Fault-Codes.php
Hope it helps! Good luck!
Mar 02, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer will not go to spin cycle in any wash mode. have to put in spin cycle after normal wash, what's going bad?
I have found that any time a washer will not automatically go to the next cycle the problem is in the control. Replacement is something you may be able to do yourself. There are many help videos on YouTube, just do a search within the site. Hope this helps,
Dennis
Feb 11, 2015 | Maytag Washing Machines
Why does my maytag yop loading centennial washer sometimes spin and sometimes not?I can move the washer cycle knob to different cycles and I will still have the same problem
I had the same problem kinda. Does it start to agitate before it fills with water? Its supposed to fill with water, agitate, sense the amount of the load, then fill with the correct amount of water. If it agitates right away then you need a water level/ temperature control sensor. I replaced mine and no longer have the problem of wet clothes at the end of the cycle. The part number is w10248240. Look on you tube for a video on how to replace. The one I saw showed how to diagnose the sensor. The part cost about $90 and it took longer for me to get out my tools than replacing the part. This part goes bad by starting the machine then adding more clothes after it starts. You can also try blowing air down the tube from the back of the sensor. It didn't work for me but was suggested and blowing the air didn't cost anything.
Apr 23, 2014 | Maytag Centennial 3.2 cu. ft. SuperSize...
Clicking noise during spin
You will need to replace the "motor coupler". Here is the part to order.
Here is a video to show you how to do the repair.
Nov 11, 2012 | Maytag Centennial MTW5800TW Top Load...
Washer immediately goes into wash cycle when filling with water on initial start.At the end of the spin cycle ,washer dumps water back in to drum.Also,it's not getting the detergent out of clothes. Maytag...
Jan 26, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer will not start. when we turn it to spin it will do that? we have checked water source thanks
It must first fill with water before it washes. Might be a bad water valve, water temp switch, water level switch or timer. Your timer has a big block that pushes into for the connection, sometimes it backs out a hair or gets corrosion in it so check that.
Here are some videos that show how to get into the machine.
Jan 07, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
