Question about General Electric Dishwashers
GE Quiet Power II (12 y.o.) dishwasher not rinsing dishes. Water flows into unit but when wash cycle begins, water drains out immediately.
No problems until now. Dishes not washed at end of cycle. Tried turning off power and changing wash cycle but didn't work. Hot water flows in but drains right away during the initial wash cycle. Plastic rinse tubing and rotating arms all move freely.
SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
Posted on Apr 12, 2008
BIKER T
  • 909 Answers
SOURCE: Bosch Dishwasher with very little water pressure or power
It all stems back to your incomming water supply. Either the sieve is dirt or the valve is blocked with sedementation. Some valves are servicable and some are not,if your valve has screws then its revicable. (low water pressure restricts movement on arms.)
Posted on Sep 18, 2009
Macmarkus
  • 2605 Answers
SOURCE: Dishwasher is not washing the dishes. Motor sound
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1776 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, as you mentioned. What you may not know, is the impeller itself is not serviceable, the entire motor/pump must be replaced unfortunately.
Before declaring it is indeed a motor/impeller issue, you said you hear a quiet sound of a motor starting once the unit has completed filling with water right ? Be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues. (try placing both spray arms at 12 o'clock position and placing a cup upright in the top rack. If the arms move and the cup fills, you've got circulation...if neither, you don't)
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump or severed somewhere between the motor and control, maybe where the door pivots during opening...but not likely.
This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders ( which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet. Check those other possibilities first and tell me what you find.
I'll watch for your reply.
Regards,
Macmarkus :)
Posted on Apr 19, 2011
caroldon
  • 17129 Answers
SOURCE: My Whirlpool Gold,quiet partner 3,model
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. Now if youheard the HUM then it canbe that the motor is not initiated which is relative to a faulty pump or motor. Also the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor .
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water .
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
For spares click On:
http://www.espares.co.uk/search/dishwashers/p/1083
Posted on Jul 19, 2011
Macmarkus
  • 2605 Answers
SOURCE: Bosch dishwasher, Model SHX45PO5UC
Hello, welcome to FixYa.
Based on your description I'd say the issue actually is with the control...unfortunately. This is commonly associated with a heating fault on Bosch built dishwashers ( various models including Bosch, Thermador, Siemens, Gaggenau, and Neff ).
Since the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). These are the steps you'll need to follow to resolve it or at least investigate.
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay, hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...this can also manifest as a long cycle time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning, no heating ( don't be fooled by the homes inlet hot water temperature ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last. Bosch recommend`s replacing the control and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness. Good luck.
Regards,
Macmarkus :)
Posted on Aug 18, 2011
Testimonial: " Well thought out response and description. Since washer is still under warranty for control unit we will probably have the Bosch Service Rep. repair"
Whirlpool dishwasher, quiet partner 1. Does not drain, does not finish wash cycle.
ensure your dishwasher pump and drain hose are unobstructed. If your machine does not drain it will not refill with fresh rinse water and since it can't do that the cycle will never finish.
Many people don't completely rinse off food stuffs from their dishware, expecting the dishwasher to take care of it. To be honest, a dishwasher is more of a fine cleaning and disinfecting device than a pot scrubber. Because of this, grease, food debris, etc can clog the pump or drain line over time. be sure to use a good de-greasing agent regularly once the flow of water has been cleared (don't wash your dishes with it however)
Mar 20, 2015 | Whirlpool Dishwashers
Whirlpool dishwasher doesn't make the regular sound
The problem could be a clogged water line or intake valve. Check the lines and make certain they are open and flowing.
Feb 26, 2014 | Dryers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
I have a GE GSD 5130 Dishwasher that leaks about 12 oz of water when it is pumping out the wash water and the rinse water. Its fine during the wash and filling cycle. Is it a seal problem?
This is more likely the hose connection at the drain pump or the pump housing is leaking. You will need to remove the toe kick, place unit into a drain cycle and inspect for a leak. Here is a couple links that should help.
http://appliancehelponline.com/dishdraincircpumpvideo.html
http://appliancehelponline.com/dishwasherdrainpump.html
Jul 15, 2010 | GE GSD5130 Dishwasher
Our GE Profile (Quiet Power 6) dishwasher is having trouble cleaning our dishes. The top shelf rarely gets cleaned and the bottom is questionable. It used to work fine. We always use Cascade powder...
