Question about Magix Music Studio 2005 Deluxe for PC
Recording do not sync up
I know this has to be a computer problem. I had this program installed on an other computer and it ran fine. Now I have it installed on a Dell Vostro 1000 AMD mobile Sempron processor. The problem is that when I record a track the object does not synchronize up with the metronome or any other previous track. It seems to slow after a 3 or 4 measures. I tried adjusting the sample rate but that still dosen't seem to help. The sound driver I have is sigma tel but I recently bought an external sound driver creative media source sound blaster because I couldn't get playback through my headphones as I recorded.
  • Anonymous Feb 02, 2009
    I have exactly the same problem, and it's really ennoying.
    I think it has indeed something to do with sound/video quality.
    I'm just hoping the problem will clear once I have bought a better sound card.
1rst- Maybe you choose the incorrect metronome. On analog audio record use your default audio card metronome and on MIDI audio record, use MIDI metronome!
2nd- Check your memory video card & remember your computer speed is as fast as the lowest speed component on it.
Pardon my poor English!!!!
Good luck!!!
Posted on Jul 28, 2009
When I play back a recording on my camera, it is perfectly fine. When I put it on my computer, the video and sound is out of sync. The video is also in slow motion. Why?
Sounds like your computer is having trouble decoding the video. You might try a newer video playback program, such as VLC (
Sep 16, 2010 | Nikon Coolpix S4000 Digital Camera
My igolf neo won't work with Windows 7 if i try
I fixed this problem by going to Start>Control Panel and uninstalling the Java 64-bit program. It is incompatible with the Neo sync application. The other Java program on there is compatible. It worked immediately without even restarting. (I tried the above Best Solution, but on the newer computers, I get a message saying the Vista driver is only for Vista, not for Windows 7).
Jan 30, 2010 | NEO iGolf neo MP3 Player
SG4 will not sync. display has UPDATE PROGRAM
Ran into this problem last night. Was trying to update software on Skycaddie. According to computer, everything finished. However, my skycaddie was displaying UPDATE PROGRAM VER 00.13 (B) Ready to Begin. Tried to reload last application as stated in earlier post. PC could not fine skycaddie.
Gave up and called customer service this morning. Only took a few minutes to get a live rep on the phone. He e-mailed me a link to execute that allowed him access to my computer. He tried to reload the last application as well, same result. He then ran an update program via a website, program found my skycaddie and was successfully updated. Whole process took less than five minutes.
I was fearing having to send my unit in for repair.
Dec 19, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
Suddenly the A/V recording is out of sync
If you have recently added and other audio / video software it is quite possible that it may have introduced some extra "codecs"
Too many or the wrong kind can have this type of impact
As can a bad player.
If you did then un-install it inc any extras or other settings it may have made.
If you have changed the format that you record in this too can cause issues esp. if the wrong codecs / player is installed.
Many video conversion utilities can play a part too.
These are all areas I would suggest you look at.
Aug 27, 2009 | Logitech Computers & Internet
Recording guitar tracks on my computer are out of sync help
Most recording programs have a some way to keep tracks in sync. It is usually some type of begining and end marker. When you press record for the second track it starts the begining marker. What is the program your using?
Mar 14, 2009 | Dell Dimension 2400 PC Desktop
Timing problem!! help needed badly!
Your solution is to delay or speed up the sound that your running thru to your computer. The reason why they put user recording latency under the options then preferences then audio settings is not because this never happens or isn't know about. If your sound is too late in the track you have to re-record the track with a higher number try about 125-160. A hint is to play some notes to the beat, check to see that you are in time, then record what you are planning to record.
Jan 11, 2009 | Sony ACID Pro 5 for PC
Won't Install
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Mar 05, 2008 | iLO (2 GB) MP3 Player
Can not connect using LG Mobile Sync
Hi all,
I went through the same trouble. After a small investigation I've found that the USB driver wasn't install. I just ran the setup and it worked imediatly C:\Program Files\LGE GSM PC Sync\USB Setup\LGUSBModemDriver_ML_WHQL_Ver_4.6.exe
Hope it could help!
Feb 03, 2008 | LG Shine KE970 Cellular Phone
60 gb ipod photo sync issues! =(
I don't believe its a File Problem, My lads Ipod has the same error -69 and will not sync, However it will also not sync on my Itunes which syncs fine with my 30gb IPOD and my Ipod also syncs fine on his computer.
So can't see where the file problem could be...
I know this doesn't help but there seems to be so many people looking in the wrong place (In my opinion)
Oct 15, 2007 | Audio Players & Recorders
Hot sync will not complete
do some clean up: try to unistall and install the PDS, in th einstallation folder (usually c:\Palm u will find a user name folder,, inside this try to rename the backup folder or cut it and copy it somewhere else... let me know the news... good luck,
Sep 12, 2005 | Palm M100
Open Questions:
Magix Music Studio 2005 Deluxe for PC Logo
166 people viewed this question
Top Magix Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Magix Computer and Internet Expert? Answer questions, earn points and help others
