Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi WS-55513 55 in. Rear Projection HDTV
My house was hit by lightening and i have no input signal but the screen still works and it has good set up picture and i'm not sure if there is sound as of right now everything appears to be normal just no picture and no input
  • 1 more comment
  • Darren Hooten Jun 28, 2007
    i'm not sure i will have to try a dvd
  • txrcaves Nov 06, 2007
    When I first turn on the TV the picture and sound will be fine for a few seconds, then the screen goes blue and there is no sound. This is the same regardless of the source of the signal.
  • Anonymous May 06, 2008
    I have 52 Vac on the coax shield. I belive it is coming from the power supply. I have also noticed that there no ground prong on the plug therefore ground reference is through the ANT A/B jacks if used and grounded outside. How can I further troubleshoot and repair ?
    President:
  • 3,130 Answers
Does a DVD or a VCR work on Video input?
Posted on Jun 28, 2007
Mitsubishi model WS-55613 screen goes off and on
there is a 9 mvolt regulator on the signal board right behind the input board. that could need resoldering or maybe replacing it should be the IC9A05
May 04, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS 55413. Ongoing rolling screen.
First check for the coolant/fluid leakage from the picture tube on to the signal board. Wipe it with paper towel and dry it will the hair dryer. I hope there's no corrosion yet.
Dec 28, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-65907 rear projection TV HD goes blue.
I would look at the source for the Hd signal as being the problem--if you are using some kind of cable or sat box it will deliver the signal to the DTV input on the back of the set--this is the HD input for this set.
It is possible to have a problem like you describe be one in the set--but very unlikely----have you looked on that green signal board for any signs of Glycol?
Anything that will produce a 1080 signal to the DTV input should tell you if the problem is the set or the source of the HD signal that is causing the problem.
If you have questions or need advice let me know--I am here to help people.
if this information has helped you rate this solution as i do this here for free.
SD TECH
Dec 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi WS-65313 Blinking Screen
Does your system have hdmi input. If so hook up cable box, if it has hdmi, to the tv and see if that works.
If that clears up your problem you have a problem with the av board or boards.
I have found that most of the newer systems do not like the voltage and frequency from xboxes, playstations, or computers very well using the rca out and in.
Let me know what you find out. I might have a better solution for you.
Dec 18, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-65909 Video Inputs Stopped Working
Finally got a tech to come out to the house ($99 to diagnose).  He determined it was the Doubler Board.  Got a quote from this company to repair it for around $800.  I was able to watch over his shoulder.  The board is really simple to replace.  I just need to find it.
Sep 13, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-55313 no video
Resolder the vertical output IC that should take care of your problem.
Jun 16, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi WS-55513 55 in. Rear Projection HDTV Television
well..there are two power sections of that board..near where the power enters the board, and also, where it delivers the signal to the screen. Both may have connectors that are wearing out, and this causes heat buildup on the board near the edges.
check there first.
Mar 25, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