The obstruction can be external to the unit. Check the drain at EACH connection working backward from the sink connection all the way to the motor pump outlet hole. Do not forget to dis-assemble the Air-Gap (if installed) and to check the inside of the garbage disposal hole also.
If all of these areas are free of obstructions then there is a good possibility that the pump impeller is either very worn / broken blade or there may be damage in the pump housing itself.
I think that if you look at the external drain lines, holes, and connections you notice a big change in the dishwashers performance.
Noting that you have hard water.... I really don't like promoting products.. but when one works and works well I will pass that information along.
There is a product out there made by FINISH called Jet-Dry and it comes in a mini basket form:
http://www.viewpoints.com/images/review/2009/134/13/1242326145-55717_full.jpg
or an additive if you have a rinse dispenser:
http://www.finishdishwashing.com/rinse-and-drying-agents.php
Lastly.... if you need to clean up the dishwasher.. on an empty no dishes cycle add 2 cups of white vinegar when you know the cycle has just started filling NOT draining and let it wash. Then do your dishes after that cycle.
Thanks for using FixYa.
Kelly
May 01, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Wash cycle OK, but the drying cycle is faulty. The dishes are wet after 12 hours. Will not dry contents of washer! #SHU680SUC/U06
your heating coil has gone bad it`s that rod looking thing in the bottom of your unit under your spray washing spinner depending on the age of your unit your probley better off buying a new dishwasher
Oct 02, 2009 | Bosch Dishwashers
Dishes not clean, soap still dripping down from dispenser.
yes its the water that washes that soap out,no water no wash.so a couple of things.eazy first.im asumming it drains fine.1 so check the flood switch dome,its in the tub ,frount area if enpty should be down.if you pick up ,will hear small click.2 [harder] with a volt meter put the probes into the water valve.its in bottem behind panel most of the time its blue,so whiteor yellow.with probes in water valve connections.turn on dishwasher at begining of cycle.after short time should get 110 volts if yes need to clean out valve[minerals]or replace because failed.God bless,tom
Jan 03, 2009 | GE Nautilus 24" Built-in Dishwasher
Water seems to be hot enough, drains properly, arnms not blocked, dishes not being cleaned at end of cycle. Almost seems like it is skipping the wash cycle.
Hi smiller8565,
There is 3 basic problems that will cause a dishwasher to not clean the dishes. You can check these problems and see if any will solve your problems.
1: If there is water or suds left in the dishwasher after the cycle is complete. This will cause dirty water to be used in the final rinse and the dishes will not get clean.
2: The pump that supplies water to the spray arms is jammed or defective and unable to pump the water properly, thus causing the dishes to remain dirty.
3: Timer, the timer is not allowing the machine to work in the wash cycle.
The solutions for these 3 are as follows.
1: check the drain line for blockage, if you have a disposal make sure it is clear and water flows down the drain properly. If you have suds left in the dishwasher, clean them out and run a couple cycles with not detergent to rinse away the old suds.
2: Look down in the bottom for any obstructions in the pump. Popcorn seeds, broken glass, etc.
3: If the unit is skipping the wash cycle you will most likely need a new timer or control assembly.
Good luck and I really hope this will Fix Ya
Mike
Sep 24, 2008 | Dishwashers
LG LDF6810ST Stainless Built In Dishwasher
It is very common that high eficiency, low water using dishwashers take longer to finish all cycles. The best way to "hurry" the washing is to make sure that the water heater is providing hot water of at least 120 degrees. But no hotter then 140 degrees.
If the dishwasher runs even longer, check to see is the dishwasher is actually connected to the cold water line. This dishwasher can be run from cold water but the water heating phase in the cycles will add much time ti the entire cycle.
This unit has a sensor that detects the detects the water clarity towards the end of the wash cycle. Rinsing the dishes may speed the load a little, but encourage not to go crazy on the rinsing because the dishwasher actually counts on the food particles to help clean the dishes.
Also, note that the final (third) blinking light means drying. You can simply open the door anytime after the final draining and power off the dishwasher, allowing the hot dishes to air dry.
Hope this helps. Please resply with your findings. Thanks!
Sep 16, 2008 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
24 people viewed this question
Top General Electric Dishwashers Experts
Tom
Dan Webster
Dan Webster
Are you a General Electric Dishwasher Expert? Answer questions, earn points and help others
