Need a new base stand where can i buy one?.
SOURCE: Lost screws for stand on Vizio VU42L
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
MBSimonds AT aol DOT com
SOURCE: Missing plastic base from Vizio 22" LCD TV
Go to ur tv website buy ur part,Type in ur S/N and part.
SOURCE: need screw specs to attach base assy to tv
I
Hi there, if you are trying to just remove the base, then on your model there is one screw in the center of the underside of the base. If you want to remove the neck of the base to then remove the 8 screws on the back of the tvs neck too. I hoped this helped, please rate thank you!
SOURCE: 26" LCT HDTV Backlight Problem
It can be that the inverter is not getting the 24vdc fromt he power supply module, check for that first, you can check it at either the power supply termninals or at the inverter board. Look to see if the power supply has any leaking/bulging top caps. Modules are easy to replace, fixing it down to component level is not so easy unless you have proper tools an electronics knowledges.
Power supply and Inverter bd: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VA26L+
Learn more here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Testimonial: "Thanks. I swapped out the inverter board for one that I know works, but still have the same proble. I'll look for indications of a bad power supply for the backlight."
