Question about GPX D1816 DVD Player
How do i hook dvd player to tv..i know its probably simple
The HD receiver i have from direct tv my new tv and a dvd player...red yellow white cables.what goes into what
The yellow and white cables hook into your tv inputs
Posted on Jan 19, 2009
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
What plugs do I plug an xbox360 into on a magnavox dvd player
Jesus, not even the red white and yellow hookups? Oh, man, sorry, but I would need the model of the DVD player...and how did you hook up the DVD player if it doesn't have the red white and yellow hookups? just curious. Also I would highly recommend getting a new TV outright. If your tv is that old, it doesn't have HD, and that essentially defeats the whole purpose of having a powerhouse like the xbox 360. If you want the dvd player hooked up, give me the model number, but if you want a new tv, give me a budget and I am positive I can direct you to something reasonable.
P.S. (being tech savvy isn't a requirement for the newer tvs. in my honest opinion, You have to be a WIZARD in order to get all the inputs to convert to the correct format so it can be displayed on the older tv, so hanging onto the old tv is actually more trouble than a new one. Just saying.)
Feb 11, 2012 | Microsoft Video Game Consoles & Games
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
Hooking up wii and dvd to tv. i have Direct TV, a DVD player and need to hook up a Wii console. i have the direct tv DVR connected to the DVD player by coaxial cable and the yellow/red/white cables...
does your tv have scart sockets?
if so you can buy this adapter that on one side is the scart socket and the other is the yellow red white sockets
something like this
http://cgi.ebay.co.uk/Switched-SCART-Adapter-Red-Black-Yellow-RCA-Socket_W0QQitemZ260520047480QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3ca8347378
Dec 30, 2009 | Nintendo Wii Console
Hello I am trying to hook up a dvd player to my kenwood vr 505 that has been in storage for a while. How do you hook up a HD tv and dvd. Does it go out from the receiver to the tv, and does the dvd go...
If you are using HDMI cables for HD then you will need to connect this from your dvd player to you tv. Then connect your dvd player to you amp using either fiberoptic cable or co-axil (orange) this will transfer your dolby digital signal. Then connect other stuff like video / freeview etc to the yellow red and white on amp, you may need a scart to phono cable. Then connect monitor out from you amp to the yellow on your tv .This way when you select the source on the amp the picture will change also. If you search the web for vr-505 manual there are some sites offering it.
Nov 27, 2009 | Kenwood VR-505 Receiver
I'm trying to hook up a 5-speaker Dolby surround
out of tv, into the combo, out of the combo into the surround amp and this work
Sep 01, 2009 | Televison & Video
I simply don't understand how to hook up the DVD
OK simple mind maybe this will help. Cable bos to DVD and DVD to TV. A set of red and white cables are for hearing (audio) ( red is general right and white is left) the holes that you plug them into should also be color coded the only real trick is that they are flowing in the correct direction. They should go out from the cable box in to the DVD and then a set should go out from the DVD and into the TV. The Yellow is for video on some units. Not all units need the yellow. Since it is cable there should be a cable connection from the wall to the cable and the only place that might need the yellow is from the DVD to the TV depending on your model of TV. Mine for example, uses an HDMI cable instead of the yellow plug ins. Hope this helps!!
Jun 15, 2009 | Supersonic SDAT SC-25 DVD/Karaoke Player
Need to know how to hook the 2 together and then to a hd tv
Connect the dvd player to one of the video inputs of the tv. Connect the left and right audio outputs from the tv to an input of the receiver. aux, or whatever you choose. Simple.
Apr 23, 2009 | Televison & Video
How to connect new HD cable box to receiver
HI:
You are using a new HD Cable box, that are using componet video cables for HD, Unfortunetly this receiver does not have componet inputs, so you will just have to run the audio from the televison directly to the receiver by connecting the video out and audio out from the television to the receiver's video Input one. This will require a normal RCA composite cables yellow,red,white. Connect one end of each of the cables to televisions output terminals, and the other to the input one on the receiver. Note: Your TV might have a seperate term called Monitor out, Connect the yellow here, and the red and white to audio out. You can do the same for the DVD but you have to use the same cables,Also the television will not display HD picture this way as this is not a HDTV Receiver. If you just want TV sound to the receiver then do not use the video(Yellow) cable just use the audio out terminals from the tv and connect to Input one on the receiver. you can do this with the cable box also but you have to use RCA type cables . If you want the full HD experience then a new up todate receiver is necessary.
Dec 06, 2008 | Sony HT-DDW740 System
PLAYING DVD
check your connections on the back of the tv and back of the dvd player. make sure you are using the proper conections on the back of the tv. if you connect the RCA (composite) cables (red yellow white) you should be going from the red yellow white on the tv to the red yellow white on the dvd player. if you have the component(red blue green) connection on the dvd connected to the red yellow white on the tv, you may get a black and white picture. If this does not work, check the manual for the dvd player and see if there is a way to turn "Progressive Scan" features off, some older TV's cannot handle a progressive scan dvd player.
Aug 13, 2007 | Koss KS2503 System
GPX D1816 DVD Player Logo
191 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
